Desktop opacity %0
Hello, when trying to tweak some of my window rules in the system settings, I have accidentally ended up with my desktop opacity set to 0% meaning I only see a black screen with the cursor.
I remember changing Active & Inactive opacity but accidentally left both at 0% and did not double check before applying.
I am able to open the terminal and execute commands but I can’t see any output so that’s about it.
Is there any way to reset the window rules from the terminal mayhaps?
Thanks
Hi there & welcome.
I don’t use KDE but the following post suggests looking here - ~/.config/kwinrulesrc
I don’t know if it will help in your case but have a look & all the best!
Ruziel :slight_smile:
