i just installed Manjaro recently and im totally new to the Linux-World. So i dont have any clue how to solve my problem and im not firm in using linux commands over the console…so im thankfull for any help
I used KUP the Backup-Tool from KDE to save my home Folder to an external drive as backup when suddenly i got errors that i only have reading rights for everything. I restarted the pc only to get the following error
[FAILED] Failed to start File System Check on /dev/disk/by-uuid…
[DEPEND] Dependency failed for /home
[DEPEND] Dependency failed for Local File Systems.
You are in emergency mode…
I dont know what whent there wrong, and i also dont have a clue how to fix this without destroying the data in my home folder
My home folder is on a second hdd in my pc with a ext4-partition. I started Manjaro with a bootable usb, the data is still there…
[manjaro@manjaro ~]$ cat /etc/fstab
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
ADDITION:
the fstab info above seems not correct, when i look into the file directly it looks as follows
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=a952b4e7-4a5c-42f8-afac-c01f06a064c1 / ext4 defaults,noatime 0 1
UUID=9d8aaa11-0138-4dc1-b81a-efd8d99370a8 swap swap defaults,noatime 0 0
UUID=0f84665f-823b-475b-bcaf-f3b86fcd930c /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
it looks ok there, home is correctly included…any other ideas?
