After seeing a post on raspberry pi forum:
https://forums.raspberrypi.com/viewtopic.php?t=367491
I wanted to install manjaro with kde on my pi 5
hoping this distro will finally help me solve the problem of not need 2 keyboard and mouse for my main pc and my pi using deskflow
so I search on google went to manjaro arm website,
https://manjaro.org/products/download/arm
downloaded the image and tried to install on my ssd using pi imager custom .img then I learned that config.txt must have a line that disable the check if the distro is compatible with pi, weird, but ok, easy enough…black screen
then I discovered that the image on the site was no good and I should use this script:
https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer
but I think this only works for SD cards, and I have an ssd on my pi, when I booted i got something like couldn’t find FAT partition or something like that, unfortunately I don’t have capture card to print this error
then I don’t even remember where I got another image: Manjaro-ARM-kde-plasma-rpi4-20240513.img.xz installed via pi imager, and apparent success, I could boot, BUT anytime the mouse stooped it disappeared and had a lot of issues with it, moving when I tried to click something, showing weird black squares around it…and I saw this is a common issue, I should just update manjaro, but I couldn’t, I had a lot of dependency issues, I am suspicious that the version I downloaded was experimental one, found this site:
https://github.com/manjaro-arm/rpi4-images/releases/tag/20250929
with a gazilion versions, all of them with “pre-release” so it didn’t inspired me much confidence that they were stable, and they don’t match the numeration scheme on the pi forum post of a successful manjaro install previously linked
Sorry for the long post, but I don’t know what to do anymore, so I ask of you kind stranger: what is the best way to install manjaro on the pi 5 with ssd? is it the script? what should I change on it to create the correct partitions on my ssd? or I just shouldn’t have chosen file system ext4, I should have chosen btrfs or f2fs? is there a better way to install? which image should I download so I can use on the pi imager?
