Dell 7480 bluetooth not detected
in bluetooth options it tells me that no device found
how to intall the driver for bluetooth for my device?
please post the output of
first. use the option ā€œpreformatted textā€ (the 3 ticks) and paste it inside them
inxi --admin --verbosity=7 --filter --no-host --width                                 1 ✘
  Kernel: 6.6.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=94056c3c-7682-4647-ae52-62c2357c4be2 rw quiet splash
    resume=UUID=16903b87-9499-4dcb-907d-8ae397807ed4 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Dell product: Latitude 7480 v: N/A
  Mobo: Dell model: 0CDXCF v: A00 serial: <superuser required> UEFI: Dell
    v: 1.32.1 date: 07/05/2023
  ID-1: BAT0 charge: 34.4 Wh (100.0%) condition: 34.4/60.0 Wh (57.3%)
    volts: 8.3 min: 7.6 model: SMP DELL DM3WC64 type: Li-poly serial: <filter>
    status: full
  System RAM: total: 8 GiB available: 7.64 GiB used: 4.46 GiB (58.4%)
  Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 500 min/max: 400/3000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 20004
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: Microdia HP Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6321
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.61x9.33")
    s-diag: 484mm (19.05") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x333d built: 2016 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 7.46 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
    device-ID: 8086:1916 surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.6.1-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.84 status: off with: pipewire-media-session
    status: active tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Local Storage: total: 238.47 GiB used: 67.65 GiB (28.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HBJD-00BH1
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1NFAV temp: 22.9 C
    scheme: GPT
  ID-1: / raw-size: 59.8 GiB size: 58.56 GiB (97.93%) used: 13.83 GiB (23.6%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 94056c3c-7682-4647-ae52-62c2357c4be2
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 22.6 MiB (5.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 723E-0A93
  ID-3: /home raw-size: 170.46 GiB size: 166.72 GiB (97.81%)
    used: 52.41 GiB (31.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: 06f345a5-0511-43fe-b7d8-9997a5430090
  ID-1: swap-1 type: partition size: 7.81 GiB used: 1.39 GiB (17.7%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 16903b87-9499-4dcb-907d-8ae397807ed4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Microdia HP Integrated Webcam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6321 class-ID: 0e02
  Device-2: 1-10:7 info: Broadcom 5880 type: smart card driver: N/A
    interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0a5c:5834 class-ID: 0b00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 35.0 C pch: 32.5 C mobo: 31.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 230 Uptime: 3h 54m wakeups: 3 Init: systemd v: 254
  Packages: pm: pacman pkgs: 1347 libs: 376 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.2.15 running-in: konsole
  inxi: 3.3.31
well i wonder a liffle bit, can you also post the output of
rfkill
a first step is to check your bios settings about any network/wireless options.
you have a combined wifi/bluetooth hardware-card. they should be recognized both and i wonder that wifi-part is detected while the bluetooth isn’t.
so check the bios-settings if there is something related disabled or set.
p.s.:
also check if there are physical switches or key-combinations to activate/deactivate at the laptop and the ā€œtravel/fly-modeā€.
rfkill         āœ”
ID TYPE DEVICE         SOFT      HARD
 0 wlan dell-wifi unblocked unblocked
 1 wlan phy0      unblocked unblocked
Do you know if Bluetooth has ever worked on the device? Some Dell Latitude 7480s were sold with Bluetooth deactivated at the firmware level as required for security reasons by some companies and government agencies. Bluetooth may also have been an optional choice for anyone purchasing online from Dell. You haven’t mentioned if the device is new or had a previous owner, but you may want to check in the BIOS to see if Bluetooth can be activated, or if it is greyed out & not possible to activate.
I found this out via this topic at Dell: ā€ŽLatitude 7480 Bluetooth | DELL Technologies
Sadly, the solution in that case was:
Hey guys,
I’ve made a few inquiries and it turns out that the Bluetooth is disabled at a firmware level. As you mentioned in one your posts it’s aimed at customers in specialized areas where Bluetooth isn’t allowed. I’m afraid that only hardware replacement will resolve this.
If Bluetooth has been deactivated on the motherboard, maybe a USB Bluetooth dongle might be a possible solution?
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
