Hi there,
I have installed Manjaro on my laptop Precision 7530 and I am connecting 2*24" Dell monitors (using HDMI) to my dock WD19DC (using HDMI and Display Port output).
When I dock my computer, all 3 monitors display correctly (2 external and laptop screen), however as soon as I try to change my monitors layout and hit apply all of them black out including my laptop. And I have to press and hold the power button to turn it off and turn it back on.
You will find below some information about my computer:
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=2844bbd9-176f-41de-a87c-1dad9e7eb480 rw quiet apparmor=1
security=apparmor resume=UUID=110ecc64-2e20-416a-91af-5058657c3189
udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.27 wm: gnome-shell dm: GDM 3.38.2.1
Type: Laptop System: Dell product: Precision 7530 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0Y0MPW v: A06 serial: <filter> UEFI: Dell v: 1.14.4
date: 10/21/2020
ID-1: BAT0 charge: 3.2 Wh (5.0%) condition: 63.4/97.0 Wh (65.4%) volts: 11.6
min: 11.4 model: BYD DELL GW0K989 type: Li-poly serial: <filter>
status: Charging
Info: 6-Core model: Intel Core i7-8850H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE cache: L1: 384 KiB
L2: 9 MiB L3: 9 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4300 MHz base/boost: 4000/4300 volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Dell driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1cbb
class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-11:3 chip-ID: 1bcf:2b96 class-ID: 0e02
Display: server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: Quadro P1000/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Plantronics Poly Voyager Base-M CD type: USB
driver: plantronics,snd-usb-audio,usbhid bus-ID: 1-4.3.3:9
chip-ID: 047f:02ea class-ID: 0300 serial: <filter>
Device-4: Realtek USB Audio type: USB driver: snd-usb-audio
bus-ID: 1-4.3.4:10 chip-ID: 0bda:402e class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000
bus-ID: 70:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp112s0 state: up mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.4:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp59s0u1u4 state: down mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.39 TiB used: 146.63 GiB (10.3%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Crucial model: CT500P1SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: P3CR010 temp: 24.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Micron
model: PC400 NVMe SK hynix 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 40001E00 temp: 26.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: AADA4105 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 442.3 GiB size: 434.35 GiB (98.20%)
used: 131.52 GiB (30.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:9
used: 16.1 MiB (5.4%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:8
ID-1: swap-1 type: partition size: 34.35 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3 maj-min: 259:10
System Temperatures: cpu: 25.0 C mobo: N/A gpu: nvidia temp: 40 C
Processes: 302 Uptime: 7m wakeups: 11 Memory: 62.67 GiB
used: 2.53 GiB (4.0%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1385 pacman: 1379 lib: 402 flatpak: 0 snap: 6
Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.0 running-in: gnome-terminal
inxi: 3.3.03
