Desktop environment doesn't start up after switching to a AMD Radeon 3700 XT
I’m going to start this out by mentioning that I previously had an Nvidia GPU.
I now have a new GPU, but now when I start my PC, I only get this:
/dev/sdb2: recovering journal
/dev/sdb2: clean, 2770081/28712960 files, 92343931/114828068 blocks
I have tried looking for a solution for this
https://www.reddit.com/r/ManjaroLinux/s/yEaJ49E3ef
But this did not work.
Thx in advance :slight_smile:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in asking → listening → reading :wink: )
I cannot send you this output. I am currently in my shell. If I was able to send output here I would’ve.
(Also I know you probably copy that text but it comes off as extremely patronizing)
If possible, try to use a live-manjaro :wink:
You even can compare the inxi from there, with the inxi you get now from tty.
(or even better post both)
:footprints:
Most people don’t say how familiar they are with:
  • TTY
  • Formatting in a forum
  • English (some posts are poorly translated)
  • Linux at all
    Or:
  • what they have already tried
  • what they did before the problem arose :wink:
It is possible to retrieve this information individually. And you will find threads that have >100 posts because important information was missing at the beginning.
Therefore, the “demand” for information is necessary so that anyone who reads it can see if they can help you in any way. (also translated :wink: )
I am open to any suggestion that would make the text more acceptable. However, I can’t change anything in the linked posts :wink:
here it is
  Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_GNOME_2213 quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 1.0
    serial: <filter> UEFI: American Megatrends LLC. v: A.50 date: 01/15/2021
  System RAM: available: 7.68 GiB used: 2.22 GiB (28.9%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 type: no module installed
  Device-2: DIMM 1 type: no module installed
  Device-3: DIMM 0 type: no module installed
  Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3000 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: BL8G30C15U4B.M8FE1
    serial: <filter>
  Info: model: AMD Ryzen 5 3500X socket: AM4 bits: 64 type: MCP arch: Zen 2
    gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 2433 high: 3600 min/max: 2200/4120 boost: enabled
    base/boost: 3600/4100 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 3600 4: 2200
    5: 2200 6: 2200 bogomips: 43215
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 2d:00.0
    chip-ID: 1002:73df class-ID: 0300
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: DP-3 model: 27E1Q serial: <filter> built: 2021 res: 2560x1440
    hz: 60 dpi: 108 gamma: 1.2 size: 600x330mm (23.62x12.99") diag: 685mm (27")
    ratio: 16:9 modes: max: 2560x1440 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 6700 XT (navi22
    LLVM 15.0.7 DRM 3.49 6.1.30-1-MANJARO) direct-render: Yes
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.36 TiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    family: BarraCuda 3.5 (CMR) size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC43 temp: 40 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 347d 20h cycles: 529
    read: 47.36 TiB written: 62.6 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8480G
    family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 62B3 temp: 40 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 345d 14h cycles: 529
    read: 74627 GiB written: 29316 GiB
  ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
    size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
    scheme: MBR
  Optical-1: /dev/sr0 vendor: MATSHITA model: DVD-RAM SW830 rev: 1.00
    dev-links: cdrom
  Message: No partition data found.
  ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: steam
    uuid: 8429e1cf-59ff-4c60-8719-afef771111fb
  ID-2: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: NO_LABEL
    uuid: 61E7-70C5
  ID-3: /dev/sdb2 maj-min: 8:18 size: 438.03 GiB fs: ext4 label: N/A
    uuid: 1ac35c4b-154d-4d98-94b4-2d5193b3401e
  ID-4: /dev/sdb3 maj-min: 8:19 size: 8.8 GiB fs: swap label: N/A
    uuid: 10f62d63-c416-461c-9990-b380d99d2019
  ID-5: /dev/sdc1 maj-min: 8:33 size: 3.45 GiB fs: iso9660
  ID-6: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: D0A3-C7FC
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-2.3:4 info: SINOWEALTH Game Mouse type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 256mA chip-ID: 258a:1007 class-ID: 0301
  Device-2: 1-2.4:6 info: Microdia USB DEVICE type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:7698 class-ID: 0301
  Device-3: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
    serial: <filter>
  Device-4: 1-10:5 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 53.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
    mem: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 272 Uptime: 1m wakeups: 0 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1240 libs: 315 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.27
Please I really need help
I can’t do much for you since graphics cards are not my area of expertise
(I’m afraid it could get worse :wink: )
And all the people here help in their free time. Therefore, you may have to wait for someone to sign up who can help you.
In the meantime, you can re-read what has already been posted and linked, or you can try using forum search.
:footprints:
Hello @mattus,
did you install/uninstall/change graphic drivers before you change the gpu’s?
Normally if you still can login you can try to install the drivers with 'mhwd’ like discribed in the wiki.
This should install the right (nonfree) drivers:
sudo mhwd -a pci nonfree 0300
If you want to use the free drivers change 'nonfree’ to 'free'. This is what I would try at first. :slightly_smiling_face:
You can also save command output to a file from within a TTY.
Here is an example:
sudo inxi --admin --verbosity=7 --filter --no-host --width > ~/output.txt
Notice the > ~/output.txt at the end? This effectively redirects the output that would have been printed to screen, to the named text file instead. In this way you can take that file and post the content later, any way you see fit.
The drivers seem to be installed already,
I get the result:
> Skipping already installed config 'video-linux' for device: 0000:2d:00.0 (0300:1200:73df) Display controller in ATI Technologies Inc Navi 22 [Radeon RX 6700/6700 XT / 6800M]
There is a recent thread Switch from Nvidia gpu to Amd gpu basically on the same topic that might be helpful.
I have now made progress and it’s booting but stops at
Starting Hold until boot process finishes up...
Starting Terminate Plymouth Boot Screen...
post pic of:
mhwd -l -li
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
it didnt detected any available drivers… check again with:
mhwd -l
and:
inxi -G
so you are in chroot? so you can normally boot into manjaro live usb?
post output also from:
mhwd-kernel -li
and:
pacman -Qm
and if you can provide normal text output …
Plymouth is unnecessary and can often cause boot issues. I suggest you uninstall it according to the instructions at Plymouth Manjaro under the heading Removal. Cheers.
Aside:- Once you’re up and running again, you might like to take a look at RustDesk as an alternative to anydesk-bin.
yeah, i am in chroot. I didn’t want to manually take photos of my screen.
Anyways, here’s the stuff:
sudo chroot /run/media/manjaro/1ac35c4b-154d-4d98-94b4-2d5193b3401e
[manjaro-gnome /]# mhwd-kernel -li
Currently running: 6.1.30-1-MANJARO (linux61)
   * linux419
   * linux510
[manjaro-gnome /]# pacman -Qm
android-emulator 33.1.23-1
android-sdk 26.1.1-2
android-studio 2023.1.1.26-1
anydesk-bin 6.3.0-1
archlinux-java-run 10-1
arcus 5.0.0-3
audiorelay 0.27.5-3
balena-etcher 2:1.18.13-1
breath2-wallpaper 1.0.18-5
cef-minimal 119.4.3-1
celt 0.11.3-6
cura 5.3.0-1
cura-resources-materials 5.6.0-1
curaengine 4.13.1-3
debtap 3.5.1-1
ebsynth-git r16.2f5c97c-1
electron19 19.1.9-5
electron7-bin 7.3.3-5
evince-no-gnome 44.1-1
gamemaker-beta 2023.200.0.299-1
gb-studio 3.1.0-1
gconf 3.2.6+11+g07808097-10
genymotion 3.5.1-1
gnome-icon-theme 3.12.0-7
gnome-icon-theme-symbolic 3.12.0-6
google-chrome 120.0.6099.71-1
gtk-theme-breath 5.9.0-1
jre 21.0.1-1
js78 78.15.0-4
libcpufeatures-git 0.7.0+15.r284.d20220617.3c4801d-1
libgbinder 1.1.35-1
libglibutil 1.0.74-1
libopenaptx 0.2.0-1
libsavitar 4.13.0-1
libsidplay 1.36.59-10
lxc-git 4.0.0.r2149.g2ac414d56-1
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
mcreator 2023.3.36712-1
minecraft-launcher 1:1.0.1221-1
multimc-bin 0.7.0.3809-1
noto-fonts-compat 20151217-1
opencolorio1 1.1.1-3
parsec-bin 150_86e-4
python-argparse 1.4.0-14
python-backcall 0.2.0-8
python-gbinder 1.1.2-1
python-mapbox-earcut 1.0.1-1
python-pep517 0.13.0-4
python-progress 1.6-8
python-pyglet 2.0.10-1
python-pyinstrument 4.6.1-1
python-pynest2d 4.12.0-1
python-sip4 4.19.25-5
python-svg.path 6.2-1
python-trimesh 4.0.5-1
qt5-webkit 5.212.0alpha4-20
rarcrack 0.2-6
sidequest-bin 0.10.38-1
steamcmd latest-3
substance-painter 8.1.3-1
systemd-fsck-silent 239-1
teamviewer 15.48.4-1
transcode 1.1.7-42
twitch-bin 1.0.4-8
uranium 5.0.0-2
urn-git r133.09c0756-1
visual-studio-code-bin 1.85.0-1
waydroid 1.4.2-1
waydroid-image-gapps 18.1_20231125-1
wine-gui-git 0.14alpha.54.gff60462-1
xclicker 1.5.0-1
xkb-switch 1.8.5-1
xp-pen-tablet 1:3.2.3.220323-3
yay-git 12.2.0.r1.g643830f-1
these are your kernels, they are older, so install a newer one, the 6.1:
pacman -S linux61
remove this:
pacman -R celt breath2-wallpaper manjaro-documentation-en manjaro-firmware
exit chroot and reboot…
