It just happend again during a youtube video. I don’t know how to lock the screen on Manjaro so I had to restart. Afterwards I opened System Log and maybe it helps someone here.
I don’t know why but I have two entrys on the left “Xorg.0.log” and “Xorg.1.log”.
0
[ 3.356] (--) Log file renamed from "/var/log/Xorg.pid-808.log" to "/var/log/Xorg.0.log"
[ 3.357] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 4.471]
X.Org X Server 1.20.13
[ 4.471] Build Operating System: Linux Manjaro Linux
[ 4.471] Current Operating System: Linux xps-manjaro 5.13.12-1-MANJARO #1 SMP PREEMPT Wed Aug 18 08:06:42 UTC 2021 x86_64
[ 4.471] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=a92fb0d1-e6fd-4a36-8570-9176b77c4488 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 4.471] Build Date: 24 August 2021 10:21:29AM
[ 4.471]
[ 4.471] Current version of pixman: 0.40.0
[ 4.471] Before reporting problems, check http://wiki.x.org
[ 4.471] Markers: (--) probed, (**) from config file, (==) default setting,
[ 4.471] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 28 11:47:00 2021
[ 4.472] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4.472] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4.474] (==) ServerLayout "layout"
[ 4.474] (==) No screen section available. Using defaults.
[ 4.474] (**) |-->Screen "Default Screen Section" (0)
[ 4.474] (**) | |-->Monitor "<default monitor>"
[ 4.474] (==) No monitor specified for screen "Default Screen Section".
[ 4.474] (==) Automatically adding devices
[ 4.474] (==) Automatically enabling devices
[ 4.474] (==) Automatically adding GPU devices
[ 4.474] (==) Automatically binding GPU devices
[ 4.474] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.474] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 4.474] Entry deleted from font path.
[ 4.475] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 4.475] Entry deleted from font path.
[ 4.475] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.475] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 4.475] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 4.475] (==) FontPath set to:
/usr/share/fonts/TTF
[ 4.475] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4.475] (II) The server relies on udev to provide the list of input devices.
[ 4.475] (II) Module ABI versions:
[ 4.475] X.Org ANSI C Emulation: 0.4
[ 4.475] X.Org Video Driver: 24.1
[ 4.475] X.Org XInput driver : 24.1
[ 4.475] X.Org Server Extension : 10.0
[ 4.475] (++) using VT number 1
[ 4.477] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 4.478] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 4.478] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
[ 4.478] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.479] (EE) systemd-logind: failed to take device /dev/dri/card0: No such device
[ 4.480] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 4.480] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.752] (--) PCI:*(0@0:2:0) 8086:9bc4:1028:097d rev 5, Mem @ 0x604a000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 5.752] (--) PCI: (1@0:0:0) 10de:1f95:1028:097d rev 161, Mem @ 0xb3000000/16777216, 0x70000000/268435456, 0x80000000/33554432, I/O @ 0x00003000/128
[ 5.752] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.752] (II) LoadModule: "glx"
[ 5.763] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.764] (II) Module glx: vendor="X.Org Foundation"
[ 5.764] compiled for 1.20.13, module version = 1.0.0
[ 5.764] ABI class: X.Org Server Extension, version 10.0
[ 5.764] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 5.764] loading driver: modesetting
[ 5.764] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 5.764] loading driver: nvidia
[ 7.535] (==) Matched modesetting as autoconfigured driver 0
[ 7.535] (==) Matched nvidia as autoconfigured driver 1
[ 7.535] (==) Matched nouveau as autoconfigured driver 2
[ 7.535] (==) Matched nv as autoconfigured driver 3
[ 7.535] (==) Matched fbdev as autoconfigured driver 4
[ 7.535] (==) Matched vesa as autoconfigured driver 5
[ 7.535] (==) Assigned the driver to the xf86ConfigLayout
[ 7.535] (II) LoadModule: "modesetting"
[ 7.535] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 7.536] (II) Module modesetting: vendor="X.Org Foundation"
[ 7.536] compiled for 1.20.13, module version = 1.20.13
[ 7.536] Module class: X.Org Video Driver
[ 7.536] ABI class: X.Org Video Driver, version 24.1
[ 7.536] (II) LoadModule: "nvidia"
[ 7.536] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.539] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 7.539] compiled for 1.6.99.901, module version = 1.0.0
[ 7.539] Module class: X.Org Video Driver
[ 7.539] (II) LoadModule: "nouveau"
[ 7.540] (WW) Warning, couldn't open module nouveau
[ 7.540] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 7.540] (II) LoadModule: "nv"
[ 7.540] (WW) Warning, couldn't open module nv
[ 7.540] (EE) Failed to load module "nv" (module does not exist, 0)
[ 7.540] (II) LoadModule: "fbdev"
[ 7.540] (WW) Warning, couldn't open module fbdev
[ 7.540] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 7.540] (II) LoadModule: "vesa"
[ 7.541] (WW) Warning, couldn't open module vesa
[ 7.541] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 7.541] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 7.541] (II) NVIDIA dlloader X Driver 470.63.01 Tue Aug 3 20:37:27 UTC 2021
[ 7.541] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.551] (II) modeset(0): using drv /dev/dri/card0
[ 7.551] (II) systemd-logind: releasing fd for 226:1
[ 7.552] (II) Loading sub module "fb"
[ 7.552] (II) LoadModule: "fb"
[ 7.552] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.552] (II) Module fb: vendor="X.Org Foundation"
[ 7.553] compiled for 1.20.13, module version = 1.0.0
[ 7.553] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.553] (II) Loading sub module "wfb"
[ 7.553] (II) LoadModule: "wfb"
[ 7.553] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.553] (II) Module wfb: vendor="X.Org Foundation"
[ 7.553] (II) Loading sub module "ramdac"
[ 7.553] (II) LoadModule: "ramdac"
[ 7.553] (II) Module "ramdac" already built-in
[ 7.593] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 7.594] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 7.594] (==) modeset(0): RGB weight 888
[ 7.594] (==) modeset(0): Default visual is TrueColor
[ 7.594] (II) Loading sub module "glamoregl"
[ 7.594] (II) LoadModule: "glamoregl"
[ 7.594] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 7.607] (II) Module glamoregl: vendor="X.Org Foundation"
[ 7.607] compiled for 1.20.13, module version = 1.0.1
[ 7.607] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.769] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (CML GT2)
[ 7.769] (II) modeset(0): glamor initialized
[ 7.770] (II) modeset(0): Output eDP-1 has no monitor section
[ 7.770] (II) modeset(0): Output DP-1 has no monitor section
[ 7.770] (II) modeset(0): Output DP-2 has no monitor section
[ 7.770] (II) modeset(0): Output DP-3 has no monitor section
[ 7.772] (II) modeset(0): EDID for output eDP-1
[ 7.772] (II) modeset(0): Manufacturer: SHP Model: 14d1 Serial#: 0
[ 7.772] (II) modeset(0): Year: 2020 Week: 4
[ 7.772] (II) modeset(0): EDID Version: 1.4
[ 7.772] (II) modeset(0): Digital Display Input
[ 7.772] (II) modeset(0): 8 bits per channel
[ 7.772] (II) modeset(0): Digital interface is DisplayPort
[ 7.772] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 21
[ 7.772] (II) modeset(0): Gamma: 2.20
[ 7.772] (II) modeset(0): No DPMS capabilities specified
[ 7.772] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 7.772] (II) modeset(0): Default color space is primary color space
[ 7.772] (II) modeset(0): First detailed timing is preferred mode
[ 7.772] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 7.772] (II) modeset(0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
[ 7.772] (II) modeset(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
[ 7.772] (II) modeset(0): Manufacturer's mask: 0
[ 7.772] (II) modeset(0): Supported detailed timing:
[ 7.772] (II) modeset(0): clock: 154.0 MHz Image Size: 336 x 210 mm
[ 7.772] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 7.772] (II) modeset(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 7.772] (II) modeset(0): clock: 123.2 MHz Image Size: 336 x 210 mm
[ 7.772] (II) modeset(0): Unknown vendor-specific block 0
[ 7.772] (II) modeset(0): EDID (in hex):
[ 7.772] (II) modeset(0): 00ffffffffffff004d10d11400000000
[ 7.772] (II) modeset(0): 041e0104a52215780ede50a3544c9926
[ 7.772] (II) modeset(0): 0f505400000001010101010101010101
[ 7.772] (II) modeset(0): 010101010101283c80a070b023403020
[ 7.772] (II) modeset(0): 360050d210000018203080a070b02340
[ 7.772] (II) modeset(0): 3020360050d210000018000000fe0046
[ 7.772] (II) modeset(0): 4b52314b804c513135364e3100000000
[ 7.772] (II) modeset(0): 0002410332001200000a010a2020003a
[ 7.772] (II) modeset(0): Printing probed modes for output eDP-1
[ 7.772] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (74.0 kHz eP)
[ 7.772] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 7.772] (II) modeset(0): Modeline "1920x1200"x48.0 123.20 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (59.2 kHz e)
[ 7.773] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 7.773] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 7.773] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 7.773] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 7.773] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 7.773] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 7.773] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 7.773] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 7.773] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 7.773] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 7.773] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 7.773] (II) modeset(0): EDID for output DP-1
[ 7.773] (II) modeset(0): EDID for output DP-2
[ 7.773] (II) modeset(0): EDID for output DP-3
[ 7.773] (II) modeset(0): Output eDP-1 connected
[ 7.773] (II) modeset(0): Output DP-1 disconnected
[ 7.773] (II) modeset(0): Output DP-2 disconnected
[ 7.773] (II) modeset(0): Output DP-3 disconnected
[ 7.773] (II) modeset(0): Using exact sizes for initial modes
[ 7.773] (II) modeset(0): Output eDP-1 using initial mode 1920x1200 +0+0
[ 7.773] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.773] (==) modeset(0): DPI set to (96, 96)
[ 7.773] (II) Loading sub module "fb"
[ 7.773] (II) LoadModule: "fb"
[ 7.774] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.774] (II) Module fb: vendor="X.Org Foundation"
[ 7.774] compiled for 1.20.13, module version = 1.0.0
[ 7.774] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.774] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 7.774] (==) NVIDIA(G0): RGB weight 888
[ 7.774] (==) NVIDIA(G0): Default visual is TrueColor
[ 7.774] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.774] (**) Option "AllowNVIDIAGpuScreens"
[ 7.774] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 7.774] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 7.774] (**) NVIDIA(G0): Enabling 2D acceleration
[ 7.774] (II) Loading sub module "glxserver_nvidia"
[ 7.774] (II) LoadModule: "glxserver_nvidia"
[ 7.774] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.802] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.802] compiled for 1.6.99.901, module version = 1.0.0
[ 7.802] Module class: X.Org Server Extension
[ 7.802] (II) NVIDIA GLX Module 470.63.01 Tue Aug 3 20:35:52 UTC 2021
[ 7.803] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 9.718] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1650 Ti (TU117-A) at PCI:1:0:0
[ 9.718] (II) NVIDIA(G0): (GPU-0)
[ 9.718] (--) NVIDIA(G0): Memory: 4194304 kBytes
[ 9.718] (--) NVIDIA(G0): VideoBIOS: 90.17.42.00.3a
[ 9.718] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 9.718] (II) NVIDIA(G0): Validated MetaModes:
[ 9.718] (II) NVIDIA(G0): "NULL"
[ 9.718] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 9.718] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 9.718] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 9.837] (==) modeset(0): Backing store enabled
[ 9.837] (==) modeset(0): Silken mouse disabled
[ 9.921] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9.921] (==) modeset(0): DPMS enabled
[ 9.921] (II) modeset(0): [DRI2] Setup complete
[ 9.921] (II) modeset(0): [DRI2] DRI driver: iris
[ 9.921] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 9.922] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 9.922] (II) NVIDIA: access.
[ 9.937] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 9.937] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 9.937] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 9.937] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 9.937] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 9.937] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 9.937] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 9.937] (II) NVIDIA(G0): Config Options in the README.
[ 9.993] (II) NVIDIA(G0): Setting mode "NULL"
[ 10.002] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 10.002] (==) NVIDIA(G0): Backing store enabled
[ 10.002] (==) NVIDIA(G0): Silken mouse disabled
[ 10.002] (==) NVIDIA(G0): DPMS enabled
[ 10.003] (II) Loading sub module "dri2"
[ 10.003] (II) LoadModule: "dri2"
[ 10.003] (II) Module "dri2" already built-in
[ 10.003] (II) NVIDIA(G0): [DRI2] Setup complete
[ 10.003] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 10.003] (II) Initializing extension Generic Event Extension
[ 10.003] (II) Initializing extension SHAPE
[ 10.003] (II) Initializing extension MIT-SHM
[ 10.003] (II) Initializing extension XInputExtension
[ 10.003] (II) Initializing extension XTEST
[ 10.004] (II) Initializing extension BIG-REQUESTS
[ 10.004] (II) Initializing extension SYNC
[ 10.004] (II) Initializing extension XKEYBOARD
[ 10.004] (II) Initializing extension XC-MISC
[ 10.004] (II) Initializing extension SECURITY
[ 10.004] (II) Initializing extension XFIXES
[ 10.004] (II) Initializing extension RENDER
[ 10.004] (II) Initializing extension RANDR
[ 10.004] (II) Initializing extension COMPOSITE
[ 10.004] (II) Initializing extension DAMAGE
[ 10.004] (II) Initializing extension MIT-SCREEN-SAVER
[ 10.004] (II) Initializing extension DOUBLE-BUFFER
[ 10.004] (II) Initializing extension RECORD
[ 10.004] (II) Initializing extension DPMS
[ 10.004] (II) Initializing extension Present
[ 10.004] (II) Initializing extension DRI3
[ 10.004] (II) Initializing extension X-Resource
[ 10.004] (II) Initializing extension XVideo
[ 10.004] (II) Initializing extension XVideo-MotionCompensation
[ 10.004] (II) Initializing extension GLX
[ 10.004] (II) Indirect GLX disabled.
[ 10.018] (II) AIGLX: Loaded and initialized iris
[ 10.018] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 10.018] (II) Initializing extension XFree86-VidModeExtension
[ 10.018] (II) Initializing extension XFree86-DGA
[ 10.018] (II) Initializing extension XFree86-DRI
[ 10.018] (II) Initializing extension DRI2
[ 10.018] (II) Initializing extension NV-GLX
[ 10.018] (II) Initializing extension NV-CONTROL
[ 10.019] (II) modeset(0): Damage tracking initialized
[ 10.019] (II) modeset(0): Setting screen physical size to 508 x 317
[ 10.121] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 10.121] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.121] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.121] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.121] (II) LoadModule: "libinput"
[ 10.121] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 10.126] (II) Module libinput: vendor="X.Org Foundation"
[ 10.126] compiled for 1.20.11, module version = 1.1.0
[ 10.126] Module class: X.Org XInput Driver
[ 10.126] ABI class: X.Org XInput driver, version 24.1
[ 10.126] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.127] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 36 paused 0
[ 10.127] (**) Video Bus: always reports core events
[ 10.127] (**) Option "Device" "/dev/input/event10"
[ 10.127] (**) Option "_source" "server/udev"
[ 10.136] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 10.136] (II) event10 - Video Bus: device is a keyboard
[ 10.136] (II) event10 - Video Bus: device removed
[ 10.136] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16/event10"
[ 10.136] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 10.136] (**) Option "xkb_layout" "de"
[ 10.164] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 10.164] (II) event10 - Video Bus: device is a keyboard
[ 10.164] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 10.164] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.164] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.164] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.164] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.165] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 39 paused 0
[ 10.165] (**) Video Bus: always reports core events
[ 10.165] (**) Option "Device" "/dev/input/event9"
[ 10.165] (**) Option "_source" "server/udev"
[ 10.166] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 10.166] (II) event9 - Video Bus: device is a keyboard
[ 10.166] (II) event9 - Video Bus: device removed
[ 10.166] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input15/event9"
[ 10.166] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 10.166] (**) Option "xkb_layout" "de"
[ 10.167] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 10.167] (II) event9 - Video Bus: device is a keyboard
[ 10.167] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 10.167] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 10.167] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 10.167] (**) Power Button: Applying InputClass "system-keyboard"
[ 10.167] (II) Using input driver 'libinput' for 'Power Button'
[ 10.168] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 40 paused 0
[ 10.168] (**) Power Button: always reports core events
[ 10.168] (**) Option "Device" "/dev/input/event1"
[ 10.168] (**) Option "_source" "server/udev"
[ 10.169] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 10.169] (II) event1 - Power Button: device is a keyboard
[ 10.169] (II) event1 - Power Button: device removed
[ 10.169] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 10.169] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 10.169] (**) Option "xkb_layout" "de"
[ 10.170] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 10.170] (II) event1 - Power Button: device is a keyboard
[ 10.170] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 10.170] (II) No input driver specified, ignoring this device.
[ 10.170] (II) This device may have been added with another device file.
[ 10.171] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event18)
[ 10.171] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 10.171] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 10.171] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 10.171] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 10.172] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 41 paused 0
[ 10.172] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 10.172] (**) Option "Device" "/dev/input/event18"
[ 10.172] (**) Option "_source" "server/udev"
[ 10.173] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.173] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.173] (II) event18 - Integrated_Webcam_HD: Integrate: device removed
[ 10.173] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input23/event18"
[ 10.173] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 9)
[ 10.173] (**) Option "xkb_layout" "de"
[ 10.174] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.174] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.175] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event19)
[ 10.175] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 10.175] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 10.175] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 10.175] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 10.176] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 42 paused 0
[ 10.176] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 10.176] (**) Option "Device" "/dev/input/event19"
[ 10.176] (**) Option "_source" "server/udev"
[ 10.177] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.177] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.177] (II) event19 - Integrated_Webcam_HD: Integrate: device removed
[ 10.177] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.2/input/input24/event19"
[ 10.177] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 10)
[ 10.177] (**) Option "xkb_layout" "de"
[ 10.178] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.178] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.179] (II) config/udev: Adding input device DELL097D:00 04F3:311C Mouse (/dev/input/event6)
[ 10.179] (**) DELL097D:00 04F3:311C Mouse: Applying InputClass "evdev pointer catchall"
[ 10.179] (**) DELL097D:00 04F3:311C Mouse: Applying InputClass "libinput pointer catchall"
[ 10.179] (II) Using input driver 'libinput' for 'DELL097D:00 04F3:311C Mouse'
[ 10.179] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 43 paused 0
[ 10.179] (**) DELL097D:00 04F3:311C Mouse: always reports core events
[ 10.179] (**) Option "Device" "/dev/input/event6"
[ 10.179] (**) Option "_source" "server/udev"
[ 10.180] (II) event6 - DELL097D:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 10.181] (II) event6 - DELL097D:00 04F3:311C Mouse: device is a pointer
[ 10.181] (II) event6 - DELL097D:00 04F3:311C Mouse: device removed
[ 10.181] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL097D:00/0018:04F3:311C.0001/input/input12/event6"
[ 10.181] (II) XINPUT: Adding extended input device "DELL097D:00 04F3:311C Mouse" (type: MOUSE, id 11)
[ 10.181] (**) Option "AccelerationScheme" "none"
[ 10.181] (**) DELL097D:00 04F3:311C Mouse: (accel) selected scheme none/0
[ 10.181] (**) DELL097D:00 04F3:311C Mouse: (accel) acceleration factor: 2.000
[ 10.181] (**) DELL097D:00 04F3:311C Mouse: (accel) acceleration threshold: 4
[ 10.182] (II) event6 - DELL097D:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 10.183] (II) event6 - DELL097D:00 04F3:311C Mouse: device is a pointer
[ 10.184] (II) config/udev: Adding input device DELL097D:00 04F3:311C Mouse (/dev/input/mouse0)
[ 10.184] (II) No input driver specified, ignoring this device.
[ 10.184] (II) This device may have been added with another device file.
[ 10.184] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/event7)
[ 10.184] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 10.184] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 10.184] (II) Using input driver 'libinput' for 'DELL097D:00 04F3:311C Touchpad'
[ 10.185] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 44 paused 0
[ 10.185] (**) DELL097D:00 04F3:311C Touchpad: always reports core events
[ 10.185] (**) Option "Device" "/dev/input/event7"
[ 10.185] (**) Option "_source" "server/udev"
[ 10.186] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 10.187] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 10.187] (II) event7 - DELL097D:00 04F3:311C Touchpad: device removed
[ 10.188] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL097D:00/0018:04F3:311C.0001/input/input13/event7"
[ 10.188] (II) XINPUT: Adding extended input device "DELL097D:00 04F3:311C Touchpad" (type: TOUCHPAD, id 12)
[ 10.189] (**) Option "AccelerationScheme" "none"
[ 10.189] (**) DELL097D:00 04F3:311C Touchpad: (accel) selected scheme none/0
[ 10.189] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration factor: 2.000
[ 10.189] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration threshold: 4
[ 10.190] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 10.191] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 10.192] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/mouse1)
[ 10.192] (II) No input driver specified, ignoring this device.
[ 10.192] (II) This device may have been added with another device file.
[ 10.193] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event12)
[ 10.193] (II) No input driver specified, ignoring this device.
[ 10.193] (II) This device may have been added with another device file.
[ 10.193] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 10.193] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 10.194] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 10.194] (II) No input driver specified, ignoring this device.
[ 10.194] (II) This device may have been added with another device file.
[ 10.194] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 10.194] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 10.195] (II) config/udev: Adding input device Intel HID events (/dev/input/event3)
[ 10.195] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 10.195] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 10.195] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 10.195] (II) Using input driver 'libinput' for 'Intel HID events'
[ 10.195] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 45 paused 0
[ 10.195] (**) Intel HID events: always reports core events
[ 10.195] (**) Option "Device" "/dev/input/event3"
[ 10.195] (**) Option "_source" "server/udev"
[ 10.196] (II) event3 - Intel HID events: is tagged by udev as: Keyboard
[ 10.196] (II) event3 - Intel HID events: device is a keyboard
[ 10.196] (II) event3 - Intel HID events: device removed
[ 10.196] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input4/event3"
[ 10.196] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 13)
[ 10.196] (**) Option "xkb_layout" "de"
[ 10.197] (II) event3 - Intel HID events: is tagged by udev as: Keyboard
[ 10.197] (II) event3 - Intel HID events: device is a keyboard
[ 10.197] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event4)
[ 10.197] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 10.197] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 10.197] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 10.197] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 10.198] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[ 10.198] (**) Intel HID 5 button array: always reports core events
[ 10.198] (**) Option "Device" "/dev/input/event4"
[ 10.198] (**) Option "_source" "server/udev"
[ 10.199] (II) event4 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 10.199] (II) event4 - Intel HID 5 button array: device is a keyboard
[ 10.199] (II) event4 - Intel HID 5 button array: device removed
[ 10.199] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input5/event4"
[ 10.199] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 14)
[ 10.199] (**) Option "xkb_layout" "de"
[ 10.200] (II) event4 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 10.200] (II) event4 - Intel HID 5 button array: device is a keyboard
[ 10.200] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 10.200] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 10.200] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 10.200] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 10.200] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 10.201] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 47 paused 0
[ 10.201] (**) Dell WMI hotkeys: always reports core events
[ 10.201] (**) Option "Device" "/dev/input/event8"
[ 10.201] (**) Option "_source" "server/udev"
[ 10.202] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 10.202] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 10.202] (II) event8 - Dell WMI hotkeys: device removed
[ 10.202] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/PNP0C14:03-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input11/event8"
[ 10.202] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
[ 10.202] (**) Option "xkb_layout" "de"
[ 10.203] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 10.203] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 10.204] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 10.204] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 10.204] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 10.204] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 10.204] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 10.205] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 48 paused 0
[ 10.205] (**) AT Translated Set 2 keyboard: always reports core events
[ 10.205] (**) Option "Device" "/dev/input/event2"
[ 10.205] (**) Option "_source" "server/udev"
[ 10.205] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.206] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.206] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 10.206] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 10.207] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[ 10.207] (**) Option "xkb_layout" "de"
[ 10.207] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 10.207] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 10.209] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/event11)
[ 10.209] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 10.209] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "libinput pointer catchall"
[ 10.209] (II) Using input driver 'libinput' for 'PS/2 Logitech Wheel Mouse'
[ 10.209] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 49 paused 0
[ 10.209] (**) PS/2 Logitech Wheel Mouse: always reports core events
[ 10.209] (**) Option "Device" "/dev/input/event11"
[ 10.209] (**) Option "_source" "server/udev"
[ 10.210] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 10.210] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 10.211] (II) event11 - PS/2 Logitech Wheel Mouse: device removed
[ 10.211] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event11"
[ 10.211] (II) XINPUT: Adding extended input device "PS/2 Logitech Wheel Mouse" (type: MOUSE, id 17)
[ 10.211] (**) Option "AccelerationScheme" "none"
[ 10.211] (**) PS/2 Logitech Wheel Mouse: (accel) selected scheme none/0
[ 10.211] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration factor: 2.000
[ 10.211] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration threshold: 4
[ 10.211] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 10.212] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 10.212] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/mouse2)
[ 10.212] (II) No input driver specified, ignoring this device.
[ 10.212] (II) This device may have been added with another device file.
[ 10.213] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 10.213] (II) No input driver specified, ignoring this device.
[ 10.213] (II) This device may have been added with another device file.
[ 10.270] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:02.0/drm/card0 /dev/dri/card0
[ 10.270] xf86: remove device 1 /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 10.270] failed to find screen to remove
[ 10.271] (II) config/udev: removing device Video Bus
[ 10.271] (**) Option "fd" "39"
[ 10.271] (II) event9 - Video Bus: device removed
[ 10.271] (II) UnloadModule: "libinput"
[ 10.271] (II) systemd-logind: releasing fd for 13:73
[ 10.351] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 10.351] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.351] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.351] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.351] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.353] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 52 paused 0
[ 10.353] (**) Video Bus: always reports core events
[ 10.353] (**) Option "Device" "/dev/input/event9"
[ 10.353] (**) Option "_source" "server/udev"
[ 10.355] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 10.355] (II) event9 - Video Bus: device is a keyboard
[ 10.356] (II) event9 - Video Bus: device removed
[ 10.356] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input15/event9"
[ 10.356] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 10.356] (**) Option "xkb_layout" "de"
[ 10.358] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 10.358] (II) event9 - Video Bus: device is a keyboard
[ 10.360] (II) config/udev: removing device Video Bus
[ 10.360] (**) Option "fd" "36"
[ 10.360] (II) event10 - Video Bus: device removed
[ 10.360] (II) UnloadModule: "libinput"
[ 10.360] (II) systemd-logind: releasing fd for 13:74
[ 10.417] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 10.418] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 10.418] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 10.418] (**) Video Bus: Applying InputClass "system-keyboard"
[ 10.418] (II) Using input driver 'libinput' for 'Video Bus'
[ 10.419] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 54 paused 0
[ 10.419] (**) Video Bus: always reports core events
[ 10.419] (**) Option "Device" "/dev/input/event10"
[ 10.419] (**) Option "_source" "server/udev"
[ 10.421] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 10.421] (II) event10 - Video Bus: device is a keyboard
[ 10.422] (II) event10 - Video Bus: device removed
[ 10.422] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16/event10"
[ 10.422] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 10.422] (**) Option "xkb_layout" "de"
[ 10.424] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 10.424] (II) event10 - Video Bus: device is a keyboard
[ 10.425] (II) config/udev: removing device DELL097D:00 04F3:311C Touchpad
[ 10.425] (**) Option "fd" "44"
[ 10.425] (II) event7 - DELL097D:00 04F3:311C Touchpad: device removed
[ 10.425] (II) UnloadModule: "libinput"
[ 10.425] (II) systemd-logind: releasing fd for 13:71
[ 10.484] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/event7)
[ 10.484] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 10.484] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 10.484] (II) Using input driver 'libinput' for 'DELL097D:00 04F3:311C Touchpad'
[ 10.486] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 44 paused 0
[ 10.486] (**) DELL097D:00 04F3:311C Touchpad: always reports core events
[ 10.486] (**) Option "Device" "/dev/input/event7"
[ 10.486] (**) Option "_source" "server/udev"
[ 10.489] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 10.492] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 10.492] (II) event7 - DELL097D:00 04F3:311C Touchpad: device removed
[ 10.493] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL097D:00/0018:04F3:311C.0001/input/input13/event7"
[ 10.493] (II) XINPUT: Adding extended input device "DELL097D:00 04F3:311C Touchpad" (type: TOUCHPAD, id 12)
[ 10.496] (**) Option "AccelerationScheme" "none"
[ 10.496] (**) DELL097D:00 04F3:311C Touchpad: (accel) selected scheme none/0
[ 10.496] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration factor: 2.000
[ 10.496] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration threshold: 4
[ 10.498] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 10.502] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 10.504] (II) config/udev: Adding input device DELL097D:00 04F3:311C Mouse (/dev/input/mouse0)
[ 10.504] (II) No input driver specified, ignoring this device.
[ 10.504] (II) This device may have been added with another device file.
[ 10.505] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/mouse1)
[ 10.505] (II) No input driver specified, ignoring this device.
[ 10.505] (II) This device may have been added with another device file.
[ 10.506] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/mouse2)
[ 10.506] (II) No input driver specified, ignoring this device.
[ 10.506] (II) This device may have been added with another device file.
[ 10.506] (II) config/udev: removing device PS/2 Logitech Wheel Mouse
[ 10.506] (**) Option "fd" "49"
[ 10.506] (II) event11 - PS/2 Logitech Wheel Mouse: device removed
[ 10.506] (II) UnloadModule: "libinput"
[ 10.506] (II) systemd-logind: releasing fd for 13:75
[ 10.577] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/event11)
[ 10.578] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 10.578] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "libinput pointer catchall"
[ 10.578] (II) Using input driver 'libinput' for 'PS/2 Logitech Wheel Mouse'
[ 10.579] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 49 paused 0
[ 10.579] (**) PS/2 Logitech Wheel Mouse: always reports core events
[ 10.579] (**) Option "Device" "/dev/input/event11"
[ 10.579] (**) Option "_source" "server/udev"
[ 10.581] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 10.581] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 10.582] (II) event11 - PS/2 Logitech Wheel Mouse: device removed
[ 10.582] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event11"
[ 10.582] (II) XINPUT: Adding extended input device "PS/2 Logitech Wheel Mouse" (type: MOUSE, id 17)
[ 10.582] (**) Option "AccelerationScheme" "none"
[ 10.582] (**) PS/2 Logitech Wheel Mouse: (accel) selected scheme none/0
[ 10.582] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration factor: 2.000
[ 10.582] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration threshold: 4
[ 10.584] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 10.584] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 10.585] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 10.585] (II) No input driver specified, ignoring this device.
[ 10.585] (II) This device may have been added with another device file.
[ 10.586] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 10.586] (II) No input driver specified, ignoring this device.
[ 10.586] (II) This device may have been added with another device file.
[ 10.586] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 10.586] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 10.587] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event12)
[ 10.587] (II) No input driver specified, ignoring this device.
[ 10.587] (II) This device may have been added with another device file.
[ 10.587] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 10.587] (II) config/udev: removing device Integrated_Webcam_HD: Integrate
[ 10.587] (**) Option "fd" "42"
[ 10.587] (II) event19 - Integrated_Webcam_HD: Integrate: device removed
[ 10.588] (II) UnloadModule: "libinput"
[ 10.588] (II) systemd-logind: releasing fd for 13:83
[ 10.671] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event19)
[ 10.671] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 10.671] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 10.671] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 10.671] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 10.673] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 42 paused 0
[ 10.673] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 10.673] (**) Option "Device" "/dev/input/event19"
[ 10.673] (**) Option "_source" "server/udev"
[ 10.676] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.676] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.676] (II) event19 - Integrated_Webcam_HD: Integrate: device removed
[ 10.677] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.2/input/input24/event19"
[ 10.677] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 10)
[ 10.677] (**) Option "xkb_layout" "de"
[ 10.679] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.679] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.680] (II) config/udev: removing device Integrated_Webcam_HD: Integrate
[ 10.680] (**) Option "fd" "41"
[ 10.680] (II) event18 - Integrated_Webcam_HD: Integrate: device removed
[ 10.681] (II) UnloadModule: "libinput"
[ 10.681] (II) systemd-logind: releasing fd for 13:82
[ 10.751] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event18)
[ 10.751] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 10.751] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 10.751] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 10.751] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 10.753] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 41 paused 0
[ 10.753] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 10.753] (**) Option "Device" "/dev/input/event18"
[ 10.753] (**) Option "_source" "server/udev"
[ 10.756] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.756] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 10.756] (II) event18 - Integrated_Webcam_HD: Integrate: device removed
[ 10.757] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input23/event18"
[ 10.757] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 9)
[ 10.757] (**) Option "xkb_layout" "de"
[ 10.759] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 10.759] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 11.218] (II) modeset(0): EDID vendor "SHP", prod id 5329
[ 11.218] (II) modeset(0): Printing DDC gathered Modelines:
[ 11.218] (II) modeset(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (74.0 kHz eP)
[ 11.218] (II) modeset(0): Modeline "1920x1200"x0.0 123.20 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (59.2 kHz e)
[ 18.115] (**) Option "fd" "40"
[ 18.116] (II) event1 - Power Button: device removed
[ 18.116] (**) Option "fd" "43"
[ 18.116] (II) event6 - DELL097D:00 04F3:311C Mouse: device removed
[ 18.116] (**) Option "fd" "45"
[ 18.116] (II) event3 - Intel HID events: device removed
[ 18.117] (**) Option "fd" "46"
[ 18.117] (II) event4 - Intel HID 5 button array: device removed
[ 18.117] (**) Option "fd" "47"
[ 18.117] (II) event8 - Dell WMI hotkeys: device removed
[ 18.117] (**) Option "fd" "48"
[ 18.118] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 18.118] (**) Option "fd" "52"
[ 18.118] (II) event9 - Video Bus: device removed
[ 18.118] (**) Option "fd" "54"
[ 18.118] (II) event10 - Video Bus: device removed
[ 18.119] (**) Option "fd" "44"
[ 18.119] (II) event7 - DELL097D:00 04F3:311C Touchpad: device removed
[ 18.119] (**) Option "fd" "49"
[ 18.119] (II) event11 - PS/2 Logitech Wheel Mouse: device removed
[ 18.119] (**) Option "fd" "42"
[ 18.119] (II) event19 - Integrated_Webcam_HD: Integrate: device removed
[ 18.120] (**) Option "fd" "41"
[ 18.120] (II) event18 - Integrated_Webcam_HD: Integrate: device removed
[ 18.120] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 18.132] (EE) modeset(0): failed to set mode: Permission denied
[ 18.133] (II) systemd-logind: got pause for 13:83
[ 18.133] (II) systemd-logind: got pause for 13:68
[ 18.133] (II) systemd-logind: got pause for 13:72
[ 18.133] (II) systemd-logind: got pause for 13:66
[ 18.133] (II) systemd-logind: got pause for 13:67
[ 18.133] (II) systemd-logind: got pause for 13:74
[ 18.133] (II) systemd-logind: got pause for 13:71
[ 18.133] (II) systemd-logind: got pause for 13:82
[ 18.133] (II) systemd-logind: got pause for 13:70
[ 18.133] (II) systemd-logind: got pause for 13:65
[ 18.133] (II) systemd-logind: got pause for 13:73
[ 18.133] (II) systemd-logind: got pause for 13:75
[ 22.630] (II) UnloadModule: "libinput"
[ 22.630] (II) systemd-logind: releasing fd for 13:82
[ 22.656] (II) UnloadModule: "libinput"
[ 22.656] (II) systemd-logind: releasing fd for 13:83
[ 22.684] (II) UnloadModule: "libinput"
[ 22.684] (II) systemd-logind: releasing fd for 13:75
[ 22.710] (II) UnloadModule: "libinput"
[ 22.710] (II) systemd-logind: releasing fd for 13:71
[ 22.737] (II) UnloadModule: "libinput"
[ 22.737] (II) systemd-logind: releasing fd for 13:74
[ 22.777] (II) UnloadModule: "libinput"
[ 22.777] (II) systemd-logind: releasing fd for 13:73
[ 22.817] (II) UnloadModule: "libinput"
[ 22.818] (II) systemd-logind: releasing fd for 13:66
[ 22.857] (II) UnloadModule: "libinput"
[ 22.857] (II) systemd-logind: releasing fd for 13:72
[ 22.897] (II) UnloadModule: "libinput"
[ 22.897] (II) systemd-logind: releasing fd for 13:68
[ 22.951] (II) UnloadModule: "libinput"
[ 22.951] (II) systemd-logind: releasing fd for 13:67
[ 22.991] (II) UnloadModule: "libinput"
[ 22.991] (II) systemd-logind: releasing fd for 13:70
[ 23.031] (II) UnloadModule: "libinput"
[ 23.032] (II) systemd-logind: releasing fd for 13:65
[ 23.082] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 23.085] (II) Server terminated successfully (0). Closing log file.
1
[ 18.165] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 18.165] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 18.166] (--) Log file renamed from "/var/log/Xorg.pid-1541.log" to "/var/log/Xorg.1.log"
[ 18.166] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 18.167]
[ 18.167] Build Operating System: Linux Manjaro Linux
[ 18.167] Current Operating System: Linux xps-manjaro 5.13.12-1-MANJARO #1 SMP PREEMPT Wed Aug 18 08:06:42 UTC 2021 x86_64
[ 18.167] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=a92fb0d1-e6fd-4a36-8570-9176b77c4488 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 18.167] Build Date: 24 August 2021 10:21:29AM
[ 18.167]
[ 18.167] Current version of pixman: 0.40.0
[ 18.167] Before reporting problems, check http://wiki.x.org
[ 18.167] Markers: (--) probed, (**) from config file, (==) default setting,
[ 18.167] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Aug 28 11:47:14 2021
[ 18.168] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 18.168] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 18.168] (==) ServerLayout "layout"
[ 18.168] (==) No screen section available. Using defaults.
[ 18.168] (**) |-->Screen "Default Screen Section" (0)
[ 18.168] (**) | |-->Monitor "<default monitor>"
[ 18.169] (==) No monitor specified for screen "Default Screen Section".
[ 18.169] (==) Automatically adding devices
[ 18.169] (==) Automatically enabling devices
[ 18.169] (==) Automatically adding GPU devices
[ 18.169] (==) Automatically binding GPU devices
[ 18.169] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 18.169] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 18.169] Entry deleted from font path.
[ 18.169] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 18.169] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 18.169] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 18.169] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 18.169] (==) FontPath set to:
[ 18.169] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 18.169] (II) The server relies on udev to provide the list of input devices.
[ 18.169] (II) Module ABI versions:
[ 18.169] X.Org ANSI C Emulation: 0.4
[ 18.169] X.Org Video Driver: 24.1
[ 18.169] X.Org XInput driver : 24.1
[ 18.169] X.Org Server Extension : 10.0
[ 18.171] (++) using VT number 2
[ 18.176] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[ 18.178] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 18.179] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 18.180] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 18.181] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 18.185] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 18.185] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 18.189] (--) PCI:*(0@0:2:0) 8086:9bc4:1028:097d rev 5, Mem @ 0x604a000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 18.189] (--) PCI: (1@0:0:0) 10de:1f95:1028:097d rev 161, Mem @ 0xb3000000/16777216, 0x70000000/268435456, 0x80000000/33554432, I/O @ 0x00003000/128
[ 18.190] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 18.190] (II) LoadModule: "glx"
[ 18.190] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 18.193] (II) Module glx: vendor="X.Org Foundation"
[ 18.193] compiled for 1.20.13, module version = 1.0.0
[ 18.193] ABI class: X.Org Server Extension, version 10.0
[ 18.193] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 18.193] loading driver: modesetting
[ 18.193] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 18.193] loading driver: nvidia
[ 18.194] (==) Matched modesetting as autoconfigured driver 0
[ 18.194] (==) Matched nvidia as autoconfigured driver 1
[ 18.194] (==) Matched nouveau as autoconfigured driver 2
[ 18.195] (==) Matched nv as autoconfigured driver 3
[ 18.195] (==) Matched fbdev as autoconfigured driver 4
[ 18.195] (==) Matched vesa as autoconfigured driver 5
[ 18.195] (==) Assigned the driver to the xf86ConfigLayout
[ 18.195] (II) LoadModule: "modesetting"
[ 18.195] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 18.196] (II) Module modesetting: vendor="X.Org Foundation"
[ 18.196] compiled for 1.20.13, module version = 1.20.13
[ 18.196] Module class: X.Org Video Driver
[ 18.196] ABI class: X.Org Video Driver, version 24.1
[ 18.196] (II) LoadModule: "nvidia"
[ 18.196] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 18.197] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 18.197] compiled for 1.6.99.901, module version = 1.0.0
[ 18.197] Module class: X.Org Video Driver
[ 18.197] (II) LoadModule: "nouveau"
[ 18.198] (WW) Warning, couldn't open module nouveau
[ 18.198] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 18.198] (II) LoadModule: "nv"
[ 18.198] (WW) Warning, couldn't open module nv
[ 18.198] (EE) Failed to load module "nv" (module does not exist, 0)
[ 18.198] (II) LoadModule: "fbdev"
[ 18.199] (WW) Warning, couldn't open module fbdev
[ 18.199] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 18.199] (II) LoadModule: "vesa"
[ 18.200] (WW) Warning, couldn't open module vesa
[ 18.200] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 18.200] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 18.200] (II) NVIDIA dlloader X Driver 470.63.01 Tue Aug 3 20:37:27 UTC 2021
[ 18.200] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 18.200] (II) modeset(0): using drv /dev/dri/card0
[ 18.200] (II) systemd-logind: releasing fd for 226:1
[ 18.202] (II) Loading sub module "fb"
[ 18.202] (II) LoadModule: "fb"
[ 18.202] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.202] (II) Module fb: vendor="X.Org Foundation"
[ 18.202] compiled for 1.20.13, module version = 1.0.0
[ 18.202] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.202] (II) Loading sub module "wfb"
[ 18.202] (II) LoadModule: "wfb"
[ 18.203] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 18.203] (II) Module wfb: vendor="X.Org Foundation"
[ 18.203] compiled for 1.20.13, module version = 1.0.0
[ 18.203] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.203] (II) Loading sub module "ramdac"
[ 18.203] (II) LoadModule: "ramdac"
[ 18.203] (II) Module "ramdac" already built-in
[ 18.204] (II) modeset(0): Creating default Display subsection in Screen section
[ 18.204] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 18.204] (==) modeset(0): RGB weight 888
[ 18.204] (==) modeset(0): Default visual is TrueColor
[ 18.204] (II) Loading sub module "glamoregl"
[ 18.204] (II) LoadModule: "glamoregl"
[ 18.205] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 18.214] (II) Module glamoregl: vendor="X.Org Foundation"
[ 18.214] compiled for 1.20.13, module version = 1.0.1
[ 18.214] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.297] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (CML GT2)
[ 18.297] (II) modeset(0): glamor initialized
[ 18.299] (II) modeset(0): Output eDP-1 has no monitor section
[ 18.299] (II) modeset(0): Output DP-1 has no monitor section
[ 18.299] (II) modeset(0): Output DP-2 has no monitor section
[ 18.299] (II) modeset(0): Output DP-3 has no monitor section
[ 18.300] (II) modeset(0): EDID for output eDP-1
[ 18.300] (II) modeset(0): Manufacturer: SHP Model: 14d1 Serial#: 0
[ 18.300] (II) modeset(0): Year: 2020 Week: 4
[ 18.300] (II) modeset(0): EDID Version: 1.4
[ 18.300] (II) modeset(0): Digital Display Input
[ 18.300] (II) modeset(0): 8 bits per channel
[ 18.300] (II) modeset(0): Digital interface is DisplayPort
[ 18.300] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 21
[ 18.300] (II) modeset(0): Gamma: 2.20
[ 18.300] (II) modeset(0): No DPMS capabilities specified
[ 18.300] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 18.300] (II) modeset(0): Default color space is primary color space
[ 18.300] (II) modeset(0): First detailed timing is preferred mode
[ 18.300] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 18.301] (II) modeset(0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
[ 18.301] (II) modeset(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
[ 18.301] (II) modeset(0): Manufacturer's mask: 0
[ 18.301] (II) modeset(0): Supported detailed timing:
[ 18.301] (II) modeset(0): clock: 154.0 MHz Image Size: 336 x 210 mm
[ 18.301] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 18.301] (II) modeset(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 18.301] (II) modeset(0): clock: 123.2 MHz Image Size: 336 x 210 mm
[ 18.301] (II) modeset(0): Unknown vendor-specific block 0
[ 18.301] (II) modeset(0): EDID (in hex):
[ 18.301] (II) modeset(0): 00ffffffffffff004d10d11400000000
[ 18.301] (II) modeset(0): 041e0104a52215780ede50a3544c9926
[ 18.301] (II) modeset(0): 0f505400000001010101010101010101
[ 18.301] (II) modeset(0): 010101010101283c80a070b023403020
[ 18.301] (II) modeset(0): 360050d210000018203080a070b02340
[ 18.301] (II) modeset(0): 3020360050d210000018000000fe0046
[ 18.301] (II) modeset(0): 4b52314b804c513135364e3100000000
[ 18.301] (II) modeset(0): 0002410332001200000a010a2020003a
[ 18.301] (II) modeset(0): Printing probed modes for output eDP-1
[ 18.301] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (74.0 kHz eP)
[ 18.301] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 18.301] (II) modeset(0): Modeline "1920x1200"x48.0 123.20 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (59.2 kHz e)
[ 18.301] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 18.301] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 18.301] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 18.301] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 18.301] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 18.301] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 18.301] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 18.301] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 18.301] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 18.301] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 18.301] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 18.301] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 18.301] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 18.301] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 18.301] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 18.301] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 18.301] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 18.301] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 18.301] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 18.302] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 18.302] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 18.302] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 18.302] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 18.302] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 18.302] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 18.302] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 18.302] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 18.302] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 18.302] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 18.302] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 18.302] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 18.302] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 18.302] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 18.302] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 18.302] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 18.302] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 18.302] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 18.302] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 18.302] (II) modeset(0): EDID for output DP-1
[ 18.302] (II) modeset(0): EDID for output DP-2
[ 18.302] (II) modeset(0): EDID for output DP-3
[ 18.302] (II) modeset(0): Output eDP-1 connected
[ 18.302] (II) modeset(0): Output DP-1 disconnected
[ 18.302] (II) modeset(0): Output DP-2 disconnected
[ 18.302] (II) modeset(0): Output DP-3 disconnected
[ 18.302] (II) modeset(0): Using exact sizes for initial modes
[ 18.302] (II) modeset(0): Output eDP-1 using initial mode 1920x1200 +0+0
[ 18.302] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.302] (==) modeset(0): DPI set to (96, 96)
[ 18.302] (II) Loading sub module "fb"
[ 18.302] (II) LoadModule: "fb"
[ 18.302] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.302] (II) Module fb: vendor="X.Org Foundation"
[ 18.302] compiled for 1.20.13, module version = 1.0.0
[ 18.302] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.302] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 18.302] (==) NVIDIA(G0): RGB weight 888
[ 18.302] (==) NVIDIA(G0): Default visual is TrueColor
[ 18.302] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.302] (**) Option "AllowNVIDIAGpuScreens"
[ 18.302] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 18.302] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 18.302] (**) NVIDIA(G0): Enabling 2D acceleration
[ 18.302] (II) Loading sub module "glxserver_nvidia"
[ 18.302] (II) LoadModule: "glxserver_nvidia"
[ 18.302] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 18.309] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 18.309] compiled for 1.6.99.901, module version = 1.0.0
[ 18.309] Module class: X.Org Server Extension
[ 18.309] (II) NVIDIA GLX Module 470.63.01 Tue Aug 3 20:35:52 UTC 2021
[ 18.309] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 18.311] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1650 Ti (TU117-A) at PCI:1:0:0
[ 18.311] (II) NVIDIA(G0): (GPU-0)
[ 18.311] (--) NVIDIA(G0): Memory: 4194304 kBytes
[ 18.311] (--) NVIDIA(G0): VideoBIOS: 90.17.42.00.3a
[ 18.311] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 18.311] (II) NVIDIA(G0): Validated MetaModes:
[ 18.311] (II) NVIDIA(G0): "NULL"
[ 18.311] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 18.311] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 18.311] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 18.383] (==) modeset(0): Backing store enabled
[ 18.383] (==) modeset(0): Silken mouse disabled
[ 18.468] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 18.468] (==) modeset(0): DPMS enabled
[ 18.468] (II) modeset(0): [DRI2] Setup complete
[ 18.468] (II) modeset(0): [DRI2] DRI driver: iris
[ 18.468] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 18.469] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 18.469] (II) NVIDIA: access.
[ 18.484] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 18.484] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 18.484] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 18.485] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 18.485] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 18.485] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 18.485] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 18.485] (II) NVIDIA(G0): Config Options in the README.
[ 18.545] (II) NVIDIA(G0): Setting mode "NULL"
[ 18.554] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 18.554] (==) NVIDIA(G0): Backing store enabled
[ 18.554] (==) NVIDIA(G0): Silken mouse disabled
[ 18.554] (==) NVIDIA(G0): DPMS enabled
[ 18.555] (II) Loading sub module "dri2"
[ 18.555] (II) LoadModule: "dri2"
[ 18.555] (II) Module "dri2" already built-in
[ 18.555] (II) NVIDIA(G0): [DRI2] Setup complete
[ 18.555] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 18.555] (II) Initializing extension Generic Event Extension
[ 18.555] (II) Initializing extension SHAPE
[ 18.555] (II) Initializing extension MIT-SHM
[ 18.555] (II) Initializing extension XInputExtension
[ 18.555] (II) Initializing extension XTEST
[ 18.555] (II) Initializing extension BIG-REQUESTS
[ 18.555] (II) Initializing extension SYNC
[ 18.555] (II) Initializing extension XKEYBOARD
[ 18.555] (II) Initializing extension XC-MISC
[ 18.555] (II) Initializing extension SECURITY
[ 18.555] (II) Initializing extension XFIXES
[ 18.555] (II) Initializing extension RENDER
[ 18.555] (II) Initializing extension RANDR
[ 18.555] (II) Initializing extension COMPOSITE
[ 18.555] (II) Initializing extension DAMAGE
[ 18.555] (II) Initializing extension MIT-SCREEN-SAVER
[ 18.555] (II) Initializing extension DOUBLE-BUFFER
[ 18.555] (II) Initializing extension RECORD
[ 18.555] (II) Initializing extension DPMS
[ 18.556] (II) Initializing extension Present
[ 18.556] (II) Initializing extension DRI3
[ 18.556] (II) Initializing extension X-Resource
[ 18.556] (II) Initializing extension XVideo
[ 18.556] (II) Initializing extension XVideo-MotionCompensation
[ 18.556] (II) Initializing extension GLX
[ 18.556] (II) Indirect GLX disabled.
[ 18.571] (II) AIGLX: Loaded and initialized iris
[ 18.571] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 18.571] (II) Initializing extension XFree86-VidModeExtension
[ 18.571] (II) Initializing extension XFree86-DGA
[ 18.571] (II) Initializing extension XFree86-DRI
[ 18.571] (II) Initializing extension DRI2
[ 18.571] (II) Initializing extension NV-GLX
[ 18.571] (II) Initializing extension NV-CONTROL
[ 18.572] (II) modeset(0): Damage tracking initialized
[ 18.572] (II) modeset(0): Setting screen physical size to 508 x 317
[ 18.633] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 18.633] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 18.633] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 18.633] (**) Video Bus: Applying InputClass "system-keyboard"
[ 18.633] (II) LoadModule: "libinput"
[ 18.633] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 18.635] (II) Module libinput: vendor="X.Org Foundation"
[ 18.635] compiled for 1.20.11, module version = 1.1.0
[ 18.635] Module class: X.Org XInput Driver
[ 18.635] ABI class: X.Org XInput driver, version 24.1
[ 18.635] (II) Using input driver 'libinput' for 'Video Bus'
[ 18.636] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 37 paused 0
[ 18.636] (**) Video Bus: always reports core events
[ 18.636] (**) Option "Device" "/dev/input/event10"
[ 18.636] (**) Option "_source" "server/udev"
[ 18.639] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 18.639] (II) event10 - Video Bus: device is a keyboard
[ 18.639] (II) event10 - Video Bus: device removed
[ 18.639] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16/event10"
[ 18.639] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 18.639] (**) Option "xkb_layout" "de"
[ 18.667] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 18.668] (II) event10 - Video Bus: device is a keyboard
[ 18.669] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 18.669] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 18.669] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 18.669] (**) Video Bus: Applying InputClass "system-keyboard"
[ 18.669] (II) Using input driver 'libinput' for 'Video Bus'
[ 18.670] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 40 paused 0
[ 18.670] (**) Video Bus: always reports core events
[ 18.670] (**) Option "Device" "/dev/input/event9"
[ 18.670] (**) Option "_source" "server/udev"
[ 18.672] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 18.672] (II) event9 - Video Bus: device is a keyboard
[ 18.672] (II) event9 - Video Bus: device removed
[ 18.672] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input15/event9"
[ 18.672] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 18.672] (**) Option "xkb_layout" "de"
[ 18.674] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 18.674] (II) event9 - Video Bus: device is a keyboard
[ 18.675] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 18.675] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 18.675] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 18.675] (**) Power Button: Applying InputClass "system-keyboard"
[ 18.675] (II) Using input driver 'libinput' for 'Power Button'
[ 18.677] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 41 paused 0
[ 18.677] (**) Power Button: always reports core events
[ 18.677] (**) Option "Device" "/dev/input/event1"
[ 18.677] (**) Option "_source" "server/udev"
[ 18.678] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 18.678] (II) event1 - Power Button: device is a keyboard
[ 18.679] (II) event1 - Power Button: device removed
[ 18.679] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 18.679] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 18.679] (**) Option "xkb_layout" "de"
[ 18.681] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 18.681] (II) event1 - Power Button: device is a keyboard
[ 18.682] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 18.682] (II) No input driver specified, ignoring this device.
[ 18.682] (II) This device may have been added with another device file.
[ 18.684] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event18)
[ 18.684] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 18.684] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 18.684] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 18.684] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 18.686] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 42 paused 0
[ 18.686] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 18.686] (**) Option "Device" "/dev/input/event18"
[ 18.686] (**) Option "_source" "server/udev"
[ 18.688] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 18.688] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 18.689] (II) event18 - Integrated_Webcam_HD: Integrate: device removed
[ 18.689] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input23/event18"
[ 18.689] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 9)
[ 18.689] (**) Option "xkb_layout" "de"
[ 18.691] (II) event18 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 18.692] (II) event18 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 18.693] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event19)
[ 18.693] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 18.693] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 18.693] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 18.693] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 18.695] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 43 paused 0
[ 18.695] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 18.695] (**) Option "Device" "/dev/input/event19"
[ 18.695] (**) Option "_source" "server/udev"
[ 18.697] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 18.697] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 18.698] (II) event19 - Integrated_Webcam_HD: Integrate: device removed
[ 18.698] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.2/input/input24/event19"
[ 18.698] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 10)
[ 18.698] (**) Option "xkb_layout" "de"
[ 18.701] (II) event19 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 18.701] (II) event19 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 18.702] (II) config/udev: Adding input device DELL097D:00 04F3:311C Mouse (/dev/input/event6)
[ 18.702] (**) DELL097D:00 04F3:311C Mouse: Applying InputClass "evdev pointer catchall"
[ 18.702] (**) DELL097D:00 04F3:311C Mouse: Applying InputClass "libinput pointer catchall"
[ 18.702] (II) Using input driver 'libinput' for 'DELL097D:00 04F3:311C Mouse'
[ 18.704] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 44 paused 0
[ 18.704] (**) DELL097D:00 04F3:311C Mouse: always reports core events
[ 18.704] (**) Option "Device" "/dev/input/event6"
[ 18.704] (**) Option "_source" "server/udev"
[ 18.706] (II) event6 - DELL097D:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 18.707] (II) event6 - DELL097D:00 04F3:311C Mouse: device is a pointer
[ 18.708] (II) event6 - DELL097D:00 04F3:311C Mouse: device removed
[ 18.708] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL097D:00/0018:04F3:311C.0001/input/input12/event6"
[ 18.708] (II) XINPUT: Adding extended input device "DELL097D:00 04F3:311C Mouse" (type: MOUSE, id 11)
[ 18.709] (**) Option "AccelerationScheme" "none"
[ 18.709] (**) DELL097D:00 04F3:311C Mouse: (accel) selected scheme none/0
[ 18.709] (**) DELL097D:00 04F3:311C Mouse: (accel) acceleration factor: 2.000
[ 18.709] (**) DELL097D:00 04F3:311C Mouse: (accel) acceleration threshold: 4
[ 18.711] (II) event6 - DELL097D:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 18.712] (II) event6 - DELL097D:00 04F3:311C Mouse: device is a pointer
[ 18.715] (II) config/udev: Adding input device DELL097D:00 04F3:311C Mouse (/dev/input/mouse0)
[ 18.715] (II) No input driver specified, ignoring this device.
[ 18.715] (II) This device may have been added with another device file.
[ 18.716] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/event7)
[ 18.716] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 18.716] (**) DELL097D:00 04F3:311C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 18.716] (II) Using input driver 'libinput' for 'DELL097D:00 04F3:311C Touchpad'
[ 18.718] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[ 18.718] (**) DELL097D:00 04F3:311C Touchpad: always reports core events
[ 18.718] (**) Option "Device" "/dev/input/event7"
[ 18.718] (**) Option "_source" "server/udev"
[ 18.720] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 18.723] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 18.724] (II) event7 - DELL097D:00 04F3:311C Touchpad: device removed
[ 18.724] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL097D:00/0018:04F3:311C.0001/input/input13/event7"
[ 18.725] (II) XINPUT: Adding extended input device "DELL097D:00 04F3:311C Touchpad" (type: TOUCHPAD, id 12)
[ 18.728] (**) Option "AccelerationScheme" "none"
[ 18.728] (**) DELL097D:00 04F3:311C Touchpad: (accel) selected scheme none/0
[ 18.728] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration factor: 2.000
[ 18.728] (**) DELL097D:00 04F3:311C Touchpad: (accel) acceleration threshold: 4
[ 18.730] (II) event7 - DELL097D:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 18.733] (II) event7 - DELL097D:00 04F3:311C Touchpad: device is a touchpad
[ 18.735] (II) config/udev: Adding input device DELL097D:00 04F3:311C Touchpad (/dev/input/mouse1)
[ 18.735] (II) No input driver specified, ignoring this device.
[ 18.735] (II) This device may have been added with another device file.
[ 18.736] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event12)
[ 18.737] (II) No input driver specified, ignoring this device.
[ 18.737] (II) This device may have been added with another device file.
[ 18.737] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 18.738] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 18.738] (II) No input driver specified, ignoring this device.
[ 18.738] (II) This device may have been added with another device file.
[ 18.739] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 18.739] (II) No input driver specified, ignoring this device.
[ 18.739] (II) This device may have been added with another device file.
[ 18.740] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 18.740] (II) No input driver specified, ignoring this device.
[ 18.740] (II) This device may have been added with another device file.
[ 18.741] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 18.741] (II) No input driver specified, ignoring this device.
[ 18.741] (II) This device may have been added with another device file.
[ 18.741] (II) config/udev: Adding input device Intel HID events (/dev/input/event3)
[ 18.741] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 18.742] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 18.742] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 18.742] (II) Using input driver 'libinput' for 'Intel HID events'
[ 18.743] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 46 paused 0
[ 18.743] (**) Intel HID events: always reports core events
[ 18.743] (**) Option "Device" "/dev/input/event3"
[ 18.743] (**) Option "_source" "server/udev"
[ 18.744] (II) event3 - Intel HID events: is tagged by udev as: Keyboard
[ 18.745] (II) event3 - Intel HID events: device is a keyboard
[ 18.745] (II) event3 - Intel HID events: device removed
[ 18.745] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input4/event3"
[ 18.745] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 13)
[ 18.745] (**) Option "xkb_layout" "de"
[ 18.747] (II) event3 - Intel HID events: is tagged by udev as: Keyboard
[ 18.747] (II) event3 - Intel HID events: device is a keyboard
[ 18.748] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event4)
[ 18.748] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 18.748] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 18.748] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 18.748] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 18.750] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 47 paused 0
[ 18.750] (**) Intel HID 5 button array: always reports core events
[ 18.750] (**) Option "Device" "/dev/input/event4"
[ 18.750] (**) Option "_source" "server/udev"
[ 18.751] (II) event4 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 18.751] (II) event4 - Intel HID 5 button array: device is a keyboard
[ 18.752] (II) event4 - Intel HID 5 button array: device removed
[ 18.752] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input5/event4"
[ 18.752] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 14)
[ 18.752] (**) Option "xkb_layout" "de"
[ 18.754] (II) event4 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 18.754] (II) event4 - Intel HID 5 button array: device is a keyboard
[ 18.755] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 18.755] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 18.756] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 18.756] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 18.756] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 18.757] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 48 paused 0
[ 18.757] (**) Dell WMI hotkeys: always reports core events
[ 18.757] (**) Option "Device" "/dev/input/event8"
[ 18.757] (**) Option "_source" "server/udev"
[ 18.759] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 18.759] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 18.760] (II) event8 - Dell WMI hotkeys: device removed
[ 18.760] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/PNP0C14:03-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input11/event8"
[ 18.760] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
[ 18.760] (**) Option "xkb_layout" "de"
[ 18.762] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 18.763] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 18.765] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 18.765] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 18.765] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 18.765] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 18.765] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 18.766] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 49 paused 0
[ 18.766] (**) AT Translated Set 2 keyboard: always reports core events
[ 18.766] (**) Option "Device" "/dev/input/event2"
[ 18.766] (**) Option "_source" "server/udev"
[ 18.768] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 18.768] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 18.771] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 18.771] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 18.771] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[ 18.771] (**) Option "xkb_layout" "de"
[ 18.773] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 18.773] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 18.776] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/event11)
[ 18.776] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 18.776] (**) PS/2 Logitech Wheel Mouse: Applying InputClass "libinput pointer catchall"
[ 18.776] (II) Using input driver 'libinput' for 'PS/2 Logitech Wheel Mouse'
[ 18.778] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 50 paused 0
[ 18.778] (**) PS/2 Logitech Wheel Mouse: always reports core events
[ 18.778] (**) Option "Device" "/dev/input/event11"
[ 18.778] (**) Option "_source" "server/udev"
[ 18.780] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 18.780] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 18.781] (II) event11 - PS/2 Logitech Wheel Mouse: device removed
[ 18.781] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event11"
[ 18.781] (II) XINPUT: Adding extended input device "PS/2 Logitech Wheel Mouse" (type: MOUSE, id 17)
[ 18.781] (**) Option "AccelerationScheme" "none"
[ 18.781] (**) PS/2 Logitech Wheel Mouse: (accel) selected scheme none/0
[ 18.781] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration factor: 2.000
[ 18.781] (**) PS/2 Logitech Wheel Mouse: (accel) acceleration threshold: 4
[ 18.783] (II) event11 - PS/2 Logitech Wheel Mouse: is tagged by udev as: Mouse
[ 18.783] (II) event11 - PS/2 Logitech Wheel Mouse: device is a pointer
[ 18.785] (II) config/udev: Adding input device PS/2 Logitech Wheel Mouse (/dev/input/mouse2)
[ 18.785] (II) No input driver specified, ignoring this device.
[ 18.785] (II) This device may have been added with another device file.
[ 18.786] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 18.786] (II) No input driver specified, ignoring this device.
[ 18.786] (II) This device may have been added with another device file.
[ 19.575] (II) modeset(0): EDID vendor "SHP", prod id 5329
[ 19.575] (II) modeset(0): Printing DDC gathered Modelines:
[ 19.575] (II) modeset(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (74.0 kHz eP)
[ 19.575] (II) modeset(0): Modeline "1920x1200"x0.0 123.20 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (59.2 kHz e)
[ 25.333] (II) config/udev: Adding input device MX Anywhere 2 Mouse (/dev/input/mouse3)
[ 25.333] (II) No input driver specified, ignoring this device.
[ 25.333] (II) This device may have been added with another device file.
[ 25.392] (II) config/udev: Adding input device MX Anywhere 2 Mouse (/dev/input/event21)
[ 25.392] (**) MX Anywhere 2 Mouse: Applying InputClass "evdev pointer catchall"
[ 25.392] (**) MX Anywhere 2 Mouse: Applying InputClass "libinput pointer catchall"
[ 25.392] (II) Using input driver 'libinput' for 'MX Anywhere 2 Mouse'
[ 25.394] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 74 paused 0
[ 25.394] (**) MX Anywhere 2 Mouse: always reports core events
[ 25.394] (**) Option "Device" "/dev/input/event21"
[ 25.394] (**) Option "_source" "server/udev"
[ 25.396] (II) event21 - MX Anywhere 2 Mouse: is tagged by udev as: Mouse
[ 25.397] (II) event21 - MX Anywhere 2 Mouse: device is a pointer
[ 25.397] (II) event21 - MX Anywhere 2 Mouse: device removed
[ 25.398] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0005:046D:B01F.0003/input/input26/event21"
[ 25.398] (II) XINPUT: Adding extended input device "MX Anywhere 2 Mouse" (type: MOUSE, id 18)
[ 25.399] (**) Option "AccelerationScheme" "none"
[ 25.400] (**) MX Anywhere 2 Mouse: (accel) selected scheme none/0
[ 25.400] (**) MX Anywhere 2 Mouse: (accel) acceleration factor: 2.000
[ 25.400] (**) MX Anywhere 2 Mouse: (accel) acceleration threshold: 4
[ 25.401] (II) event21 - MX Anywhere 2 Mouse: is tagged by udev as: Mouse
[ 25.402] (II) event21 - MX Anywhere 2 Mouse: device is a pointer
[ 25.419] (II) config/udev: Adding input device MX Anywhere 2 Keyboard (/dev/input/event20)
[ 25.419] (**) MX Anywhere 2 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.419] (**) MX Anywhere 2 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 25.419] (**) MX Anywhere 2 Keyboard: Applying InputClass "system-keyboard"
[ 25.419] (II) Using input driver 'libinput' for 'MX Anywhere 2 Keyboard'
[ 25.421] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 75 paused 0
[ 25.421] (**) MX Anywhere 2 Keyboard: always reports core events
[ 25.421] (**) Option "Device" "/dev/input/event20"
[ 25.421] (**) Option "_source" "server/udev"
[ 25.423] (II) event20 - MX Anywhere 2 Keyboard: is tagged by udev as: Keyboard
[ 25.424] (II) event20 - MX Anywhere 2 Keyboard: device is a keyboard
[ 25.425] (II) event20 - MX Anywhere 2 Keyboard: device removed
[ 25.425] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0005:046D:B01F.0003/input/input25/event20"
[ 25.425] (II) XINPUT: Adding extended input device "MX Anywhere 2 Keyboard" (type: KEYBOARD, id 19)
[ 25.425] (**) Option "xkb_layout" "de"
[ 25.427] (II) event20 - MX Anywhere 2 Keyboard: is tagged by udev as: Keyboard
[ 25.427] (II) event20 - MX Anywhere 2 Keyboard: device is a keyboard
