I got the new Dell XPS 15 9500 with the Killer Wi-Fi 6 AX500-DBS WIFI module.
Unfortunately, the Module is not recognized correctly and not usable.
In the device list, it looks like it is recognized as a Qualcomm Device 1101.
$ inxi -Fazy
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=04cfe330-0e09-4eff-bcf3-f50244307900 rw quiet apparmor=1
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 9500 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0HH6JF v: A00 serial: <filter> UEFI: Dell v: 1.1.3
date: 05/08/2020
ID-1: BAT0 charge: 77.2 Wh condition: 77.2/84.3 Wh (92%) volts: 13.1/11.4
model: BYD DELL M59JH05 type: Li-poly serial: <filter> status: Full
Topology: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 2 microcode: C8 L2 cache: 16.0 MiB
bogomips: 76816
Speed: 800 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 801 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f95
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-11:4 chip ID: 0c45:6d14
Display: x11 server: X.Org 1.20.8 driver: intel,modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.0x25.0")
s-diag: 1198mm (47.2")
Monitor-1: eDP1 res: 3840x2400 hz: 60 dpi: 287 size: 340x210mm (13.4x8.3")
diag: 400mm (15.7")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:06c8
Sound Server: ALSA v: k5.8.3-2-MANJARO
Device-1: Qualcomm vendor: Bigfoot Networks driver: N/A port: 3000
bus ID: 6c:00.0 chip ID: 17cb:1101
Local Storage: total: 1.86 TiB used: 15.56 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM981a NVMe 2048GB size: 1.86 TiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 15301229 scheme: GPT
ID-1: / raw size: 1.08 TiB size: 1.06 TiB (98.34%) used: 15.49 GiB (1.4%)
fs: ext4 dev: /dev/nvme0n1p7
System Temperatures: cpu: 56.0 C mobo: N/A gpu: nouveau temp: 39 C
Fan Speeds (RPM): cpu: 2782 fan-2: 3101
Processes: 290 Uptime: 42m Memory: 62.56 GiB used: 2.58 GiB (4.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1039 lib: 269
Shell: Bash v: 5.0.18 running in: urxvtd inxi: 3.1.05
and
$ lspci
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 05)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:13.0 Serial controller: Intel Corporation Device 06fc
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:1c.0 PCI bridge: Intel Corporation Device 06b8 (rev f0)
00:1c.5 PCI bridge: Intel Corporation Device 06bd (rev f0)
00:1c.6 PCI bridge: Intel Corporation Device 06be (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1e.0 Communication controller: Intel Corporation Comet Lake PCH Serial IO UART Host Controller #0
00:1f.0 ISA bridge: Intel Corporation Device 068e
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 3D controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
38:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6c:00.0 Network controller: Qualcomm Device 1101 (rev 01)
6d:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader (rev 01)
6e:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
I found other people having the same problems in other distros: mint ( https://forums.linuxmint.com/viewtopic.php?p=1881057
), Fedora ( https://bugzilla.redhat.com/show_bug.cgi?id=1727457
) and Ubuntu ( https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1879633
Is there some way to get it to work in manjaro?
