Hello,
The device security feature is not translated in an other language than English in Gnome 43.x. Must we have to wait Gnome 44.x to have this issue solved ?
Thanks.
Hello,
Thanks.
What is the issue?
You think you described it - but I do not comprehend.
What is the “device security feature”?
Anyway if your issue is with GNOME translation, see upstream with them, Manjaro does not make GNOME translation as far as I know. TranslationProject - GNOME Wiki!
I contacted the Gnome translation team for French. They need to check the file for the Gnome control center.
