Hello folks,
writing on my phone, so I’m sorry if formatting is off.
I, stupid as I am, force shutdown(pressing the power button until computer turns off) my computer the other day. Now booting up is relatively normal speed wise but once I log into my user account, it takes longer than normal. Also the loading screen is still showing when an autostart app opens. Feels like it hangs after the loading bar reached 100%
The other problem is that my desktop icons “disappeared”. They are still in the desktop folder but they don’t show up on my desktop
I checked an “Layout: Folder View” is still active.
Also all icons in my taskbar don’t do anything. The loading symbol appears but the app won’t open. The icons of the application launcher don’t work either.
What works though is using Runner to open settings for example. Konsole works too to open things.
I wanted to upload a picture of the errors using journalctl -p3 -b but unfortunately I’m not allowed to:(
Thanks for the help!
PS.: Sorry for forgetting my specs!
Here are my specs using the command that Andreas suggested
[My specs on pastebin](System: Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 - Pastebin.com
You need to give some general info like:
What Desktop do you use ? KDE / Gnome / XFCE …
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information.
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to form…
Have you already for your problem in the forum ? (Wisdom lies in asking → listening → reading )
Tip for the future:
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
Difficulty: ★★☆☆☆
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to “Power Off” or “Hard Reset” their system without doing a REISUB, please send them here!
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial…
cscs
8 August 2023 18:20
3
Does the desktop behave the same with a new user?
Good question!
I just created a new user and there the desktop and taskbar etc seem to work just fine.
So maybe some bad config?
Sounds like you may have this issue:
Complete Linux noob here.
I started my computer after it was completely shut down, and I can log in fine but nothing will launch. I can’t launch konsole, dolphin, firefox, anything at all with the exception of the Add/Remove Software gui. I get no error messages, I click icons and get the spinning circle and then it stops and nothing further happens. At most I can right click my desktop and open desktop settings. I’ve shutdown completely, restarted, put into sleep, hard shut down, and nothing h…
The marked Solution will help if this is your issue.
cscs
8 August 2023 19:18
6
I was pretty much going to suggest what @jcorporon sorta-linked …
Continuing the discussion from KDE Plasma Completely dysfunctional :
Though of course you could backup the Trolltech file and/or the .cache folder instead of just deleting them.
And do note that it will remove your desktop configurations - you will have to set things again.
(or move back the files)
