[skaboomatude@skaboomatude-pc Desktop]$ sudo inxi -Fazy
/usr/bin/inxi: illegal option – a
Error 7: One of the options you entered in your script parameters: -Fazy
is not supported.The option may require extra arguments to work.
For supported options (and their arguments), check the help menu: inxi -h
[skaboomatude@skaboomatude-pc Desktop]$ sudo parted -l
Model: ATA ST4000DM000-1F21 (scsi)
Disk /dev/sda: 4001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 135MB 134MB ext4
2 135MB 4001GB 4001GB ntfs Basic data partition msftdata
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sdb: 250GB
Disk Flags:
1 2098kB 317MB 315MB fat32 boot, legacy_boot, esp
2 317MB 232GB 231GB ext4 Main SSD boot, esp
3 232GB 250GB 18.3GB linux-swap(v1)
Model: ATA ST4000VX000-1F41 (scsi)
Disk /dev/sdc: 4001GB
Disk Flags:
2 317MB 4001GB 4000GB ext4
Model: ATA WDC WD40EFRX-68W (scsi)
Disk /dev/sdd: 4001GB
Disk Flags: pmbr_boot
1 1049kB 4001GB 4001GB ntfs 4tbdrive msftdata
Model: ATA WDC WD20EFRX-68E (scsi)
Disk /dev/sde: 2000GB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 2000GB 2000GB ntfs
Model: Generic Flash Disk (scsi)
Disk /dev/sdf: 2013MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 32.8kB 1706MB 1706MB primary boot
2 1706MB 1710MB 4194kB primary esp
[skaboomatude@skaboomatude-pc Desktop]$ sudo lsblk -fs
NAME FSTYPE LABEL UUID MOUNTPOINT
sda1 ext4 7636d0ba-f716-480f-8911-608911173be6 /run/media/skaboomatude/7636d0ba-f716-480f-8911-608911173be6
└─sda
sda2 ntfs Uber Mega Bad Ass Drive C2B60143B6013985 /run/media/skaboomatude/Uber Mega Bad Ass Drive
└─sda
sdb1 vfat 99BE-629F
└─sdb
sdb2 ext4 d3ae9244-6b18-4f52-a155-c3959a4844ef /
└─sdb
sdb3 swap ffd5119e-1e13-4172-a6d4-0c983de01ea7 [SWAP]
└─sdb
sdc2 ext4 95f33ce0-ed81-47d8-93b1-0c3978b9ffb7 /run/media/skaboomatude/95f33ce0-ed81-47d8-93b1-0c3978b9ffb7
└─sdc
sdd1 ntfs 6A421778561C27DE /run/media/skaboomatude/6A421778561C27DE
└─sdd
sde ntfs red 089FC59901AFE458 /run/media/skaboomatude/red
sdf1 iso9660 MJRO1705 2017-09-16-10-13-30-00 /run/media/skaboomatude/MJRO1705
└─sdf iso9660 MJRO1705 2017-09-16-10-13-30-00
sdf2 vfat MISO_EFI 7723-A0BA
[skaboomatude@skaboomatude-pc Desktop]$ sudo efibootmgr -v
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0002
Boot0001* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x14,0x0)/USB(10,0)/CDROM(1,0x32d884,0x8000)…BO
Boot0002* UEFI: Generic Flash Disk 8.07, Partition 2 PciRoot(0x0)/Pci(0x14,0x0)/USB(10,0)/HD(2,MBR,0xaa3126b4,0x32d884,0x2000)…BO
[skaboomatude@skaboomatude-pc Desktop]$ ^C
