When you have an system monitor widget on your desktop to monitor memory, and want to manually set the Y range.
The input box only accepts values upto 99.999 which is in KB, ~97,6552734375MiB.
This ofcourse is nowhere near usable as most systems have memory in the ranges of GiB.
The automatic Y-Range is also flawed because it makes the chart too short because it uses a max value that is like 2x the available memory.
Ohh ok ill try there then, i thought the gadgets were separate…okay…
edit:
Damn their system is sooo unfriendly with all their categories, there aint nothing for gadgets…ill try to post it in “some” category then…
