Disable power status notifications
Since my battery is broken, every minute I get a notifications in the top right corner saying “Power status: AC”.
I disabled it with the xfce power manager settings in the past, but it’s not available for wayland.
Is there a way to disable these, or if it’s easier all notifications?
Search for this on the web:
reddit / is_there_a_way_to_ask_mako_to_ignore/
( The forum does not allow me posting links for some reason :frowning: )
You could just add the solution here :+1:
I added
[app-name="poweralertd"]
invisible=1
to ~/.config/mako/config and restarted mako.
