I am trying to reinstall Pulseaudio because Pipewire doesnt work well with Firefox.
I had some problems but was finally able to remove manjaro-pipewire with Pamac, and install barebones Pulseaudio (no optional packages) and turn Pulseaudio on in syscontrol.
However, there are still pipewire packages I cannot remove, and I still cannot add optional packages to pulseaudio.
The main problem appears to be that I installed Ardour.
There is a circular set of dependencies between Ardour and some pipewire packages. Is there any way to force removal of a package despite the dependency, or removing it together with the dependency?
ο ξ° ο ~ ξ° inxi -Aa ξ² β ξ² 4s ο
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: off with: 1: pipewire-media-session
status: off 2: pw-jack type: plugin tools: pw-cat,pw-cli
Server-2: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
ο ξ° ο ~ ξ° pamac install manjaro-pulse ξ² β
Preparing...
Refreshing AUR...
Choose optional dependencies for manjaro-pulse:
1: paprefs: Configuration dialog
2: pasystray: system tray application
3: pavucontrol: A GTK volume control tool
4: pavucontrol-qt: A Qt volume control tool
5: pulseaudio-equalizer: Graphical equalizer
6: pulseaudio-equalizer-ladspa: A 15-band equalizer
7: pulseaudio-jack: Jack support
8: pulseaudio-lirc: IR (lirc) support
9: pulseaudio-rtp: RTP and RAOP support
10: pulseaudio-zeroconf: Zeroconf support
Enter a selection (default=none): 1,2,4,5,6
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing pipewire-jack breaks dependency 'jack' required by ardour
- removing pipewire-jack breaks dependency 'libjack.so=0-64' required by ardour
Iβm happy to provide other info, of course, if needed. Thank you for your help, and taking time to read this!
Man, you are fast! Thanks!
Firefox forces max volume every time I touch the web player. It appears to be a problem without resolution and Firefox states they use Pulseaudio. I tried Pipewire hoping it would fix some bluetooth headphone issues, but it did not.
I do not need Ardour, I installed because it intrigued me. Unfortunately that same circular dependency refuses to let me uninstall Ardour. This is way I was hoping there might be a way to force uninstall.
As you can see, there there were dependencies. I removed them, removed ardour, installed the pulseaudio options, but this time I chose audacity. Not I am getting the same error about pipewire-jack, but with audacity this time.
ο ξ° ο ~ ξ° sudo pacman -R ardour ξ² 1 β
[sudo] password for alexandra:
Sorry, try again.
checking dependencies...
:: removing ardour breaks dependency 'lv2-host' required by zam-plugins-lv2
ο ξ° ο ~ ξ° pamac zam-plugins-lv2 ξ² 1 β ξ² 14s ο
Available actions:
pamac --version
pamac --help, -h [action]
pamac search [options] <package(s)>
pamac list [options] <package(s)>
pamac info [options] <package(s)>
pamac install [options] <package(s)>
pamac reinstall [options] <package(s)>
pamac remove [options] [package(s)]
pamac checkupdates [options]
pamac update,upgrade [options]
pamac clone [options] <package(s)>
pamac build [options] [package(s)]
pamac clean [options]
ο ξ° ο ~ ξ° pamac remove zam-plugins-lv2 ξ² β
Preparing...
Checking dependencies...
To remove (1):
zam-plugins-lv2 4.2-1 extra
Total removed size: 34.3 MB
Apply transaction ? [y/N] y
Authenticating as: Alexandra (alexandra)
Password:
Removing zam-plugins-lv2 (4.2-1)... [1/1]
Arming ConditionNeedsUpdate... [1/2]
Refreshing PackageKit... [2/2]
ο ξ° ο ~ ξ° pamac remove ardour ξ² β ξ² 8s ο
Preparing...
To remove (1):
ardour 8.4-1 extra
Total removed size: 98.5 MB
Password:
Removing ardour (8.4-1)... [1/1]
Arming ConditionNeedsUpdate... [1/5]
Updating the MIME type database... [2/5]
Refreshing PackageKit... [3/5]
Updating icon theme caches... [4/5]
Updating the desktop file MIME type cache... [5/5]
ο ξ° ο ~ ξ° pamac install manjaro-pulse ξ² β ξ² 18s ο
Preparing...
Refreshing AUR...
Enter a selection (default=none): 1,2,3,4,5,6
Choose a provider for ladspa-host:
1: ardour 8.4-1 extra
2: audacity 1:3.4.2-3 extra
3: carla 2.5.8-1 extra
4: element 0.46.6-1 extra
5: muse 4.2.1-1 extra
6: qtractor 0.9.39-3 extra
7: rosegarden 23.12-1 extra
Enter a number (default=1): 2
- unable to satisfy dependency 'jack' required by audacity
- removing pipewire-jack breaks dependency 'libjack.so=0-64' required by aubio
ο ξ° ο ~ ξ°
(aubio was ardour before I removed it and replaced with audacity)
The above seems to be the crux of the problem. Although I have removed manjaro-pipewire, I can do no more than reinstall pulseaudio without any options, because pipewire-jack remains. If I try to remove pipewire-jack, it states it is required by various programs. if I remove those, then new ones appear.
Is there any way to force removal of pipewire-jack?
Thank you for your reply. Installing Manjaro-pulse via pamac is exactly what I did. If you look at my first post, I show the results of that.
I was able to install manjaro-pulse with no options. However if I try to install with any options, I still get the pipewire-jack conflict.
Believe me I do not desire make any of this uneccesarily difficult.
I manually installed pulseaudio-jack, and that appeared to work, however, I did not get a prompt to remove pipewire-jack, and then when I tried to reinstall pulseaudio with other options, the pipewire conflict reappears.
pamac install pulseaudio-jack ξ² β ξ² 23s ο
Preparing...
Refreshing AUR...
To install (1):
pulseaudio-jack 17.0-3 extra 19.5 kB
Total download size: 19.5 kB
Total installed size: 83.6 kB
Password:
Download of pulseaudio-jack (17.0-3) started
Download of pulseaudio-jack (17.0-3) finished
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing pulseaudio-jack (17.0-3)... [1/1]
ο ξ° ο ~ ξ° Pamac install manjaro-pulse ξ² β ξ² 17s ο
zsh: correct 'Pamac' to 'pamac' [nyae]? y
Preparing...
7: pulseaudio-lirc: IR (lirc) support
8: pulseaudio-rtp: RTP and RAOP support
9: pulseaudio-zeroconf: Zeroconf support
Enter a selection (default=none): 1,2,3,4,5,6,
