Hello,
I am a somewhat experienced linux user, and cannot figure out what (most likely BIOS) problem is causing this.
Basically;
charging=loud fans
not charging=no fans.
Since it happens instantaneously, I don’t think the computer is reading temperature sensors, it just is coded somewhere to turn on fans.
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=4b8b96c1-5b55-4cff-a6f2-058ebfe16cb2 rw enable_fbc=1 enable_psr=1
disable_power_well=0 mem_sleep_default=deep apparmor=1 security=apparmor
udev.log_priority=3
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 02MJVY v: A00 serial: <filter> UEFI: Dell v: 1.21.0
date: 07/20/2021
ID-1: BAT0 charge: 60.5 Wh (79.7%) condition: 75.9/97.0 Wh (78.2%)
volts: 12.7 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Charging
RAM: total: 15.26 GiB used: 2.87 GiB (18.8%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 2200 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2200 2: 2200
3: 2199 4: 2200 5: 2199 6: 2200 7: 2200 8: 2200 9: 2187 10: 2199 11: 2200
12: 2201
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:671d class-ID: 0e02
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: eDP-1 res: 3840x2160 hz: 60 dpi: 284 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0cf3:e301 class-ID: e001
Local Storage: total: 476.94 GiB used: 127.9 GiB (26.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 80003E00 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 176.28 GiB size: 172.51 GiB (97.86%)
used: 127.8 GiB (74.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 4b8b96c1-5b55-4cff-a6f2-058ebfe16cb2
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 110.9 MiB (17.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 2833-3897
ID-1: swap-1 type: partition size: 4.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:5 label: N/A
uuid: a8646cf5-7500-4d18-a23a-119385e84afa
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 200 GiB fs: ntfs label: N/A
uuid: 2084868384865AE4
ID-3: /dev/nvme0n1p7 maj-min: 259:6 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 4ABEBC0EBEBBF115
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e301
class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2502 fan-2: 2499
Processes: 301 Uptime: 10m wakeups: 7 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1204 lib: 295
flatpak: 0 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.08
In journalctl and dmesg there is no addition to logs when I insert or remove charger, except for kernel: ata3: SATA link down (SStatus 4 SControl 300) when the charger is inserted.
powertop --auto-tune, tlp on bat or ac, and auto-cpufreq have not changed the problem.
I have tried all power saving measures described in the ArchWiki under my laptop.
Any insight on where to look for what might be happening is greatly appreciated!
**Edit: When on AC, my CPU is always 2.20 Ghz according to cpupower frequency-info. When unplugged it varies, from 800Mhz to 2.2 Ghz depending on the workload. This seems to be my problem, as the fans may be reacting to 2.20Ghz. I need to change to governor to powersave from performance even when on AC.
I will look through any dell BIOS setting that could be causing some sort of pinned CPU frequency when on AC. **
