$ ls -l $XDG_CONFIG_HOME/cinnamon-session/saved-session/
ls: cannot access '/cinnamon-session/saved-session/': No such file or directory
Try:
ls -l ~/.config/cinnamon-session/saved-session/
That was it! Thanks a lot!. ![]()
It found a .desktop file which I deleted. And after restart, no automatic launch of Openoffice anymore.
I didn’t install any session manager though… Is it the default feature for Cinnamon?
Never having used Cinnamon, my only comment is:
I’ve installed dconf-editor and the auto-save-session key was enabled! So the problem is definitely solved.
