Hello all, I may be premature in posting this but … updating to dbus-python results in the flollwing error: dbus-python and python2-dbus are in conflict
however removing python2-dbus breaks the dependency python2-dbus required by xboxdrv. It seems updating to dbus-python breaks the xboxdrv package needed for usb xbox controllers.
Seems the AUR package xboxdrv was flagged out of date on 2021-03-18 regarding this but no action was taken since, not sure what to do in that situation since xboxdrv was the only xbox controller driver that worked flawlessly for me. https://aur.archlinux.org/packages/xboxdrv/
Right! xboxdrv worked so well. Do you think xboxdrv will be updated any time soon. If so, I will uninstall it and wait for an update. However @realmain suggested a fix, I want to try it but I don’t want to make a frakenxboxdrv package.
Why do you need this external driver? My Xbox controller works perfectly in Manjaro I don’t really think it is required nowadays (maybe a few years back?).
Also from the AUR page: Last Updated: 2019-09-29 23:36
PS: never share terminal output as images, paste your text and then select it all, and click the </> button to make it a properly formatted text, like this:
[omano@omano-nvme ~]$ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
