Hi everyone!
I’ve installed Manjaro a few days ago and have been trying to make it work top notch since then.
I have an issue of sluggish performance in the desktop environment (happened with Gnome and KDE) and with 4k videos (especially on the web through web browser). I have a Dell XPS 15 9570 with both integrated intel GPU and Nvidia 1050ti, so I have read this is usually a potential cause of trouble. Following is my inxi output after running sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.134-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=06c15e00-c925-4d29-bab1-e8b1ad586452 rw quiet splash apparmor=1
Console: tty pts/0 wm: gnome-shell DM: GDM 40.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 02MJVY v: A00 serial: <filter> UEFI: Dell v: 1.19.0
date: 03/16/2021
ID-1: BAT0 charge: 41.2 Wh (78.8%) condition: 52.3/97.0 Wh (53.9%)
volts: 12.1 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Unknown
RAM: total: 15.28 GiB used: 2.85 GiB (18.7%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A size: 8 GiB speed: 2667 MT/s type: DDR4 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: 802C0000802C
part-no: 8ATF1G64HZ-2G6E1 serial: <filter>
Device-2: DIMM B size: 8 GiB speed: 2667 MT/s type: DDR4 detail: synchronous
Info: 6-Core model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: EA cache: L1: 384 KiB
L2: 9 MiB L3: 9 MiB bogomips: 52815
Speed: 841 MHz min/max: 800/4100 MHz base/boost: 2277/4100 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 841 2: 838 3: 806 4: 805 5: 846
6: 837 7: 889 8: 839 9: 839 10: 840 11: 811 12: 840
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0bda:5657 class-ID: 0e02 serial: <filter>
Display: server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.134-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel port: 3000
bus-ID: 3b:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-4:3 chip-ID: 0cf3:e300 class-ID: e001
Local Storage: total: 476.94 GiB used: 67.07 GiB (14.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 80003E00 scheme: GPT
ID-1: / raw-size: 97.94 GiB size: 95.84 GiB (97.86%) used: 66.96 GiB (69.9%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 06c15e00-c925-4d29-bab1-e8b1ad586452
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 111.5 MiB (17.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: 5A6B-F68B
ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 363.37 GiB fs: ntfs label: OS
uuid: 1C2CB65F2CB6341C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 877 MiB fs: ntfs label: N/A
uuid: 247E29067E28D1FA
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 12.88 GiB fs: ntfs label: Image
uuid: 7636D61936D5DA67
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.14 GiB fs: ntfs
label: DELLSUPPORT uuid: 2890CB0190CAD50A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
Device-3: 1-7:4 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-4: 1-12:5 info: Realtek Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2496 fan-2: 2523
Processes: 284 Uptime: 9m wakeups: 694 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1268 pacman: 1265 lib: 327
flatpak: 0 snap: 3 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.06
And here are the information I have gathered through some testing :
- Both graphics cards work fine, I have tested with glxgears (with primer-run for nvidia card) and I have successfully played a video game with steam + proton (which is amazing btw, glad there is finally a solution to linux gaming). The game was mirror’s edge (first) so it was definetly running nvidia or it would not have been smooth at all, but here I had a really smooth experience.
- It is not specific to KDE or Gnome, I installed first KDE, then did a complete reinstall with Gnome (and updated which brought me to gnome 40), and have the same issue
- I have tested switching from x11 to Wayland, even though it seems like it is not recommended on Nvidia cards, but I have read that with newer driver it is getting better. I would say the problem is still there, but maybe it is slightly better with Wayland for the desktop smoothness (though so little that I am not sure) but no noticeable improvement with 4k videos.
- Playing 4k video with VLC is smooth with nvidia graphics card (running prime-run vlc), still sluggish with integrated graphics, though I don’t know if it is capable of it. However, It’s better if I play full screen on Wayland or I have some diagonal screen tearing.
- I have tried using chromium instead of firefox, but it is not better.
- I have tried 3 different kernels, 5.10.52-1; 5.13.4-1; 5.4.134-1. Problem still persists.
- On KDE I had the problem with both free and non-free drivers, I haven’t tested free drivers on Gnome.
And now I am here, because I am short on ideas and quite unexperienced with linux. I would appreciate some help troubleshooting this. If possible with detailed explanation to help me learn (but if not possible I’ll take all the help I can get
Best regards
