As in the topic after the last update all icons from the desktop will disappear.
In your Applications there is an accessory called “Extensions”
Make sure the Desktop Icons Extension is enabled. Recently it was renamed to Gtk4 Desktop Extensions NG, so it might just need turning on again,
Thank you for your help. Enabling the extension solved the problem.
