Manjaro starts up and then im on desktop but cant move my mouse and hitting the windows key doesnt do anything either. This is after I just turned off my computer.
For interactivity:
For sharing/finding/formatting info:
For pastebin from command line if needed:
https://forum.manjaro.org/t/howto-use-public-command-line-pastebin-services-without-installing-anything/38378
Oh nevermind now it works?? Third restarts the charm this is inexplainable.
What? I started my program adn then it frose again
Problem is I cant login to my tty. I have a usb boot ready so I can try that ig.
I can for example open htop for like 10 seconds then it ig crashes
It might be fine enough to boot into runlevel 3. Maybe.
You can also use the live USB to chroot (rather manjaro-chroot) in.
manjaro-chroot doesnt work
Cant create chroot on non directory
Should I try to boot into runlevel 3? Idk how to od it but I can search it.
Manjaro chroot a works
Ill run sudo pacman syu
Did you not look at any of the links ?
Failed to synchronise Unable to lock databases
Isk how to get into grub
Grub is the thing you see after turning on the computer.
Where you select the kernel.
The guide also has this bit in the case of ‘hidden’ grub:
Idk when to press esc or shift. To choose my kernel I usually just press f12 but rn the key is broken so i have to go to bios and change the priority.
…And thats your BIOS, not GRUB.
When you select manjaro there … the first thing it will do is launch grub.
You would try to hit Esc then, directly after starting.
If that doesnt work … there would be ways to augment the grub configuration file so that it is not hidden … but if your system does not function for more than a few seconds that is not viable either.
So you will need to use the live usb I suppose.
Heres a bunch of chroot instructions:
I never had grub so why would I want to restore it
Links have more information than just whatever you can read on the title.
Please learn to follow them when they are provided.
And you have grub … even if you dont know what it is.
There are technically other bootloaders … but since its all a mystery to you … it is grub, because thats the default.
I dont know what you are trying to show because that video is private.
But I would probably bet that instructions to do chroot and how would be the same and are still available at the wiki link above.
And so it will remain (or get worse) until you start reading the links provided, and following the good advice from @cscs
(Wisdom lies in asking → listening → reading
They say to chrrot but as I said chroot isn’t working.
~ manjaro-chroot -a ✔
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda5]
--> mount: [/mnt]
mount: /mnt: /dev/sda5 already mounted on /mnt.
dmesg(1) may have more information after failed mount system call.
--> mount: [/mnt/boot/efi]
[manjaro /]# pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
[manjaro /]# mount /dev/sdyC /mnt
mount: /mnt: special device /dev/sdyC does not exist.
[manjaro /]# grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sdy
Installing for i386-pc platform.
grub-install: error: cannot find a GRUB drive for /dev/sdy. Check your device.map.
[manjaro /]# pacman -Syu grub
core is up to date
extra is up to date
warning: grub-2.12-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) grub-2.12-3
Total Installed Size: 47.86 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [####################################] 100%
(1/1) checking package integrity [####################################] 100%
(1/1) loading package files [####################################] 100%
(1/1) checking for file conflicts [####################################] 100%
(1/1) checking available disk space [####################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling grub [####################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(3/3) Updating the info directory file...
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.19-x86_64.img
Found initrd fallback image: /boot/initramfs-5.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
[manjaro /]# pacman -Syu install-grub
core is up to date
extra is up to date
Packages (1) install-grub-2.12-3.10
Total Download Size: 0.02 MiB
Total Installed Size: 0.01 MiB
:: Retrieving packages...
install-grub-2.12-3.10-x86_64 22.7 KiB 26.0 KiB/s 00:01 [####################################] 100%
(1/1) installing install-grub [####################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
[manjaro /]#
He isnt replying and the guide isnt working idk what to do if u could help that be much appreciated
. Sorry for disturbing if not.
