I have a HDR capable 4K display on my Dell XPS 9575 laptop but cannot get the HDR option to show in KDE Plasma settings. The settings show “Built-in Screen” rather than the monitor model etc. Does this prevent KDE Plasma from showing the HDR option? Do I need to configure the monitor further, and if so how do I do that? I can’t find anything recent that tells me.
Manjaro KDE Plasma 6.3.6 running Wayland
inxi --edid -c 0
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
temp: 50.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
class-ID: 0e02 serial: 200901010001
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 3840x2160
hz: 60 scale: 190% (1.9) to: 2021x1137 dpi: 284 gamma: 1.2 chroma: red:
x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 3840x2160
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 14.98 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.2.3-arch1.2
device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
v: 25.2.3-arch1.2 device-ID: 1002:694e surfaces: N/A
Mod edit (scotty65): formatted inxi output to something more easily read by removing the single backticks from each line and adding 3 backticks ``` to the lines before and after the full output
