Hello,
There is two package, by the same maintainer which seems to do the same thing in AUR repository : AUR (en) - Packages
What’s the difference. Are both needed to have the “typehead” feature enabled ? Are they doing the same thing ?
Thanks
Hello,
Thanks
looks like one is an extension to Nautilus
the other the whole file manager with that feature included
I don’t know that feature - but I’d hesitate to replace the whole program and try using the extension.
That is a split pkgbuild PKGBUILD - aur.git - AUR Package Repositories
it is a replacement for Nautilus and for libnautilus-extension, libnautilus-extension-typeahead isn’t an extension but is libnautilus-extension see that it provides and conflicts libnautilus-extension, libnautilus-extension.so
Nautilus is a split package in Arch and there too
Ok.
I don’t really understand what is a split package but still thanks for your answer.
A split pkgbuild (not a split package) is a pkgbuild that create 2 or more packages
You can see by it having pkgbase= + multiple pkgnames
pkgbase=nautilus-typeahead
pkgname=(
nautilus-typeahead
instead of only pkgname=nautilus (for example)
