digiKam won’t start. I don’t have very much information; when I start from the terminal, I get a segmentation fault:
qt.gui.icc: fromIccProfile: failed size sanity 2
qt.multimedia.ffmpeg: Using Qt multimedia with FFmpeg version n7.1 GPL version 3 or later
qt.multimedia.ffmpeg: Available HW decoding frameworks:
Segmentation fault (core dumped)
This happened with the last large system update; if I revert the system using Timeshift to a snapshot from Feb. 12, it works.
System info:
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1ce9d361-da4f-4cfc-a3f3-d8f96400815a rw udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Type: Desktop System: HP product: Victus by HP 15L Gaming Desktop TG02-0xxx
v: N/A serial: <superuser required> Chassis: type: 3
Mobo: HP model: 89B5 v: A (SMVB) serial: <superuser required>
part-nu: 669X0EA#ABD uuid: <superuser required> UEFI: AMI v: F.07
date: 05/11/2022
System RAM: total: 16 GiB available: 15.38 GiB used: 5.05 GiB (32.8%)
Device-1: DIMM2 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M378A1K43EB2-CWE
serial: <filter>
Device-2: DIMM1 type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Info: model: 12th Gen Intel Core i7-12700F bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 2076 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2076 2: 2076 3: 2076
4: 2076 5: 2076 6: 2076 7: 2076 8: 2076 9: 2076 10: 2076 11: 2076 12: 2076
13: 2076 14: 2076 15: 2076 16: 2076 17: 2076 18: 2076 19: 2076 20: 2076
bogomips: 84500
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: Hewlett-Packard driver: nvidia v: 550.144.03
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:2489 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.03x10.71")
s-diag: 1004mm (39.51")
Monitor-1: DP-1 pos: primary,left res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
modes: N/A
Monitor-2: HDMI-0 pos: right res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 102 size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: N/A device-ID: 10de:2489 surfaces: xcb,xlib
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-S HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 0bda:2852
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 4.57 TiB used: 2.1 TiB (45.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-60WN4A2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A04 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200 serial: <filter>
scheme: GPT
ID-1: / raw-size: 150 GiB size: 146.59 GiB (97.72%) used: 81.21 GiB (55.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 1ce9d361-da4f-4cfc-a3f3-d8f96400815a
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0133-6BF9
ID-3: /home raw-size: 787.58 GiB size: 774.14 GiB (98.29%)
used: 595.14 GiB (76.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 60d1d6b1-7dce-4221-b66f-f78ef18e024d
ID-4: /home/<filter>/Pictures raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 237.78 GiB (26.0%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: Pictures uuid: b337d5f1-8bc5-44ce-b22c-96e19676f922
ID-5: /home/<filter>/Pictures/Photos raw-size: 2.73 TiB
size: 2.69 TiB (98.39%) used: 1.2 TiB (44.8%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: Photos uuid: ed31eac8-59b2-4f07-83ac-e7f9363404d6
ID-1: swap-1 type: partition size: 16 GiB used: 835.8 MiB (5.1%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 88e467b5-737f-40b3-861a-922f10d60380
Device-1: 1-1:2 info: Microdia USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0c45:8513 class-ID: 0301
Device-2: 1-10:3 info: HP HP 430 Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 488mA chip-ID: 03f0:104c class-ID: 0301
serial: <filter>
Device-3: 1-11:4 info: Logitech Webcam C270 type: video,audio
Device-4: 1-14:5 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Device-1: 2-9:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2492 pm: pacman pkgs: 2482 libs: 568 tools: pamac,yay pm: flatpak
pkgs: 10
1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://mirror.23m.com/manjaro/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
7: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
8: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
CPU top: 5 of 430
1: cpu: 45.9% command: baloo_file_extractor pid: 2840
mem: 425.6 MiB (2.7%)
2: cpu: 16.3% command: baloo_file pid: 1045 mem: 25.1 MiB (0.1%)
3: cpu: 11.9% command: plasmashell pid: 1096 mem: 621.7 MiB (3.9%)
4: cpu: 11.1% command: Xorg pid: 899 mem: 116.3 MiB (0.7%)
5: cpu: 9.1% command: kwin_x11 pid: 1086 mem: 192.2 MiB (1.2%)
Memory top: 5 of 430
1: mem: 621.7 MiB (3.9%) command: plasmashell pid: 1096 cpu: 11.9%
2: mem: 474.7 MiB (3.0%) command: kontact pid: 1318 cpu: 4.6%
3: mem: 425.6 MiB (2.7%) command: baloo_file_extractor pid: 2840
cpu: 45.9%
4: mem: 417.7 MiB (2.6%) command: signal-desktop pid: 1335 cpu: 7.1%
5: mem: 290.8 MiB (1.8%) command: mariadbd pid: 897 cpu: 0.9%
Processes: 430 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
