Hi everyone,
I’m new here - recently switched to Manjaro from antix and Pop_OS.
I’ve been looking around for this issue but could not find it anywhere, hence I’ve registered and am posting here some details in case anyone can help (I hope so, it seems to be a very friendly, knowledgeable community).
The problem:
Although my USB ports are all recognised with no issues in lsusb, when connecting anything to those ports… well, whatever I connect it does not work, although it is identified.
For example, connecting a USB stick to one port works correctly, and I can mount it too.
Connecting the same USB stick to another port does not work, although it shows in lsusb.
The laptop is a DELL XPSL702x with 3 USB ports. All 3 ports work fine on Windows.
lsusb information below - in this example, the devices connected at Bus 004 Device 005 and Bus 003 Device 002 are not recognised. However, if I connect them to Bus 002 Device 003 they work fine.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 0408:2fb1 Quanta Computer, Inc. Laptop_Integrated_Webcam_2HDM
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 003: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2/50 Kyson
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 2357:011e TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 005: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
Here is the inxi -zv8 output
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=29d082b6-22cb-4ed8-b9db-af9d4162e0ab rw quiet splash
resume=UUID=c47bcdad-6f90-472d-8773-3bb56b02cc5c udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Portable System: Dell product: Dell System XPS L702X v: N/A
serial: <superuser required> Chassis: type: 8 v: 0.1
Mobo: Dell model: 0K4H3G v: FAB1 serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: Dell v: A19 date: 09/07/2012
System RAM: total: 10 GiB available: 9.61 GiB used: 5.07 GiB (52.8%)
Array-1: capacity: 32 GiB note: est. slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: 0000 part-no: N/A serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
manufacturer: 830b part-no: NT2GC64B88B0NS-CG serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-2410M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/2900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 18364
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: NVIDIA GF106M [GeForce GT 550M] vendor: Dell driver: nvidia
v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
gen: 2 speed: 5 GT/s lanes: 16 ports: active: none empty: HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:0dd6 class-ID: 0300
Device-3: Quanta Laptop_Integrated_Webcam_2HDM driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:3
chip-ID: 0408:2fb1 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: intel,nvidia unloaded: modesetting
dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 75 s-size: 543x305mm (21.38x12.01")
s-diag: 623mm (24.52")
Monitor-1: LVDS-1 mapped: LVDS1 model: Chi Mei Opto 0x1718 built: 2010
res: 1600x900 hz: 60 dpi: 107 gamma: 1.2 chroma: red: x: 0.620 y: 0.337
green: x: 0.322 y: 0.596 blue: x: 0.161 y: 0.078 white: x: 0.314 y: 0.329
size: 380x220mm (14.96x8.66") diag: 438mm (17.3") ratio: 16:9
modes: 1600x900
API: EGL v: 1.5 hw: drv: intel crocus platforms: gbm: drv: crocus
API: OpenGL v: 3.3 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
glx-v: 1.4 direct-render: yes renderer: GeForce GT 550M/PCIe/SSE2
memory: 1000 MiB
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0be9 class-ID: 0403
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0083 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: down mac: <filter>
Device-3: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
driver: rtl88XXau type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-2:2 chip-ID: 2357:011e class-ID: 0000 serial: <filter>
IF: wlp4s0u2 state: dormant mac: <filter>
Local Storage: total: 861.19 GiB used: 314.54 GiB (36.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R022 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST320LT007-9ZV142
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DEM1 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 3.0
size: 57.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: PMAP
ID-4: /dev/sdd maj-min: 8:48 model: USB Flash Disk size: 58.2 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1100
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRWBD CT30N rev: A101
dev-links: cdrom
ID-1: / raw-size: 436.56 GiB size: 428.63 GiB (98.19%)
used: 206.69 GiB (48.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 29d082b6-22cb-4ed8-b9db-af9d4162e0ab
ID-2: /run/media/anto/5925439F08707623 raw-size: 57.76 GiB
size: 57.76 GiB (100.00%) used: 14.29 GiB (24.7%) fs: ntfs dev: /dev/sdc
maj-min: 8:32 label: N/A uuid: 5925439F08707623
ID-3: /run/media/anto/Extra space 1 raw-size: 156.39 GiB
size: 156.39 GiB (100.00%) used: 93.56 GiB (59.8%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: Extra space 1 uuid: 01D55517C6A79D60
ID-1: swap-1 type: partition size: 10.57 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: c47bcdad-6f90-472d-8773-3bb56b02cc5c
ID-1: /dev/sdb2 maj-min: 8:18 size: 141.7 GiB fs: ext4 label: More space
uuid: b5288b4f-5c4c-4ee3-b3f9-11b146bdf73c
ID-2: /dev/sdd1 maj-min: 8:49 size: 4 MiB fs: vfat label: N/A
uuid: 6A56-8FBF
ID-3: /dev/sdd2 maj-min: 8:50 size: 58.2 GiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.4:3 info: Quanta Laptop_Integrated_Webcam_2HDM type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 250mA chip-ID: 0408:2fb1 class-ID: 0e02
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.2:3 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-2:2 info: TP-Link AC600 wireless Realtek RTL8811AU [Archer
T2U Nano] type: Network driver: rtl88XXau interfaces: 1 rev: 2.1
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
Device-1: 4-1:5 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 304mA
chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 68.0 C mobo: 38.0 C sodimm: SODIMM C gpu: nvidia
temp: 55 C
Fan Speeds (rpm): N/A
Packages: 1307 pm: dpkg pkgs: 0 pm: pacman pkgs: 1292 libs: 341
tools: pamac,yay pm: flatpak pkgs: 15
1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
Processes:
CPU top: 5 of 248
1: cpu: 19.8% command: firefox pid: 2141 mem: 729.9 MiB (7.4%)
2: cpu: 16.2% command: Xorg pid: 627 mem: 120.2 MiB (1.2%)
3: cpu: 9.5% command: firefox pid: 10907 mem: 282.3 MiB (2.8%)
4: cpu: 5.2% command: spotify pid: 4024 mem: 304.4 MiB (3.0%)
5: cpu: 5.0% command: spotify pid: 3927 mem: 356.3 MiB (3.6%)
Memory top: 5 of 248
1: mem: 729.9 MiB (7.4%) command: firefox pid: 2141 cpu: 19.8%
2: mem: 695.9 MiB (7.0%) command: pamac-manager pid: 9681 cpu: 0.1%
3: mem: 569.8 MiB (5.7%) command: plasmashell pid: 794 cpu: 1.8%
4: mem: 565.9 MiB (5.7%) command: pamac-checkupdates pid: 2016 cpu: 0.4%
5: mem: 356.3 MiB (3.6%) command: spotify pid: 3927 cpu: 5.0%
Processes: 248 Power: uptime: 1h 54m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.81 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
Hopefully I formatted everything correctly.
Thanks to any kind souls who can help ![]()
