Deepin seems to be in a broken state. In order for me to have the dock, i actually have to restart the WM with deepin-wm --replace &
otherwise i have just an empty desktop and i can access the right click menu only.
GTK+ apps have no title bars, nor window decoration to resize them, and Qt apps are inmutable …
Unless there is a known issue upstream and a fix there, i don’t see how you could.
Well … talk to deepin. Its basically always broken, always has been, and their releases are a bit chaotic.
Also - dont expect much. Even though its ‘open source’ they dont seem to put a high priority on transparency or interaction.
If none of that, or the bugs that come with it, are acceptable to you … you should use a different DE.
This is not true! I have been using Manjaro DDE for more than a year now … and the experience has been good. It is true that the 20211120 updates broke DDE but the fix above makes things usable again.
What I had to do …
sudo pacman -S deepin-wm
then run
I also ran
sudo deepin-wm --replace &
Thanks to bogdancovaciu for the advice!
Below is what terminal spews when the deepin-wm --replace & is given … maybe this can help someone find the bug
It is a community edition, so I expect that someone checks, that a major update don’t break the system. I don’t know why you blame the deepin team in this case. I know about the history that at some point manjaro discontinued deepin, but now its back at least as a community edition. I see its not an official edition, but after installing XFCE edition first I decided that this is really ugly in many respects and that I take the risky road again. Since deepin-wm is officially discontinued we need another solution.
Noob question, is it possible to temporary roll back as workaround? If possible can you give some directons? Many thanks, next time will read before updating
I had the same issues above, and tried multiple restores with Timeshift - the earliest snapshots did not solve the issue however one saved just before latest update when things broke worked - I lost quite a bit of set up (new machine) as I have been trying to find a working system of safety and convienience. Unfortunately Timeshift does not appear to support NAS or network locations - so I only had limited local drive space and it fills up quickly with daily and weekly snapshots. But Yes rolling back to a previous snap shot saved me.
I wonder which package is to blame. It seems to me that the basic deepin stuff has not changed with the update, neither lightdm. So how can this happen? The deepin-wm solution may stop working soon, as the package is deprecated.
Then you fundamentally misunderstand what a community edition is.
It does not mean manjaro supported.
It just means that someone from the community whipped up an ISO using manjaro without fundamentally changing the base structure or packaging system etc.
new update on deepin or any manjaro stuff today
but deepin is still ■■■■■■■ broken THX
sry but frustraded that its al broken i do like deepin
gezz have too get use to mabox
Fui a: ~/.config/autostart y marqué “Deepin Window Manager” y tildé “Ejecutar como programa”.
-No es un descubrimiento, es el resúmen de lo que aquí se ha dicho. Gracias a todos.
PD. No he logrado cambiar el fondo de pantalla…
Thank you CSCS, I had a simple question implicit in my post - trying to find a working (arch based) system… I use a few key applications, Appimages, have recent hardware, and two 4K monitors, as well as normal ancillaries like printers etc, and on about 20 different distros, Deepin Manjaro was the only one that worked for me. A rolling or semi rolling release was also on my wish list.
I am a Noob, don’t wish to spend most of my time fighting with the terminal to get things done, Deepin worked out of the box for me - rarely does that happen for me.
