Hey guys, I noticed my desktop won’t hibernate nor sleep (when I try, it goes to a black blinking cursor screen and then it just comes back on). I got the uuid flag and everything together (I had manaully partitioned a 17.58G pool for swap on my hard drive when I first installed the OS in the gui installer). Anyone have any idea why my system won’t hibernate or suspend?
Here’s my system information.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=64815fb7-95cc-405b-8c37-8241d87e7deb rw quiet apparmor=1
security=apparmor resume=UUID=86f7406f-38b2-40f1-aafa-d124261e8d7a
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7B79 v: 1.0 serial: <filter>
Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: 1.I2 date: 02/03/2021
Device-1: hidpp_battery_0 model: Logitech M310 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.62 GiB used: 8.88 GiB (56.8%)
Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 86429
Speed: 2700 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2700 2: 2016 3: 2191 4: 2196 5: 3207 6: 2197 7: 2199 8: 2129 9: 2408
10: 1984 11: 3394 12: 2200
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 27:00.0 chip-ID: 10de:1c03
class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: DP-2.8 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-12:2 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: f000
bus-ID: 24:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp36s0 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
bus-ID: 1-14:4 chip-ID: 8087:0a2b class-ID: e001
Message: No LVM data was found.
Local Storage: total: 1.14 TiB used: 152.79 GiB (13.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 61.2
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00WN4A0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST j rev: 1.01
dev-links: cdrom
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 39.44 GiB (16.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 64815fb7-95cc-405b-8c37-8241d87e7deb
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 212A-B15F
ID-3: /home raw-size: 913.93 GiB size: 898.51 GiB (98.31%)
used: 109.86 GiB (12.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 5511a3cb-a10a-4727-85bb-735087178938
ID-4: /home/<filter>/gdrive raw-size: N/A size: 15 GiB
used: 3.48 GiB (23.2%) fs: fuse.rclone source: ERR-102 label: N/A uuid: N/A
ID-5: /home/<filter>/mega raw-size: N/A size: 50 GiB used: 14.21 GiB (28.4%)
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 86f7406f-38b2-40f1-aafa-d124261e8d7a
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 1-12:2 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Device-2: 1-13:5 info: Cyber Power System CP1500 AVR UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 50mA chip-ID: 0764:0501 class-ID: 0300
Device-3: 1-14:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Realtek RTS5411 Hub ports: 2 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Hub-5: 3-1.1:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.1.1:4 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-2: 3-1.1.2:5 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-1:2 info: Realtek Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.5 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 366 Uptime: 27m wakeups: 2 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1411 lib: 375 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
