I have installed manjaro 20.0 Lycia on my new Dell latitude 5400 laptop. Manjaro is working fine. But suddenly yesterday when I restarted, it shows Dell logo and then just a black screen appears. It remains until the battery becomes empty. It doesn’t even show a cursor or error message!! I can sometime access the system using a bootable usb drive. When it shows welcome screen then I select “detect bootloader” option and it shows (hd1, gpt1). I press enter and if my luck is good enough it normally shows manjaro login screen and I can use without any issues. Otherwise black screen. I tried many solutions including kernel downgrading, re-installing grub etc. Now I am tired and frustrated. I wish if anybody can understand and help me… In my 7 years old laptop I also use manjaro but not a single problem! So why new machine is creating problem!! Please help!! Thanks in advance.
Hello, does your machine boots on a recent Manjaro iso on USB key ?
Hello, are you able to boot the recent Manjaro Desktop ISO? If so then it would be nice to get a log what happend there.
- Boot the iso.
- open a terminal
- open browser and go to forum.manjaro.org
- type
manjaro-chroot -a
into the terminal and type 1 - then run
journalctl -b -0 --no-pager | curl --upload - https://aptget.xyz/boot.0.log
- Paste the link here.
Also useful:
inxi -Fazy
sudo parted -l
Thanks
No! Its black when I press boot option during installation but previous version installs without any problem. But creates the problem I mentioned.
The recent 20.1 iso shows black screen from the beginning when I press boot option in the welcome screen. Thats why I chose the old version that’s already running in my old laptop without any issues.
I was able to login don’t know how. I have tried the commands you provide and the following is the output:
- manjaro-chroot -a
==> ERROR: You can't mount 0!
- journalctl link: http://aptget.xyz/uCOVD/boot.0.log
- inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=0d7e81ae-e848-48f0-86de-53f0fdbae1a9 rw quiet apparmor=1
security=apparmor resume=UUID=9bef5d86-da38-47ea-91c2-b4e4c5ece51f
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude 5400 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0PD9KD v: A00 serial: <filter> UEFI: Dell v: 1.7.4
date: 05/12/2020
ID-1: BAT0 charge: 7.2 Wh condition: 65.3/68.0 Wh (96%) volts: 7.8/7.6
model: BYD DELL 9JRYT03 type: Li-poly serial: <filter> status: Charging
Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
L2 cache: 6144 KiB
bogomips: 28808
Speed: 900 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 901 5: 900 6: 900 7: 900 8: 900
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 0bda:5539 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1368x768 s-dpi: 97 s-size: 360x202mm (14.2x8.0")
s-diag: 413mm (16.3")
Monitor-1: eDP1 res: 1368x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 3000 bus ID: 00:14.3 chip ID: 8086:9df0
Device-2: Intel Ethernet I219-V vendor: Dell driver: e1000e v: 3.2.6-k
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15be
IF: eno2 state: down mac: <filter>
Local Storage: total: 506.36 GiB used: 11.59 GiB (2.3%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNS512G NVMe KIOXIA 512GB
- sudo parted -l
Model: KBG40ZNS512G NVMe KIOXIA 512GB (nvme)
Disk /dev/nvme0n1: 512GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 494GB 494GB ext4
3 494GB 512GB 18.3GB linux-swap(v1) swap
Maybe try with a different USB stick. But please keep the latest iso, not an old one.
I think you didn’t understand what I said about the new one.
While reading the boot.0.log i saw this:
ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
The linux ACPI always tells the firmware that it is windows, but there is code on the firmware that supports linux. Here it becomes ignored, but to work well, some systems need this. To enable this you could add:
acpi_osi=Linux
to the kernel parameters in grub: Kernel parameters - ArchWiki
Have look here at the acpi section: [HowTo] Power savings setup| 2021-01-25
That’s the reason why i said:
and not 0
Hi!
I have had this with my Latitude 7440, too. But only when it is attached to the Docking Station and has a secondary/external Monitor active and connected.
Temporary fix / Try this out:
In GRUB, edit boot menu parameters, delete “quiet” from boot string. There is a key you can press when the menu shows that will allow for a one time change of the boot parameters.
If systems boots (now showing boot text in text console, that’s what “quiet” suppresses), that is your solution. Make it permanent by editing GRUB menu to exclude “quiet” option. (easiest by installing a GRUB editor or do a web search on the commands you need to edit and rebuild the GRUB menu by hand).
Fingers crossed, hope it helps!
