I was trying to google for an info how to disable “panel self refresh” as i seem to be running into this amdgpu bug 680M (Rebrandt) laptop randomly becomes very slow to update the screen (#3647) · Issues · drm / amd · GitLab and someone there mentioned disabling panel self refresh fixes this issue temporarily (even there won’t be power optimization from the psr) and this is the first result
i randomly get a lot of
amdgpu 0000:c3:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
and the whole system works in like 0.5 fps
So, the way to do it is to open this file /etc/default/grub and then add these 2 lines?
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i915.enable_psr=0”
GRUB_CMDLINE_LINUX=“i915.enable_psr=0”
I am not sure if this information here is correct, i am afraid i will break something
You replied to a two and a half year old post.
Better provide your own context by creating your own thread.
Only the first line - leave the second line be as it was → empty
https://unix.stackexchange.com/questions/440961/grub-cmdline-linux-default-vs-grub-cmdline-linux
After you changed something there, run update-grub - the second post here mentions this.
allright, thanks
i have replied to this topic because this is the thread that is being linked to when you search for “manjaro disable psr”
cscs
5
No.
First, you dont need to duplicate the entries. Just one on one of the lines is fine.
Second … that option is very much for intel. You state you have amd.
AMD has a bunch of options, which I detailed here:
And whenever you edit grub options you need to run
sudo update-grub
For them to take effect.
BG405
6
I’d just comment out that second line, and probably also remove “quiet” and “splash” from the first one.
cscs
7
I tend to prefer leaving all defaults on the … DEFAULT line, and putting ‘extras’ on the other.
Still probably an exercise in futility to apply intel-specific options to an amd system though.
