I can easily page months using the popup calender that appears when clicking the clock - using Plasma 6.1.4 - which - if you are on stable branch - will be fixed when Plama 6.1 hit’s stable branch or you switch branch - whichever comes first
$ mbn info plasma-desktop -q
Branch : archlinux
Version : 6.1.4-1
Repository : extra
Build Date : Wed 07 Aug 2024 10:13:14
Packager : Tomaz Canabrava <tcanabrava@archlinux.org>
Branch : unstable
Version : 6.1.4-1
Repository : extra
Branch : testing
Version : 6.0.5-1
Repository : extra
Build Date : Sat 25 May 2024 22:52:20
Branch : stable
Version : 6.0.5-1
Repository : extra
And please please don’t use images - use your vocabulary to describe your issue.
Sorry, sometimes I share images because my english is not good and always a “image is better than 1000 words”. I will try to remember don’t share images.
If i’m not wrong I have the previous version:
~ sudo pacman -Qi plasma-desktop 127 ✘
[sudo] password for diego:
Version : 6.0.5-1
Description : KDE Plasma Desktop
Architecture : x86_64
URL : https://kde.org/plasma-desktop/
Licenses : LGPL-2.0-or-later
Groups : plasma
Provides : None
Depends On : baloo emoji-font gcc-libs glibc icu kauth kbookmarks kcmutils kcodecs kcompletion kconfig kconfigwidgets kcoreaddons kcrash kdbusaddons
kdeclarative kglobalaccel kguiaddons ki18n kiconthemes kio kirigami kirigami-addons kitemmodels kitemviews kjobwidgets kmenuedit knewstuff
knotifications knotifyconfig kpackage kpipewire krunner kservice ksvg kwidgetsaddons kwindowsystem kxmlgui libcanberra libksysguard libx11
libxcb libxcursor libxi libxkbcommon libxkbfile libplasma plasma-activities plasma-activities-stats plasma-workspace plasma5support
polkit-kde-agent powerdevil qt6-5compat qt6-base qt6-declarative qt6-wayland sdl2 solid sonnet systemsettings wayland xcb-util-keysyms
xdg-user-dirs
Optional Deps : bluedevil: Bluetooth applet [installed]
glib2: kimpanel IBUS support [installed]
ibus: kimpanel IBUS support
kaccounts-integration: OpenDesktop integration plugin [installed]
kscreen: screen management [installed]
libaccounts-qt: OpenDesktop integration plugin [installed]
packagekit-qt6: to install new krunner plugins
plasma-nm: Network manager applet [installed]
plasma-pa: Audio volume applet [installed]
scim: kimpanel SCIM support
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 30,60 MiB
Build Date : sáb 25 may 2024 22:52:20
Install Date : jue 13 jun 2024 22:06:19
Install Reason : Explicitly installed
Install Script : No
