Using gnome terminal(manjaro zsh)…how to disable automatic terminal title?
I want it to just say ‘Terminal’.
This is a window-manager and/or application setting - but can also be set by -t argument in the launchers or configuration files.
Personally - when working with multiple terminals it can be very good to know if you are actually home or on some ssh sever - before you issue some critical command
Ya…R8…I think I shouldn’t change that…if multiple terminals r open then it is very hard to distinguish which is which😅
I think the auto suggest terminal title is in manjaro zsh config or something
