Hello,
I came back to my computer a few minutes ago, and it displayed on the screen that I had to go to tty and enter loginctl unlock-session 2
, and I did so. A torrent wasn’t working for me, so I restarted my computer, and now whenever I log into my account, the desktop and taskbar turn black, although the cursor is visible. However, when I log into the root account, it works normally.
Here’s my inxi dump:
Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=14240bb8-bf84-482f-b273-cb482cd440ec rw rootflags=subvol=@ quiet
cryptdevice=UUID=c7894bef-22f0-439b-80a2-ace067589e9b:luks-c7894bef-22f0-439b-80a2-ace067589e9b
root=/dev/mapper/luks-c7894bef-22f0-439b-80a2-ace067589e9b splash
udev.log_priority=3 split_lock_detect=off
Desktop: KDE Plasma v: 5 tk: Qt v: 5.15.12 info: frameworks v: 5.115.0
Type: Desktop System: Dell product: OptiPlex 3010 v: 01
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Dell model: 042P49 v: A01 serial: <superuser required>
part-nu: OptiPlex 3010 uuid: <superuser required> UEFI: Dell v: A22
date: 11/29/2018
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 1600/3200 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 25549
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner / Sapphire driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 42.0 C
Display: x11 server: X.org v: 1.21.1.11 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0
Monitor-1: DP-2 model: Viewteck GFV24C built: 2019 res: 1920x1080 dpi: 92
gamma: 1.2 size: 530x280mm (20.87x11.02") diag: 599mm (23.6") modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi inactive: gbm,wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.0.2-manjaro1.1
note: incomplete (EGL sourced) renderer: AMD Radeon RX 470 Graphics
(radeonsi polaris10 LLVM 16.0.6 DRM 3.49 6.1.80-1-MANJARO), llvmpipe (LLVM
16.0.6 256 bits)
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: C-Media TONOR TC-777 Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.3:4 chip-ID: 0d8c:0134 class-ID: 0300
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active (process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Info: services: NetworkManager
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3:3 chip-ID: 0bda:8771
Supported mdraid levels: raid0
Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 976224256 chunk-size: 64k
Components: Online:
0: sdb maj-min: 8:16 size: 931.51 GiB
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 538328 chunk-size: N/A
Components: Online: N/A Spare:
0: sdb maj-min: 8:16 size: 931.51 GiB state: S
Local Storage: total: raw: 1.56 TiB usable: 670.19 GiB used: 97.4 GiB (14.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0BB3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA722010CLA330
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3EA
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 183.23 GiB size: 183.23 GiB (100.00%)
used: 57.72 GiB (31.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c7894bef-22f0-439b-80a2-ace067589e9b
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 40.04 GiB size: 40.04 GiB (100.00%)
used: 39.68 GiB (99.1%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-81477fea-6b10-4c5f-8805-2b84f2b02142
ID-4: /var/log raw-size: 183.23 GiB size: 183.23 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1721
Memory: total: 16 GiB available: 15.59 GiB used: 2.34 GiB (15.0%)
Processes: 259 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1527 pm: pacman pkgs: 1520 libs: 452 tools: pamac,yay pm: flatpak
pkgs: 7 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash (su) v: 5.2.26
running-in: konsole inxi: 3.3.33
Any help would be greatly appreciated. Thanks in advance.
