i have a dell latitude 7480 fingerprint
lsusb shows:
Bus 001 Device 003: ID 0a5c:5834 Broadcom Corp. [unknown]
this is the fingerprint sensor but it seems that there is no driver installed on the system for this sensor
so where can i find the driver of this sensor so as i can use it with fprintd?
Dell Drivers & Downloads may be worth a visit.
These links may give some useful information:
- arch-fingerprint
- libfprint-2-tod1-broadcom
- Fingerprint reader replacement on Dell 5590
- Fingerprint driver for Linux - Dell Latitude 5500, 0a5c:5843 Broadcom Corp. 5820
- Fingerprint driver for GNU/Linux
These results were found with a simple Google search using 0a5c:5834 Broadcom driver linux – I hope these lead to something usable.
Cheers.
As far as I know you can’t, it’s not supported by libfprint.
Device with ID 0a5c:5834 does not work on most Dell systems
https://linux-hardware.org/?id=usb:0a5c-5834
Archwiki confirms device does not work on Latitude 7480 specifically
https://wiki.archlinux.org/title/Laptop/Dell#Latitude
after installing "libfprint-2-tod1-broadcom: now the pc detect the sensor
lsusb:
Bus 001 Device 006: ID 0a5c:5834 Broadcom Corp. 5880
but i still cant configure it:
fprintd-enroll ![]()
Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
As evidenced by numerous links, including those I initially posted, the general consensus seems to be that this device 0a5c:5834 on the Lattitude 7480 will likely never be made to function.
As @MrLavender ponts out, the libfprint Wiki lists it as unsupported; as does ArchLinux (which Manjaro is built upon), as indicated by @nikgnomic .
I submit that Manjaro forum users will likely not be able to help further with your issue, and that it will only become a time-sink for all who try. Therefore I have taken the liberty of assigning a post above as being the solution, so that this thread may soon be closed.
Of course, if you disagree, you can always change it again. Cheers.
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
