hola a todos, me gustaria cambiar los drivers por los originales pero no se como hacer ese proceso o si se pueda ya que he estado experimentando sobrecalentamiento desde la ultima actualizacion de sistema aca la info:
neofetch
██████████████████ ████████ aaa@aaa-80e1
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: 80E1 Lenovo G40-45
████████ ████████ Kernel: 6.6.16-2-MANJARO
████████ ████████ ████████ Uptime: 31 mins
████████ ████████ ████████ Packages: 1161 (pacman)
████████ ████████ ████████ Shell: bash 5.2.26
████████ ████████ ████████ Resolution: 1366x768
████████ ████████ ████████ WM: i3
████████ ████████ ████████ Theme: Adapta-Nokto-Eta-Maia [GTK2/3]
████████ ████████ ████████ Icons: Papirus-Dark [GTK2/3]
████████ ████████ ████████ Terminal: urxvt
████████ ████████ ████████ Terminal Font: 9x15,xft
CPU: AMD E1-6010 APU with AMD Radeon R2 Graphics (2) @ 1.350GHz
GPU: AMD ATI Radeon R2 Graphics
Memory: 1009MiB / 6902MiB
mhwd -l --detail
> PCI Device: /devices/pci0000:00/0000:00:02.4/0000:02:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.09.12
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:01.0 (0300:1002:9853)
Display controller ATI Technologies Inc Mullins [Radeon R2 Graphics]
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
cscs
1 March 2024 00:05
2
AAA_AAA:
neofetch
inxi -Fazy
No hay nada más para elegir.
O hiciste algo más, como instalar los drivers manualmente?
Reinicie y se queda en pantalla negra que puedo hacer?
*Ya lo solucione *
había instalado 2 controladores de video de mas y los desinstale
No, realmente lo que quiero es el sobrecalentamiento ya que ha estado alcanzado temperaturas de 90°, me dijeron que pueden ser los controladores pero no se cómo corregir eso, instale estos 3 que estaban disponibles
AAA_AAA:
network-r8168
AAA_AAA:
video-vesa
AAA_AAA:
video-modesetting
inxi -Fazy
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e1dcd096-1707-4bc3-b652-365351f808f8 rw quiet apparmor=1
security=apparmor resume=UUID=8a7f014f-4983-47e9-b9ab-adb4f9cf69b3
udev.log_priority=3
Desktop: i3 v: 4.23 with: i3bar tools: xautolock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 80E1 v: Lenovo G40-45
serial: <superuser required> Chassis: type: 10 v: Lenovo G40-45
Mobo: LENOVO model: Lancer 4B2 v: SDK0H15299 WIN
serial: <superuser required> part-nu: LENOVO_MT_80E1_BU_idea_FM_Lenovo G40-45
uuid: <superuser required> UEFI-[Legacy]: LENOVO v: A2CN34WW(V2.02)
date: 02/28/2015
ID-1: BAT1 charge: 15.1 Wh (68.9%) condition: 21.9/28.5 Wh (76.9%)
power: 6.4 W volts: 15.5 min: 14.4 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: charging
Info: model: AMD E1-6010 APU with AMD Radeon R2 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1174 high: 1350 min/max: 1000/1350 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 998 2: 1350
bogomips: 5392
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Mullins [Radeon R2 Graphics] vendor: Lenovo driver: radeon
v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9853 class-ID: 0300
Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:3 chip-ID: 5986:0652
Display: x11 server: X.org v: 1.21.1.11 compositor: Picom v: git-fc1d1
driver: X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0455 built: 2014
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x174mm (12.2x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: KABINI (radeonsi LLVM 16.0.6 DRM 2.50
6.6.16-2-MANJARO) device-ID: 1002:9853 memory: 1000 MiB unified: no
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros QCA6164 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0041 class-ID: 0280
vendor: Lenovo RTL8111/8168/8411 driver: r8168 v: 8.052.01-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3:4
chip-ID: 0cf3:e300 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.1
lmp-v: 7 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 447.13 GiB used: 28.74 GiB (6.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 480GB SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0KA3 scheme: MBR
ID-1: / raw-size: 438.33 GiB size: 430.38 GiB (98.19%) used: 28.74 GiB (6.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 71.8 C mobo: N/A gpu: radeon temp: 72.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB note: est. available: 6.74 GiB used: 1.61 GiB (23.8%)
Processes: 161 Power: uptime: 1h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.69 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1163 libs: 316 tools: pamac,yay Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26 running-in: urxvtd
inxi: 3.3.33
Los “drivers” que vienen instalados para AMD son siempre la mejor opción, sin instalar drivers adicionales. A no ser que necesite algo que solo funcione con otro driver.
Veo que tu ordenador tiene algunos años. ¿Has descartado que el calentamiento sea por tener estropeado o sucio el ventilador o que se haya estropeado la pasta térmica? ¿Has probado otra distribución o windows en el mismo ordenador?
También echaría un vistazo a que no haya algún proceso raro corriendo y consumiendo muchos recursos.
Note El aumento con la última actualización del 21 de feb
Gracias por la sugerencia, voy a hacer mantenimiento
Como hago para saber esto?
Una de las opciones es escribir top en la consola y revisar los procesos.
¿A qué te refieres?
La última actualización del sistema, está:
2024-02-21
plymouth update may cause black screens
To “fix” the current problem, we have downgraded plymouth once again to have more time to find a proper solution to migrate most of your installations to a working state with newer plymouth versions.
sudo pacman -Syuu
bashrc-manjaro is now merged into bash
Yes, replace bashrc-manjaro with bash
Please also compare your:
/etc/.bash.bashrc
with the generated
/etc/.bash.bashrc.pacsave
and retrofit all of your customisations as there was no .pacnew file generated.
Same goes for /etc/skel/.bashrc
pacman and pacman-contrib changes
como identifico que se ejecuta que no necesito?
top - 20:45:29 up 6 min, 1 user, load average: 1.18, 1.28, 0.66
Tasks: 149 total, 2 running, 147 sleeping, 0 stopped, 0 zombie
%Cpu(s): 54.2 us, 20.9 sy, 0.0 ni, 22.2 id, 0.7 wa, 1.6 hi, 0.5 si, 0.0 st
MiB Mem : 6902.1 total, 5218.3 free, 1058.9 used, 877.3 buff/cache
MiB Swap: 9011.2 total, 9011.2 free, 0.0 used. 5843.2 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1275 aaa 20 0 32.7g 271288 162528 S 56.4 3.8 0:22.96 chromium
1306 aaa 20 0 32.7g 150960 99024 S 29.0 2.1 1:22.38 chromium
1382 aaa 20 0 1131.3g 151412 98416 S 25.4 2.1 0:17.94 chromium
1355 aaa 20 0 1131.3g 149192 102960 S 15.8 2.1 0:58.58 chromium
650 root 20 0 935828 130708 87348 R 12.5 1.8 0:33.23 Xorg
1176 aaa 20 0 839948 82456 49740 S 3.0 1.2 0:10.94 picom
1090 aaa 20 0 599908 11976 7348 S 2.6 0.2 0:07.81 conky
1624 aaa 20 0 47756 24208 13156 S 1.3 0.3 0:00.64 urxvtd
993 aaa 20 0 100460 17672 13192 S 0.7 0.3 0:00.46 i3
18 root -2 0 0 0 0 I 0.3 0.0 0:00.31 rcu_preempt
48 root 0 -20 0 0 0 I 0.3 0.0 0:00.69 kworker/1:1H-radeon-crtc
54 root 20 0 0 0 0 I 0.3 0.0 0:00.14 kworker/1:2-mm_percpu_wq
587 root 20 0 418476 26392 20528 S 0.3 0.4 0:03.19 NetworkManager
1311 aaa 20 0 32.4g 73104 53884 S 0.3 1.0 0:01.06 chromium
1668 aaa 20 0 14888 6144 3968 R 0.3 0.1 0:00.09 top
1 root 20 0 22416 13636 10140 S 0.0 0.2 0:02.99 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_g
5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_p
6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_
7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns
10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-kblockd
11 root 20 0 0 0 0 I 0.0 0.0 0:00.03 kworker/u8:0-ext4-rsv-conversion
13 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_pe
14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread
15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread
16 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread
17 root 20 0 0 0 0 S 0.0 0.0 0:00.11 ksoftirqd/0
19 root -2 0 0 0 0 S 0.0 0.0 0:00.00 rcub/0
20 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
21 root -51 0 0 0 0 S 0.0 0.0 0:00.00 idle_inject/0
22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
24 root -51 0 0 0 0 S 0.0 0.0 0:00.00 idle_inject/1
25 root rt 0 0 0 0 S 0.0 0.0 0:00.55 migration/1
26 root 20 0 0 0 0 S 0.0 0.0 0:00.10 ksoftirqd/1
28 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-kblockd
29 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
30 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-inet_
31 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kauditd
32 root 20 0 0 0 0 I 0.0 0.0 0:00.06 kworker/1:1-events
Puedes buscar el nombre de los programas en un buscador o buscarlos desde la consola. No tienes nada que te consuma más de lo que debería.
Si es que lo había acabado de prender para mostrarte.
lo que estoy haciendo es des-habilitar los servicios que no necesito que se ejecutan al encender el equipo
systemctl list-unit-files --type=service | grep enabled
add-autologin-group.service enabled disabled
apparmor.service enabled disabled
avahi-daemon.service enabled disabled
bluetooth.service enabled disabled
cups.service enabled disabled
getty@.service enabled enabled
haveged.service enabled disabled
lightdm.service enabled disabled
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
systemd-boot-update.service disabled enabled
systemd-fsck-root.service enabled-runtime disabled
systemd-homed.service disabled enabled
systemd-network-generator.service disabled enabled
systemd-networkd-wait-online.service disabled enabled
systemd-networkd.service disabled enabled
systemd-pstore.service disabled enabled
systemd-remount-fs.service enabled-runtime disabled
systemd-resolved.service disabled enabled
systemd-timesyncd.service enabled enabled
tlp.service enabled disabled
descubri que era chromium el que consumia muchos recursos, he estado usando ifrefox y no ha vuelto a tener esas temperaturas
cscs
5 March 2024 19:22
11
He marcado la solución al problema descrito en el título.
system
Closed
7 March 2024 07:23
12
