Devtools missing from Extra repo?
does anyone know why devtools is available in the Extra repo in Arch Linux but not in Manjaro Extra repo?
Just a speculation, but probably because it is pretty arch specific?
usr/bin/arch-nspawn
usr/bin/archbuild
usr/bin/archrelease
...etc...
There are some tools that will probably be useful for us here too, but i am pretty sure the package as a whole cannot work on manjaro without adaptation.
Well, I am working on a project and very much want to use updpkgbuild in my workflow, does anyone know if this is included in any Manjaro Packages?
Because Manjaro isn’t Arch linux. The Manjaro equivalents of this package are the manjaro-tools-base and manjaro-tools-pkg packages.
Several years ago before I joined the team, there was a Manjaro fork of devtools. That became manjaro-tools and manjaro-tools-pkg conflicts with devtools. That and some other Arch-specific tools are not included in the Manjaro repos.
What is updpkgbuild? The devtools package does not contain a script with that name and there is no package called that. You can see the file list here.
I found a couple references to a function named that using updpkgsums & makepkg like mentioned here.
OK, I think I am being led astray by Google, They keep referring to updpkgbuild as a script of devtools that updates the checksums and runs makepkg in one command, but clearly that does not exist.
Thank you all for helping me straighten this out.
There’s pkgctl version upgrade that seems close, but it doesn’t run makepkg.
❯ pkgctl version --help
Usage: pkgctl version [COMMAND] [OPTIONS]
Check and manage package versions against upstream.
COMMANDS
    check      Compares local package versions against upstream
    setup      Automatically detect and setup a basic nvchecker config
    upgrade    Adjust the PKGBUILD to match the latest upstream version
OPTIONS
    -h, --help    Show this help text
EXAMPLES
    $ pkgctl version check libfoo linux libbar
    $ pkgctl version setup libfoo
There is updpkgsums that can be used before makepkg
