Hello,
I am using https://sdkman.io/ in my Manjaro 22 with Plasma.
After compiling my java application with Netbeans I am getting the following error:
30-Jan-2023 13:40:44.410 SEVERE [Catalina-utility-1] org.apache.catalina.startup.ExpandWar.copy Error copying [/home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/4-ROOT] to [/home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/11-ROOT]
java.io.FileNotFoundException: /home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/4-ROOT (No such file or directory)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(FileInputStream.java:216)
at java.base/java.io.FileInputStream.<init>(FileInputStream.java:157)
at org.apache.catalina.startup.ExpandWar.copy(ExpandWar.java:269)
at org.apache.catalina.startup.ContextConfig.antiLocking(ContextConfig.java:924)
at org.apache.catalina.startup.ContextConfig.beforeStart(ContextConfig.java:965)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:305)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:182)
at org.apache.catalina.startup.HostConfig.reload(HostConfig.java:1542)
at org.apache.catalina.startup.HostConfig.checkResources(HostConfig.java:1505)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1744)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:316)
at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1162)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1365)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1369)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1347)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:833)
30-Jan-2023 13:40:44.411 SEVERE [Catalina-utility-1] org.apache.catalina.startup.HostConfig.reload Error during context [] restart
org.apache.catalina.LifecycleException: Failed to start component [org.apache.catalina.webresources.StandardRoot@3618bb7]
at org.apache.catalina.util.LifecycleBase.handleSubClassException(LifecycleBase.java:440)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:198)
at org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4834)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4972)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
Caused by: java.lang.IllegalArgumentException: The main resource set specified [/home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/4-ROOT] is not valid
at org.apache.catalina.webresources.StandardRoot.createMainResourceSet(StandardRoot.java:762)
at org.apache.catalina.webresources.StandardRoot.startInternal(StandardRoot.java:719)
... 19 more
30-Jan-2023 13:40:54.413 INFO [Catalina-utility-2] org.apache.catalina.startup.HostConfig.reload Reloading context []
30-Jan-2023 13:40:54.413 INFO [Catalina-utility-2] org.apache.catalina.util.LifecycleBase.stop The stop() method was called on component [WebappLoader[StandardEngine[Catalina].StandardHost[localhost].StandardContext[]]] after stop() had already been called. The second call will be ignored.
30-Jan-2023 13:40:54.413 INFO [Catalina-utility-2] org.apache.catalina.util.LifecycleBase.destroy The destroy() method was called on component [org.apache.catalina.webresources.DirResourceSet@609eadd9] after destroy() had already been called. The second call will be ignored.
30-Jan-2023 13:40:54.415 SEVERE [Catalina-utility-2] org.apache.catalina.startup.ExpandWar.copy Error copying [/home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/4-ROOT] to [/home/mgem/.sdkman/candidates/tomcat/10.0.22/temp/12-ROOT]
30-Jan-2023 13:40:54.416 SEVERE [Catalina-utility-2] org.apache.catalina.startup.HostConfig.reload Error during context [] restart
... 19 more
I have tried to apply:
$chmod -R 777 tomcat
to tomcat directory but nothing changes.
The following are the versions:
SDKMAN 5.16.0
java: 17.0.5-oracle
tomcat: 10.0.22
Anyone is getting the same issue?
