Did Manjaro mirror remove archlinux-keyring?
Hi,
I am trying to fix many keyring issues to follow Manjaro Wiki
I downloaded Manjaro-keyring:
curl -O https://mirror.easyname.at/manjaro/pool/overlay/manjaro-keyring-20230719-3-any.pkg.tar.zst
It works.
But I didn’t find archlinux-keyring from the mirror. Was it already removed?
No. Any why are you downloading 1 year old keyring?
They’re all there:
Branch compare for Manjaro
Packages for query "archlinux-keyring" on x64 architecture.
1 results
Database last updated on: 2024-08-30 08:41:31.959349+00:00 (UTC)
archlinux-keyring
    stable    :20240709-1
    testing    :20240709-1
    unstable    :20240709-1
This is exactly what Manjaro Wiki says to follow the mirror https://mirror.easyname.at/manjaro/pool/overlay.
manjaro-keyring-20230719-3-any.pkg.tar.zst 2024-06-13 18:02 90K
It sounds like Manjaro Wiki is a bug.
Sound like you got manjaro-keyring and archlinux-keyring confused.
Why does Manjaro Wiki say I download archlinux-keyring?
I can’t see any bug. This is what I see on that page:
Use either your browser or curl to download. Using curl assumes you know the correct package name as located with the mirror. Replace YYYYMMDD-R as available from the mirror.
user $ curl -O https://mirror.easyname.at/manjaro/pool/overlay/manjaro-keyring-YYYYMMDD-R-any.pkg.tar.zst
user $ curl -O https://mirror.easyname.at/manjaro/pool/sync/archlinux-keyring-YYYYMMDD-R-any.pkg.tar.zst
Notice the difference? The archlinux-keyring is located in the /pool/sync/ folder, not the /pool/overlay/ folder.
Ah I did not notice the difference.
