Hello,
I have this Problem in eclipse, that i cannot read Variables due to theming and it is really distracting me.
How do I disable GTK theming for certain applications and allow their stock themes?
I would like to specifically exclude stm32cubeide.
It doesn’t change anything.
Where do I put it?
I put: export SWT_GTK3=0 eclipse
in: ~/.profile ~/.xinitrc /etc/environment
and rebootet everytime.
I also put it in terminal and it did not work.
If it is that big an issue - and others have the similar experience with dark themes - the right place would be to file a report with eclipse developers - or use Adwaita - which is considered the defacto Gnome theme - it even exist in a dark version too.
The thing is the GTK theme applies to all GTK applications by default. Some may allow to use different theming, but that’s independently from the others.
So the easiest way may rather be to use another GTK theme.
