Hello All,
I have a Pinebook Pro laptop with Manjaro installed. Every time the system is rebooted, the brightness level gets set back to 40% and I have to use the Fn+F2 key to increase the brightness to 70%.
Not an Earth shattering problem, but it is a bit of an annoyance. I’ve searched across the web for hours, and unless I’m blind, missing it completely, or just not finding it, I haven’t found a solution.
Anyone have a clue on how to fix this ?
Many thanks
