My dGPU is (maybe) always active after I updated my kernel from 4.19 to any 5.x kernel
I use Freon Extension in GNOME and I have activated my GPU temps and when I switch to 4.19 my gpu temps go and my laptop temps are in normal 45 degrees but with any 5.x kernel the temps are always persistent and the laptop temps are in high 60 to 80 when idle sometimes. This is affecting the battery life also. I am getting like 4 hours before with 4.19 but with any 5.x i get 1.5 hours.
Thank you for your help and time in advance.
System Info:
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 81HN v: Lenovo V130-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo V130-15IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 8VCN17WW date: 05/02/2019
ID-1: BAT0 charge: 26.1 Wh (100.0%) condition: 26.1/30.6 Wh (85.2%)
volts: 8.5 min: 7.6 model: CPT-COS L17C2PB3 type: Li-poly serial: <filter>
status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 7.12 GiB used: 3.23 GiB (45.3%)
RAM Report:
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check rev: A cache: L2: 6 MiB bogomips: 28800
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04ca:7070 class-ID: 0e02
Display: wayland server: X.Org 1.21.1.1 compositor: gnome-shell driver:
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 8086:3166 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: c000 bus-ID: 03:00.0
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-8:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.13 TiB used: 153.66 GiB (13.3%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WDS240G2G0B-00EPW0
size: 223.58 GiB speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000
scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DA8AESH rev: XL6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / size: 210.11 GiB used: 153.66 GiB (73.1%) fs: ext4 dev: /dev/sdb2
label: N/A uuid: e9cebb32-0da4-461b-a313-2d6077e5f85c
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sdb1 label: N/A uuid: 6AFD-AE9D
dev: /dev/sdb3 label: N/A uuid: 5e28faa4-bdc2-492c-8cfc-906809733835
ID-1: /dev/sda1 size: 232.83 GiB fs: ext4 label: HDD.Part1 Bkps
uuid: 6ba795dc-2154-4b2e-bb88-3e55ebd23235
ID-2: /dev/sda2 size: 7.45 GiB fs: swap label: swap
uuid: d7488ea0-db70-4f68-9f0e-e35530a0c752
ID-3: /dev/sda3 size: 465.85 GiB fs: ntfs label: HDD.Part3 Personal
uuid: 1A306D1F34155F53
ID-4: /dev/sda4 size: 225.38 GiB fs: ext4 label: HDD.Part4 PCBkp
uuid: 12032873-a888-4fbb-b4da-f5c523b559b4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-5:3 info: Lite-On Integrated Camera type: Video
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 64.0 C mobo: 60.0 C gpu: amdgpu temp: 64.0 C
Processes: 279 Uptime: 1h 25m wakeups: 23 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1496 pacman: 1489 snap: 7 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
EDIT: grammar and typos
