Greetings, I seem to be having some issues disabling power notifications. Is there a way to change the service to not display gui popups about battery states. Preferably something I can place in bashrc or a service I can disable for next boot. Thank you for your time.
Applications → Settings → Power Manager
…and in the General tab I turned off Status Notifications.
The General Status Notifications selection didn’t seem to make a difference.
There is also xfce4-power manager option to Show or Block in Notifications (xfce4-notifyd-config) in Applications tab. Did you try to switch off it as well?
