Since the last update, the HDD’s in Thunar are no longer in order. They are ordered, if I start Thunar from the Deskotp icon, the order is normal again. If I then start from the bar, the HDD’s are also in the correct order.
If I then open Thunar in the bar after the desktop Thunar, the HDD’s are also displayed correctly again. If I then go into a folder, then close Thunar and open it again, the order is messed up again.
With PCManFM this behavior is not to be found.
What can be done about it? Thunar still has the same version number as before the last update.
Translated with DeepL Translate: The world's most accurate translator (free version)
