+++THE OLD ISSUE IS NOT FIXED, BUT I HAVE A NEW ONE+++
I wanted to install Ventoy to reset my Lenovo, which is also infected with malware, or to install Windows and update the bios or Uefi, but since then my Manjaro system on the HP no longer recognizes USB sticks, hahahaha.
At first I used an unnecessary number of commands…I know:
sudo pacman -Syu
sudo pacman -Syyu
sudo pamac checkupdates -a
sudo pamac upgrade -a
sudo pacman -S archlinux-keyring manjaro-keyrin
sudo pacman-key --populate archlinux manjaro
Subsequently:
sudo pacman -S ventoy
sudo sed -Ei '/EnableAUR/s/^#//' /etc/pamac.conf
pamac build ventoy-bin
USB ports no longer work…
So I tried to uninstall Ventoy:
sudo pacman -Rns ventoy
pamac remove ventoy-bin
pamac remove -o
pamac clean -uv -k 0
pamac clean -v -k 2
Well, that didn’t help. The USB ports still no longer work.
+++with regard tot the old issue+++
inxi --admin --verbosity=8 --filter --no-host --width ✔
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=d09e29bc-fe35-47d7-9a72-f7d615f43ec3 rw quiet splash apparmor=1
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 845 G7 Notebook PC v: N/A
Mobo: HP model: 8760 v: KBC Version 07.2C.00 serial: <superuser required>
part-nu: 39Y44UC#ABB uuid: <superuser required> UEFI: HP v: S77 Ver. 01.02.03
date: 11/27/2020
ID-1: BAT0 charge: 37.1 Wh (98.7%) condition: 37.6/53.2 Wh (70.7%)
volts: 12.4 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 361
System RAM: total: 8 GiB available: 7.1 GiB used: 4.01 GiB (56.6%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: HP32D4S2S1ME-8 firmware: HP32D4S2S1ME-8 serial: <filter>
Device-2: Bottom-Slot 2(right) type: no module installed
Info: model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1397 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
bogomips: 50325
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,eDP-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 45.0 C
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Lenovo P27h-20 serial: <filter> built: 2020
res: 2560x1440 dpi: 108 gamma: 1.2 chroma: red: x: 0.663 y: 0.329 green:
x: 0.298 y: 0.616 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
size: 609x349mm (23.98x13.74") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 1440x480, 800x600,
720x576, 720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 18.1.8 DRM 3.54 6.5.13-7-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no display-ID: :0.0
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Hewlett-Packard driver: N/A pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 238.47 GiB used: 212.01 GiB (88.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 212.01 GiB (90.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d09e29bc-fe35-47d7-9a72-f7d615f43ec3
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 100A-4A48
Device-1: 1-2:11 info: Lenovo Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 17ef:608d class-ID: 0301
Device-2: 1-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 1-4:13 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:00df class-ID: ff00 serial: <filter>
Device-1: 3-2:17 info: Logitech Keyboard K120 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
System Temperatures: cpu: 64.5 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1347 libs: 378 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
3: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
5: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
6: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
8: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
9: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
10: https://mirrors2.manjaro.org/stable/$repo/$arch
11: http://mirror.fcix.net/manjaro/stable/$repo/$arch
12: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirrors.manjaro.org/repo/stable/$repo/$arch
14: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
16: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
17: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
18: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
19: http://manjaro.grena.ge/stable/$repo/$arch
20: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://mirror.funami.tech/manjaro/stable/$repo/$arch
23: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
26: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
27: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
30: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
31: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
32: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
33: https://manjaro.ynh.ovh/stable/$repo/$arch
34: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
35: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
36: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
37: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
40: https://manjaro.kurdy.org/stable/$repo/$arch
41: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
43: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
44: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
46: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
47: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
49: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
50: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
51: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
52: https://mirror.easyname.at/manjaro/stable/$repo/$arch
53: https://mirror.init7.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 334
1: cpu: 13.0% command: gnome-shell pid: 1841 mem: 974.3 MiB (13.4%)
2: cpu: 12.0% command: firefox pid: 87336 mem: 531.9 MiB (7.3%)
3: cpu: 7.0% command: firefox pid: 88705 mem: 226.9 MiB (3.1%)
4: cpu: 6.5% command: soffice.bin pid: 82064 mem: 398.5 MiB (5.4%)
5: cpu: 3.9% command: gnome-terminal-server pid: 89528 mem: 60.4 MiB (0.8%)
Memory top: 5 of 334
1: mem: 974.3 MiB (13.4%) command: gnome-shell pid: 1841 cpu: 13.0%
2: mem: 531.9 MiB (7.3%) command: firefox pid: 87336 cpu: 12.0%
3: mem: 398.5 MiB (5.4%) command: soffice.bin pid: 82064 cpu: 6.5%
4: mem: 226.9 MiB (3.1%) command: firefox pid: 88705 cpu: 7.0%
5: mem: 192.4 MiB (2.6%) command: firefox pid: 87589 cpu: 2.7%
Processes: 334 Power: uptime: 4h 42m states: freeze,mem,disk suspend: s2idle
image: 2.83 GiB services: gsd-power,upowerd Init: systemd v: 256
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.36
Its pretty obvious:
https://en.wikipedia.org/wiki/420_(cannabis_culture)
What are the odds? Should play Lotto.
