Today I decided to reapply thermal paste on my dell gaming notebook (here we go…). After doing so successfully I tried booting my linux installation which is in my main SSD and I get an error
ERROR: device 'UUID=some-uuid-in-here' not found. Skipping fsck.
mount: /new_root: can't find UUID=some-uuid-in-here.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
Most solutions are related to chrooting to the drive from a live usb. However, I can`t seem to find my SSD drive anywhere from this live boot. Even though the BIOS finds it and tries to boot, it also gets warm so it is definitely connected.
[manjaro-gnome manjaro]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> ERROR: No Linux partitions detected!
The only weird thing that happened when reassembling the laptop was that it took a while for it to boot up again, it seems to be related to the motherboard battery or something. Any other ideas I can try?
If it’s worth anything, everything worked fine before disassembling.
Its possible manjaro-chroot automation is not smart enough for whatever happened with your partition configuration.
Take a look at things (gparted, lsblk, etc) and verify the path you need to use, and attempt chroot by hand…
Where sda is my HDD and sdb is my current USB stick. The other ones I’m not sure what they are, however none of them seem to be my SSD. Gparted shows the same devices. Just to give more info, I ran fdisk -l:
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: TOSHIBA MQ02ABD1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 7DE73988-776C-4CA6-98CE-FFF6995AE9A1
Disk /dev/sdb: 7.45 GiB, 8002732032 bytes, 15630336 sectors
Disk model: Cruzer Blade
Disklabel type: dos
Disk identifier: 0x00000000
Which TOSHIBA MQ02ABD1 is indeed my HDD.
Is it possible that the SSD is faulty even if BIOS is still able to find it and try to boot from it? What else can I try to do to find it?
Edit: I’m not sure if its worth anything, however I can’t find anything like nvme (I guess this is how it would show up?) in /etc/.
In the output above it shows manjaro-chroot trying to use sdb (your live usb) … so it never attempted on sda (your hdd) ,
So manual will be the next step, but what to do depends on filesystem … which isnt shown.
Please refer to the wiki.
To list partitions with uuid and filesystem you can use
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
And manual chroot instructions are
Manual chroot
(Unnecessary if you have used manjaro-chroot) Mount the partitions using the designated temporary mountpoint and always start with root
root # mount /dev/sdyC /mnt
Info
### With a BTRFS filesystem, you should note that the subvolumes must be mounted. That would be in such a case: root # mount -o subvol=@ /dev/sdyC /mnt ###
Then - if applicable - mount boot
root # mount /dev/sdyB /mnt/boot
Then - if applicable - mount efi
root # mount /dev/sdyA /mnt/boot/efi
Create the chroot environment and use bash as shell
root # manjaro-chroot /mnt /bin/bash
From there you should be able to get in and check/edit /etc/fstab
Ok, that error makes more sense now. However, I’m not sure if manjaro-chroot would search sda since there is no linux partition on my HDD, it is empty at the moment.
I believe I can follow these instructions once I can find a way to reach my SSD, which contains my linux partition. I just don’t understand how my PC tries to boot from it but I can’t find it in manjaro.
Edit: in the emergency shell, running blkid it only shows only SDA and SDB. No nvme as well… How is this possible?
Don’t worry! I’m glad to just have someone to even talk to at this moment
It shows up as a UEFI boot option and now I’ve tried to boot from a windows installer and it identifies two storage units, one with 931.5GB which is my HDD and another with 936.5GB which I believe would be my SSD (I’m not sure how to get more information about the unit in this case).
This means the unit is working, right? Maybe it’s some kind of firmware issue on my SSD? I’m really confused.
Managed to have it boot!!! Hooray! I’ve found another post about windows finding an SSD and Linux not finding it. Turns out my MB for some unknown reason changed the SSD to run in RAID mode, when it should be in AHCI. This did the trick.
Thank you so much for helping me in troubleshooting this issue, cscs!!
