I installed the dialect-git AUR, and it installed successfully.
When I try to run it, I get the following error.
File "/usr/local/share/dialect/dialect/main.py", line 45, in do_activate
self.window = DialectWindow(
File "/usr/local/share/dialect/dialect/window.py", line 99, in __init__
self.translator = Translator()
File "/usr/lib/python3.8/site-packages/googletrans/client.py", line 61, in __init__
self.client = httpx.Client(http2=http2)
File "/usr/lib/python3.8/site-packages/httpx/_client.py", line 590, in __init__
raise ImportError(
ImportError: Using http2=True, but the 'h2' package is not installed. Make sure to install httpx using `pip install httpx[http2]`.
I am running fully updated Manjaro Cinnamon. Is there a way to fix it without installing the package from pip?
I already have python-httpx installed.
@Yochanan Maybe the PKGBUILD needs to be updated? I did not comment in the AUR page because I don’t know if this is a Manjaro only issue, and people regularly write in the AUR comments section that Manjaro is off topic there.
Technically this isn’t an issue with Dialect. HTTP/2 support is optional for HTTPX. Notice it says,
python-h2 is an optional dependency of python-httpcore which is required by python-httpx which is required by python-googletrans which is required by dialect. See how that works?
