v4r
October 27, 2020, 6:53pm
#1
I cloned the nginx-rtmp package from AUR. Build works fine, but in the last step, when installing, I get this:
==> Installing nginx-rtmp package group with pacman -U…
[sudo] password for hp:
loading packages…
resolving dependencies…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: nginx-rtmp and nginx-rtmp-src are in conflict
==> WARNING: Failed to install built package(s).
nginx-rtmp-src is not installed. In the build directory , there is a subdirectory ‘pkg’, which has two subdirectories ‘nginx-rtmp’ and ‘nginx-rtmp-src’.
What can I do now to get nginx-rtmp installed?
Thanks in advance - Hans-Peter
Strit
October 27, 2020, 6:57pm
#2
The package should have been transferred to your package cache, so check in /var/cache/pacman/pkg/nginx-rtmp*.
Strit
October 27, 2020, 7:03pm
#4
This one is troublesome though. Maybe try uninstalling nginx-rtmp-src
and then try building the package again.
v4r
October 27, 2020, 7:11pm
#5
I can’t deinstall, because it is not installed.
[hp@pbp nginx-rtmp]$ sudo pamac remove nginx-rtmp-src
Error: target not found: nginx-rtmp-src
both nginx-rtmp and nginx-rtmp-src are mentioned in the PKGBUILD
pkgname=(nginx-rtmp nginx-rtmp-src)
and both are getting built>
==> Tidying install…
-> Removing libtool files…
-> Purging unwanted files…
-> Removing static library files…
-> Stripping unneeded symbols from binaries and libraries…
-> Compressing man and info pages…
==> Checking for packaging issues…
==> WARNING: Package contains reference to $srcdir
usr/bin/nginx
==> Creating package “nginx-rtmp”…
-> Generating .PKGINFO file…
-> Generating .BUILDINFO file…
-> Adding install file…
-> Generating .MTREE file…
-> Compressing package…
==> Starting package_nginx-rtmp-src()…
==> WARNING: backup entry file not in package : etc/nginx/fastcgi.conf
==> WARNING: backup entry file not in package : etc/nginx/fastcgi_params
==> WARNING: backup entry file not in package : etc/nginx/koi-win
==> WARNING: backup entry file not in package : etc/nginx/koi-utf
==> WARNING: backup entry file not in package : etc/nginx/nginx.conf
==> WARNING: backup entry file not in package : etc/nginx/scgi_params
==> WARNING: backup entry file not in package : etc/nginx/uwsgi_params
==> WARNING: backup entry file not in package : etc/nginx/win-utf
==> WARNING: backup entry file not in package : etc/logrotate.d/nginx
==> Creating package “nginx-rtmp-src”…
==> Leaving fakeroot environment.
==> Finished making: nginx-rtmp 1.18.0-3 (Tue Oct 27 17:33:40 2020)
What if I remove all occurrences of nginx-rtmp-src from the PKGBUILD?
Strit
October 27, 2020, 7:12pm
#6
What tool are you using to build the package?
Pamac, Yay or makepkg?
v4r
October 27, 2020, 7:14pm
#7
makepkg -si --skippgpcheck
Can’t use pamac or yay. Both complain about nonexistent keys or failing import of keys.
Strit
October 27, 2020, 7:16pm
#8
Okay.
Then the package(s) should be in the same folder where you ran the makepkg command.
So you should be able to install it with sudo pacman -U nginx-rtmp-1.18*
makepkg -si
will try to install all the resulting packages, but those in the PKGBUILD conflict with eachother.
v4r
October 27, 2020, 7:20pm
#9
@Strit That’s it. nginx-rtmp finally installed. Many thanks for your help!
system
closed
November 11, 2020, 7:20pm
#10
