Device not waking up from suspend
hey guys, I’m back in Manjaro after a couple of years and probably for the first time using it on a laptop. I have an Asus expertbook with intel i5 and xe graphics and I’m having a really bizarre issue. It doesn’t wake up after being suspended, let me be suspended because of inactivity or using the power menu or sytemctl suspend, it doesn’t wake up. I see that the keyboard lights gets turned on after i try to wake it up but no screen or any other kind of feedback, I need to hold the power button to turn it off and then turn it back on, this is really an inconvenience. Here’s the output of journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p":
Jan 09 12:26:35 mahdisLappy systemd[1]: Starting System Suspend...
Jan 09 12:26:35 mahdisLappy systemd-sleep[1942]: Entering sleep state 'suspend'...
Jan 09 12:26:35 mahdisLappy kernel: PM: suspend entry (s2idle)
As far as I understand there’s nothing abnormal here but again never really had to look into it.
Anyway, here’s the output of inxi -Fazy:
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=9194513e-ee19-4f46-a84e-94941b2a1902 rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
    UEFI: ASUSTeK v: B1500CEAEY.304 date: 11/15/2021
  ID-1: BAT0 charge: 41.0 Wh (99.0%) condition: 41.4/42.1 Wh (98.5%)
    volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: charging cycles: 8
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 2503 high: 3617 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1003 2: 2548 3: 1263
    4: 3543 5: 2400 6: 3254 7: 3617 8: 2400 bogomips: 38720
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-5:4 chip-ID: 13d3:56a2 class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: BOE Display 0x09cc built: 2021 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 28.3 GiB (5.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B00
    lanes: 4 type: SSD serial: <filter> rev: FXM7201Q temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 28.3 GiB (5.9%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 28.3 GiB (5.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2300
  Processes: 301 Uptime: 15m wakeups: 4362 Memory: 7.46 GiB
  used: 3.12 GiB (41.8%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1358
  pm: pacman pkgs: 1341 libs: 356 tools: gnome-software,pamac pm: flatpak
  pkgs: 17 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
Let me know if there’s any other info I can provide.
Hi and welcome to the forum :+1:
Try output of journalctl --grep “(suspend|resume)” which should show more…
Plus regarding s2idle see: Search results for 's2idle ACPI BIOS' - Manjaro Linux Forum
Thanks, @TriMoon, I guess I should have done more searching before posting here. This solved the issue for me:
