Hi,
I have tried installing the Manjaro 21 on my new Dell XPS 15 9500 with the Killer Wi-Fi 6 AX500-DBS WIFI module.
I noticed when I started the Live usb with proprietary drivers, it loads up the wifi driver and works absolutely fine.
But after the installation, the wifi is not recognized correctly and not usable.
In the device list, it looks like it is recognized as a Qualcomm Device 1101.
Any help would be much appreciated.
Many thanks
AJ
sour
26 June 2021 16:01
3
There is a bug in the firmware apparently: Dell XPS 13 (9310) - ArchWiki
The solution is there.
$ inxi -Fxxxz --no-host ✔
System: Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 3.38.4 tk: GTK 3.24.29
wm: gnome-shell dm: GDM 40.0 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: XPS 15 9500 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0HH6JF v: A00 serial: <filter> UEFI: Dell v: 1.7.1 date: 03/29/2021
Battery: ID-1: BAT0 charge: 74.8 Wh (98.2%) condition: 76.2/84.3 Wh (90.4%) volts: 12.8 min: 11.4 model: BYD DELL M59JH08
type: Li-poly serial: <filter> status: Discharging
CPU: Info: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake rev: 2 cache: L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 76816
Speed: 800 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800 13: 801 14: 800 15: 800 16: 800
Graphics: Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell driver: nvidia v: 465.31 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0302
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver: loaded: modesetting,nvidia
unloaded: intel,nouveau alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Qualcomm vendor: Rivet Networks driver: ath11k_pci v: kernel port: 3000 bus-ID: 6c:00.0
chip-ID: 17cb:1101 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:3 chip-ID: 0bda:8153
class-ID: 0000 serial: <filter>
IF: enp0s20f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 953.87 GiB used: 72.99 GiB (7.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM981a NVMe 1024GB size: 953.87 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 15304129 temp: 38.9 C scheme: GPT
Partition: ID-1: / size: 114.79 GiB used: 7.15 GiB (6.2%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 499 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 817.18 GiB used: 65.84 GiB (8.1%) fs: ext4 dev: /dev/nvme0n1p4
Swap: ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 322 Uptime: 9m wakeups: 69 Memory: 62.56 GiB used: 2.91 GiB (4.7%) Init: systemd v: 248 Compilers:
gcc: N/A Packages: pacman: 963 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
$ lspci ✔
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation 6th-9th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 05)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:13.0 Serial controller: Intel Corporation Device 06fc
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:1c.0 PCI bridge: Intel Corporation Device 06b8 (rev f0)
00:1c.5 PCI bridge: Intel Corporation Device 06bd (rev f0)
00:1c.6 PCI bridge: Intel Corporation Device 06be (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 068e
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 3D controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
38:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6c:00.0 Network controller: Qualcomm Device 1101 (rev 01)
6d:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader (rev 01)
6e:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Just tried this solution, no luck !
That’s because it uses a Qualcomm Atheros chipset.
Have you tried the 5.12 kernel?
Nope, I have not tried 5.12 kernel.
But I noticed, when start Live USB with proprietary drivers, WiFi seemed to be working.
Just installed 5.12 kernel, no change still same issue.
System: Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 3.38.4 tk: GTK 3.24.29
Battery: ID-1: BAT0 charge: 54.1 Wh (71.0%) condition: 76.2/84.3 Wh (90.4%) volts: 11.8 min: 11.4
model: BYD DELL M59JH08 type: Li-poly serial: <filter> status: Discharging
Speed: 800 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 2713 3: 1878 4: 1062 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 901
class-ID: 0300
chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Drives: Local Storage: total: 953.87 GiB used: 82.72 GiB (8.7%)
rotation: SSD serial: <filter> rev: 15304129 scheme: GPT
Partition: ID-1: / size: 114.79 GiB used: 14.8 GiB (12.9%) fs: ext4 dev: /dev/nvme0n1p3
ID-3: /home size: 817.18 GiB used: 67.93 GiB (8.3%) fs: ext4 dev: /dev/nvme0n1p4
Sensors: System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2826 fan-2: 3108
Info: Processes: 329 Uptime: 1m wakeups: 8 Memory: 62.56 GiB used: 2.71 GiB (4.3%) Init: systemd v: 248
Compilers: gcc: 11.1.0 Packages: pacman: 1025 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.04
Can you boot from the live USB and check the output of the following to compare with the installed system?
inxi -Nazy
lspci | grep Network
Hello!
I just recently had a VERY similar problem on my i9 XPS15, where the installer worked, but wifi didn’t work anymore after install.
I was able to identify issues with the ath11k module via dmesg-
sudo dmesg | grep -i ath11k
This showed that I had memory page_alloc errors. I then added ‘memmap=12M\$20M’ to my /etc/default/grub, and regenerated it.
My wifi card then worked nominally.
For additional info, see:
https://wiki.archlinux.org/title/Dell_XPS_13_(9310)
@golden_demise Thanks for suggestion.
Just tried that trick, and it worked right away.
Many thanks again @Yochanan and @golden_demise , much appreciated
sour
27 June 2021 03:57
13
I really wish they would fix that firmware bug.
Man I was disappointed when I found out my XPS came with an Atheros chipset.
system
Closed
12 July 2021 03:57
14
