Dell 5590 - Freeze at sleep using nvme ssd
Hi, I’m running a clean install of Manjaro using Gnome, XFS with swap on a 1TB nvme (Kingston) and system freeze at every sleep, here are the specs and logs:
I read a bunch of articles and posts but no idea about what’s hapenning, the swap is on.
inxi -Fxxxrz
inxi -Fxxxrz
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: Dell product: G5 5590 v: N/A
  Mobo: Dell model: 0F3T2G v: A02 serial: <superuser required> UEFI: Dell
    v: 1.21.1 date: 09/14/2022
  ID-1: BAT0 charge: 40.9 Wh (100.0%) condition: 40.9/60.0 Wh (68.2%)
    volts: 16.9 min: 15.2 model: LGC-LGC3.985 DELL 8622M06 type: Li-ion
    serial: <filter> status: full
  Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
    status: discharging
  Info: 6-core model: Intel Core i7-9750H bits: 64 type: MT MCP smt: enabled
    arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
  Speed (MHz): avg: 3700 high: 3702 min/max: 800/4500 cores: 1: 3702 2: 3700
    3: 3700 4: 3700 5: 3700 6: 3700 7: 3701 8: 3700 9: 3700 10: 3700 11: 3700
    12: 3700 bogomips: 62431
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
    driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,
    DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
    driver: nvidia v: 530.41.03 arch: Turing pcie: speed: 5 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-5:4 chip-ID: 0c45:671f class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 4480x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1-0 pos: right res: 2560x1080 hz: 60 dpi: 97
    size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
  Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 144 dpi: 142
    size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    bus-ID: 1-3:3 v: kernel chip-ID: 18ee:52f8 bus-ID: 00:1f.3 class-ID: 0300
  Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
    chip-ID: 10de:10f9 class-ID: 0403
  Device-3: Soundprese HD-II type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 0.3.70 status: off
  Server-3: PulseAudio v: 16.1 status: active
  Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
  IF: enp60s0 state: down mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
    driver: wl v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 3d:00.0
    chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp61s0 state: up mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
    bus-ID: 1-14.3:9 chip-ID: 05ac:828d class-ID: fe01
  Local Storage: total: 2.73 TiB used: 45.56 GiB (1.6%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
    speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: SBM02103
    temp: 46.9 C scheme: GPT
  ID-2: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
  ID-1: / size: 896.49 GiB used: 45.56 GiB (5.1%) fs: xfs dev: /dev/dm-0
    mapped: luks-15c08fff-1a1b-4a13-be27-60c56a4d0700
  ID-2: /boot/efi size: 299.4 MiB used: 472 KiB (0.2%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 34.28 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-1 mapped: luks-d9c05080-3ac8-401d-8036-a3c1cb92ff7a
  System Temperatures: cpu: 87.0 C pch: 70.0 C mobo: 69.0 C
  Fan Speeds (RPM): cpu: 4395 fan-2: 4369
  Packages: 1297 pm: pacman pkgs: 1288 pm: flatpak pkgs: 9
    1: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    2: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    3: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
  Processes: 366 Uptime: 21m wakeups: 27 Memory: 31.16 GiB
  used: 16.76 GiB (53.8%) Init: systemd v: 252 default: graphical Compilers:
  gcc: 12.2.1 clang: 15.0.7 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.26
journalctl -b0 -p4 --no-pager
logs
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "glx"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module glx: vendor="X.Org Foundation"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.21.1.8, module version = 1.0.0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         ABI class: X.Org Server Extension, version 10.0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Applying OutputClass "intel" to /dev/dri/card0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         loading driver: modesetting
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Applying OutputClass "nvidia" to /dev/dri/card1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         loading driver: nvidia
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched modesetting as autoconfigured driver 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched nvidia as autoconfigured driver 1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched nouveau as autoconfigured driver 2
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched nv as autoconfigured driver 3
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched fbdev as autoconfigured driver 4
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Matched vesa as autoconfigured driver 5
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) Assigned the driver to the xf86ConfigLayout
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "modesetting"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module modesetting: vendor="X.Org Foundation"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.21.1.8, module version = 1.21.1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         Module class: X.Org Video Driver
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         ABI class: X.Org Video Driver, version 25.2
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "nvidia"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module nvidia: vendor="NVIDIA Corporation"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.6.99.901, module version = 1.0.0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "nouveau"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) Warning, couldn't open module nouveau
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (EE) Failed to load module "nouveau" (module does not exist, 0)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "nv"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) Warning, couldn't open module nv
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (EE) Failed to load module "nv" (module does not exist, 0)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "fbdev"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) Warning, couldn't open module fbdev
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (EE) Failed to load module "fbdev" (module does not exist, 0)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "vesa"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) Warning, couldn't open module vesa
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (EE) Failed to load module "vesa" (module does not exist, 0)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA dlloader X Driver  530.41.03  Thu Mar 16 19:25:45 UTC 2023
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): using drv /dev/dri/card0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: releasing fd for 226:1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "fb"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "fb"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module "fb" already built-in
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "wfb"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "wfb"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/libwfb.so
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module wfb: vendor="X.Org Foundation"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         ABI class: X.Org ANSI C Emulation, version 0.4
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Creating default Display subsection in Screen section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         "Default Screen Section" for depth/fbbpp 24/32
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): RGB weight 888
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): Default visual is TrueColor
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "glamoregl"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "glamoregl"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module glamoregl: vendor="X.Org Foundation"
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.21.1.8, module version = 1.0.1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): glamor initialized
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): VariableRefresh: disabled
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): AsyncFlipSecondaries: disabled
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output eDP-1 has no monitor section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output DP-1 has no monitor section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output HDMI-1 has no monitor section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output DP-2 has no monitor section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output HDMI-2 has no monitor section
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID for output eDP-1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Manufacturer: BOE  Model: 84a  Serial#: 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Year: 2018  Week: 1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID Version: 1.4
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Digital Display Input
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): 8 bits per channel
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Digital interface is DisplayPort
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Gamma: 2.20
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): No DPMS capabilities specified
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Supported color encodings: RGB 4:4:4
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): First detailed timing is preferred mode
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): redX: 0.640 redY: 0.329   greenX: 0.300 greenY: 0.600
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): blueX: 0.149 blueY: 0.060   whiteX: 0.312 whiteY: 0.328
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Manufacturer's mask: 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Supported detailed timing:
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): clock: 342.1 MHz   Image Size:  344 x 194 mm
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2080 h_border: 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1142 v_border: 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Unknown vendor-specific block 0
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: [31B blob data]
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID (in hex):
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         00ffffffffffff0009e54a0800000000
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         011c0104a522137802de50a3544c9926
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         0f505400000001010101010101010101
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         0101010101019d8580a070383e406c30
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         aa0058c21000001a0000000000000000
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         0000000000000000001a000000fe0046
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         35542050804e56313536464800000000
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0):         0002412f9e021000000b010a2020004e
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Printing probed modes for output eDP-1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x144.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x1024"x85.0  157.50  1280 1344 1504 1728  1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x960"x85.0  148.50  1280 1344 1504 1728  960 961 964 1011 +hsync +vsync (85.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x170.0  194.02  1024 1108 1220 1416  768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x150.1  170.24  1024 1108 1220 1416  768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x85.0   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync (68.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x768i"x43.5   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x720"x170.0  170.68  960 1036 1144 1328  720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x720"x150.0  148.50  960 1032 1144 1320  720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "928x696"x150.0  144.00  928 992 1104 1280  696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "896x672"x150.1  130.50  896 944 1052 1228  672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x170.0  114.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x150.0  101.25  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x140.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x130.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x85.1   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync (53.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "700x525"x149.5   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x512"x170.0   78.75  640 672 752 864  512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x512"x150.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x170.2   74.25  640 672 752 864  480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x85.0   36.00  640 696 752 832  480 481 484 509 -hsync -vsync (43.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "720x400"x85.0   35.50  720 756 828 936  400 401 404 446 -hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x400"x85.1   31.50  640 672 736 832  400 401 404 445 -hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "576x432"x150.0   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "640x350"x85.1   31.50  640 672 736 832  350 382 385 445 +hsync -vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x384"x170.0   47.25  512 536 584 688  384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x384"x150.1   39.38  512 520 568 656  384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x384"x140.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x384i"x87.1   22.45  512 516 604 632  384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "416x312"x149.3   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "400x300"x170.5   28.15  400 416 448 524  300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "400x300"x144.4   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "400x300"x150.2   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x240"x170.4   18.00  320 348 376 416  240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x240"x145.6   15.75  320 332 352 416  240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x240"x150.0   15.75  320 328 360 420  240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "360x200"x170.1   17.75  360 378 414 468  200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x200"x170.5   15.75  320 336 368 416  200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "320x175"x170.5   15.75  320 336 368 416  175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID for output DP-1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID for output HDMI-1
abr 26 17:17:53 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID for output DP-2
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID for output HDMI-2
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output eDP-1 connected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output DP-1 disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output HDMI-1 disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output DP-2 disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output HDMI-2 disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Using exact sizes for initial modes
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): DPI set to (96, 96)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "fb"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "fb"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module "fb" already built-in
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): RGB weight 888
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Default visual is TrueColor
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "AllowNVIDIAGpuScreens"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Applying OutputClass "nvidia" options to /dev/dri/card1
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) NVIDIA(G0): Enabling 2D acceleration
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "glxserver_nvidia"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "glxserver_nvidia"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.6.99.901, module version = 1.0.0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]:         Module class: X.Org Server Extension
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA GLX Module  530.41.03  Thu Mar 16 19:27:05 UTC 2023
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA: The X server supports PRIME Render Offload.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(0):     DFP-0 (boot)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(0):     DFP-1
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(0):     DFP-2
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 2060 (TU106-A) at PCI:1:0:0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     (GPU-0)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(G0): Memory: 6291456 kBytes
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(G0): VideoBIOS: 90.06.2d.00.bd
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): Detected PCI Express Link width: 16X
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: disconnected
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): Validated MetaModes:
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     "NULL"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) NVIDIA(G0): Cannot find size of first mode for LG Electronics LG ULTRAWIDE
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) NVIDIA(G0):     (DFP-0); cannot compute DPI from LG Electronics LG
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (WW) NVIDIA(G0):     ULTRAWIDE (DFP-0)'s EDID.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): Backing store enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): Silken mouse enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) modeset(0): DPMS enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): [DRI2] Setup complete
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): [DRI2]   DRI driver: iris
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): [DRI2]   VDPAU driver: va_gl
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA:     access.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0):     Config Options in the README.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): Setting mode "NULL"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Disabling shared memory pixmaps
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Backing store enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): Silken mouse enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (==) NVIDIA(G0): DPMS enabled
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading sub module "dri2"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "dri2"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module "dri2" already built-in
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): [DRI2] Setup complete
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension Generic Event Extension
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension SHAPE
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension MIT-SHM
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XInputExtension
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XTEST
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension BIG-REQUESTS
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension SYNC
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XKEYBOARD
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XC-MISC
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension SECURITY
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XFIXES
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension RENDER
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension RANDR
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension COMPOSITE
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension DAMAGE
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension MIT-SCREEN-SAVER
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension DOUBLE-BUFFER
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension RECORD
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension DPMS
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension Present
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension DRI3
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension X-Resource
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XVideo
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XVideo-MotionCompensation
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension GLX
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Indirect GLX disabled.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) AIGLX: Loaded and initialized iris
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) GLX: Initialized DRI2 GL provider for screen 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XFree86-VidModeExtension
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XFree86-DGA
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension XFree86-DRI
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension DRI2
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension NV-GLX
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Initializing extension NV-CONTROL
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Damage tracking initialized
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Setting screen physical size to 508 x 285
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Video Bus (/dev/input/event12)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Video Bus: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) LoadModule: "libinput"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Module libinput: vendor="X.Org Foundation"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]:         compiled for 1.21.1.8, module version = 1.3.0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]:         Module class: X.Org XInput Driver
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]:         ABI class: X.Org XInput driver, version 24.4
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Video Bus'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 49 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Video Bus: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event12"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event12 - Video Bus: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event12 - Video Bus: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event12 - Video Bus: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input23/event12"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "xkb_layout" "us"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Video Bus (/dev/input/event13)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 52 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event13"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event13 - Video Bus: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event13 - Video Bus: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event13 - Video Bus: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input24/event13"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Power Button: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Power Button'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 53 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Power Button: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event1"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event1  - Power Button: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event1  - Power Button: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event1  - Power Button: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) No input driver specified, ignoring this device.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) This device may have been added with another device file.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Sleep Button: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Sleep Button'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 54 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Sleep Button: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event2"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event2  - Sleep Button: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event2  - Sleep Button: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event2  - Sleep Button: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event6)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Logitech G603 (/dev/input/event4)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: Applying InputClass "evdev pointer catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: Applying InputClass "libinput pointer catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Logitech G603'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 55 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event4"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event4  - Logitech G603: is tagged by udev as: Keyboard Mouse
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event4  - Logitech G603: device is a pointer
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event4  - Logitech G603: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event4  - Logitech G603: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: Logitech G603: Step value 0 was provided, libinput Fallback acceleration function is used.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: Logitech G603: needs a virtual subdevice
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C539.0003/0003:046D:406C.0004/input/input15/event4"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Logitech G603" (type: MOUSE, id 10)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "AccelerationScheme" "none"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: (accel) selected scheme none/0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: (accel) acceleration factor: 2.000
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Logitech G603: (accel) acceleration threshold: 4
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Logitech G603 (/dev/input/mouse0)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Soundprese HD-II Consumer Control (/dev/input/event5)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Soundprese HD-II Consumer Control: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Soundprese HD-II Consumer Control: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Soundprese HD-II Consumer Control: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Soundprese HD-II Consumer Control'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 56 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Soundprese HD-II Consumer Control: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event5"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event5  - Soundprese HD-II Consumer Control: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event5  - Soundprese HD-II Consumer Control: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event5  - Soundprese HD-II Consumer Control: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.3/0003:18EE:52F8.0005/input/input16/event5"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Soundprese HD-II Consumer Control" (type: KEYBOARD, id 11)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event17)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 57 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Integrated_Webcam_HD: Integrate: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event17"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event17 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event17 - Integrated_Webcam_HD: Integrate: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event17 - Integrated_Webcam_HD: Integrate: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input29/event17"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 12)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device DELL08EA:00 06CB:CCA8 Mouse (/dev/input/event23)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: Applying InputClass "evdev pointer catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: Applying InputClass "libinput pointer catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'DELL08EA:00 06CB:CCA8 Mouse'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 58 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event23"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event23 - DELL08EA:00 06CB:CCA8 Mouse: is tagged by udev as: Mouse Pointingstick
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event23 - DELL08EA:00 06CB:CCA8 Mouse: device is a pointer
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event23 - DELL08EA:00 06CB:CCA8 Mouse: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: DELL08EA:00 06CB:CCA8 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-6/i2c-DELL08EA:00/0018:06CB:CCA8.0009/input/input38/event23"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "DELL08EA:00 06CB:CCA8 Mouse" (type: MOUSE, id 13)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: (accel) selected scheme none/0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: (accel) acceleration factor: 2.000
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Mouse: (accel) acceleration threshold: 4
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device DELL08EA:00 06CB:CCA8 Mouse (/dev/input/mouse3)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device DELL08EA:00 06CB:CCA8 Touchpad (/dev/input/event24)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: Applying InputClass "evdev touchpad catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: Applying InputClass "libinput touchpad catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'DELL08EA:00 06CB:CCA8 Touchpad'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 59 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event24"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event24 - DELL08EA:00 06CB:CCA8 Touchpad: is tagged by udev as: Touchpad
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event24 - DELL08EA:00 06CB:CCA8 Touchpad: device is a touchpad
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event24 - DELL08EA:00 06CB:CCA8 Touchpad: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: DELL08EA:00 06CB:CCA8 Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-6/i2c-DELL08EA:00/0018:06CB:CCA8.0009/input/input39/event24"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "DELL08EA:00 06CB:CCA8 Touchpad" (type: TOUCHPAD, id 14)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: (accel) selected scheme none/0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: (accel) acceleration factor: 2.000
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) DELL08EA:00 06CB:CCA8 Touchpad: (accel) acceleration threshold: 4
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device DELL08EA:00 06CB:CCA8 Touchpad (/dev/input/mouse4)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event14)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event21)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event22)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Intel HID events (/dev/input/event8)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID events: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Intel HID events'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 60 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID events: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event8"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event8  - Intel HID events: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event8  - Intel HID events: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event8  - Intel HID events: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input19/event8"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 15)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event9)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Intel HID 5 button array'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 61 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Intel HID 5 button array: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event9"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event9  - Intel HID 5 button array: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event9  - Intel HID 5 button array: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event9  - Intel HID 5 button array: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input20/event9"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 16)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event16)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 62 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Dell WMI hotkeys: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event16"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event16 - Dell WMI hotkeys: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event16 - Dell WMI hotkeys: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event16 - Dell WMI hotkeys: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input28/event16"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 17)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 63 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) AT Translated Set 2 keyboard: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event3"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event3  - AT Translated Set 2 keyboard: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event11)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 64 paused 0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: always reports core events
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event11"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event11 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event11 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event11 - SynPS/2 Synaptics TouchPad: device is a touchpad
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event11 - SynPS/2 Synaptics TouchPad: device removed
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: SynPS/2 Synaptics TouchPad: Step value 0 was provided, libinput Fallback acceleration function is used.
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input22/event11"
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 19)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse2)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device PC Speaker (/dev/input/event10)
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: Logitech G603: is a virtual subdevice
abr 26 17:17:54 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "Logitech G603" (type: KEYBOARD, id 20)
abr 26 17:17:55 neri-g55590 gnome-session-binary[1901]: WARNING: Could not parse desktop file manjaro-app-folder-settings.desktop or it references a not found TryExec binary
abr 26 17:17:55 neri-g55590 gnome-session-binary[1901]: WARNING: Could not parse desktop file manjaro-starter.desktop or it references a not found TryExec binary
abr 26 17:17:55 neri-g55590 gnome-keyring-daemon[1911]: discover_other_daemon: 1
abr 26 17:17:55 neri-g55590 gnome-keyring-daemon[1913]: discover_other_daemon: 1
abr 26 17:17:55 neri-g55590 gnome-keyring-daemon[1912]: discover_other_daemon: 1
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1910.scope: Failed to add PIDs to scope's control group: No such process
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1910.scope: Failed with result 'resources'.
abr 26 17:17:55 neri-g55590 systemd[1768]: Failed to start Application launched by gnome-session-binary.
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dsecrets-1907.scope: Failed to add PIDs to scope's control group: No such process
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dsecrets-1907.scope: Failed with result 'resources'.
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dssh-1909.scope: Failed to add PIDs to scope's control group: No such process
abr 26 17:17:55 neri-g55590 systemd[1768]: app-gnome-gnome\x2dkeyring\x2dssh-1909.scope: Failed with result 'resources'.
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID vendor "BOE", prod id 2122
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Printing DDC gathered Modelines:
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: disconnected
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: disconnected
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
abr 26 17:17:55 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Allocate new frame buffer 4480x1080 stride
abr 26 17:17:56 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) NVIDIA(G0): Setting mode "HDMI-1-0: nvidia-auto-select @2560x1080 +1920+0 {AllowGSYNC=Off, ViewPortIn=2560x1080, ViewPortOut=2560x1080+0+0}"
abr 26 17:17:56 neri-g55590 gnome-shell[1917]: ATK Bridge is disabled but a11y has already been enabled.
abr 26 17:17:57 neri-g55590 gnome-keyring-daemon[1784]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
abr 26 17:17:57 neri-g55590 gnome-keyring-d[1784]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
abr 26 17:17:57 neri-g55590 gnome-shell[1917]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
abr 26 17:17:57 neri-g55590 gnome-shell[1917]: Some code accessed the property 'ThumbnailsBox' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
abr 26 17:17:57 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): EDID vendor "BOE", prod id 2122
abr 26 17:17:57 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Printing DDC gathered Modelines:
abr 26 17:17:57 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) modeset(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
abr 26 17:17:57 neri-g55590 gnome-keyring-daemon[1784]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
abr 26 17:17:57 neri-g55590 gnome-keyring-d[1784]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: disconnected
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: disconnected
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
abr 26 17:17:58 neri-g55590 /usr/lib/gdm-x-session[1798]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
abr 26 17:17:58 neri-g55590 kernel: kauditd_printk_skb: 16 callbacks suppressed
abr 26 17:17:58 neri-g55590 gnome-session-binary[1901]: GnomeDesktop-WARNING: Could not create transient scope for PID 2339: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2339 does not exist.
abr 26 17:17:58 neri-g55590 gsd-usb-protect[2216]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
abr 26 17:17:58 neri-g55590 gsd-media-keys[2198]: Failed to grab accelerator for keybinding settings:playback-random
abr 26 17:17:58 neri-g55590 gsd-media-keys[2198]: Failed to grab accelerator for keybinding settings:playback-repeat
abr 26 17:17:58 neri-g55590 gsd-media-keys[2198]: Failed to grab accelerator for keybinding settings:rotate-video-lock
abr 26 17:17:58 neri-g55590 gsd-media-keys[2198]: Failed to grab accelerator for keybinding settings:hibernate
abr 26 17:17:58 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profile Enabled Default' for device 'Logitech G603' returned 3 items, expected 2
abr 26 17:17:58 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profiles Available' for device 'Logitech G603' returned 3 items, expected 2
abr 26 17:17:58 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profile Enabled' for device 'Logitech G603' returned 3 items, expected 2
abr 26 17:17:59 neri-g55590 gnome-shell[1917]: GTask meta_color_store_ensure_colord_profile (source object: 0x555b7aeb3ae0, source tag: 0x7fd3b546add0) finalized without ever returning (using g_task_return_*()). This potentially indicates a bug in the program.
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[1324]: dbus-daemon[1324]: [session uid=120 pid=1324] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=1494 comm="/usr/lib/gsd-sharing")
abr 26 17:18:00 neri-g55590 gnome-session-binary[1325]: WARNING: Lost name on bus: org.gnome.SessionManager
abr 26 17:18:00 neri-g55590 gsd-usb-protect[1498]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-rfkill[1507]: Error releasing name org.gnome.SettingsDaemon.Rfkill: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-screensaver[1527]: Error releasing name org.freedesktop.ScreenSaver: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-smartcard[1509]: Error releasing name org.gnome.SettingsDaemon.Smartcard: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-sound[1532]: Error releasing name org.gnome.SettingsDaemon.Sound: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-print-notif[1504]: Error releasing name org.gnome.SettingsDaemon.PrintNotifications: A conexão está fechada
abr 26 17:18:00 neri-g55590 gsd-housekeepin[1547]: Error releasing name org.gnome.SettingsDaemon.Housekeeping: A conexão está fechada
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) UnloadModule: "libinput"
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: not releasing fd for 13:68, still in use
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:75
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:67
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:80
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:73
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:72
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:88
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:87
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:81
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:69
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:68
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:66
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:65
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:77
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) systemd-logind: releasing fd for 13:76
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (WW) NVIDIA(G0): Failed to set the display configuration
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (WW) NVIDIA(G0):  - Setting a mode on head 0 failed: Insufficient permissions
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (WW) NVIDIA(G0):  - Setting a mode on head 1 failed: Insufficient permissions
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (WW) NVIDIA(G0):  - Setting a mode on head 2 failed: Insufficient permissions
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (WW) NVIDIA(G0):  - Setting a mode on head 3 failed: Insufficient permissions
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) NVIDIA(GPU-0): Deleting GPU-0
abr 26 17:18:00 neri-g55590 /usr/lib/gdm-x-session[957]: (II) Server terminated successfully (0). Closing log file.
abr 26 17:18:00 neri-g55590 gnome-session-f[2543]: Não foi possível abrir a tela:
abr 26 17:18:00 neri-g55590 gdm-launch-environment][940]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
abr 26 17:18:00 neri-g55590 pulseaudio[1995]: stat('/etc/pulse/default.pa.d'): Arquivo ou diretório inexistente
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device ERGO K860 Mouse (/dev/input/mouse1)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) No input driver specified, ignoring this device.
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) This device may have been added with another device file.
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device ERGO K860 Mouse (/dev/input/event25)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: Applying InputClass "evdev pointer catchall"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: Applying InputClass "libinput pointer catchall"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'ERGO K860 Mouse'
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 87 paused 0
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: always reports core events
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event25"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event25 - ERGO K860 Mouse: is tagged by udev as: Mouse
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event25 - ERGO K860 Mouse: device is a pointer
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event25 - ERGO K860 Mouse: device removed
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: ERGO K860 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0005:046D:B359.000A/input/input42/event25"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "ERGO K860 Mouse" (type: MOUSE, id 21)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "AccelerationScheme" "none"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: (accel) selected scheme none/0
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: (accel) acceleration factor: 2.000
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Mouse: (accel) acceleration threshold: 4
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) config/udev: Adding input device ERGO K860 Keyboard (/dev/input/event7)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: Applying InputClass "evdev keyboard catchall"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: Applying InputClass "libinput keyboard catchall"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: Applying InputClass "system-keyboard"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) Using input driver 'libinput' for 'ERGO K860 Keyboard'
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 88 paused 0
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: always reports core events
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "Device" "/dev/input/event7"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event7  - ERGO K860 Keyboard: is tagged by udev as: Keyboard
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event7  - ERGO K860 Keyboard: device is a keyboard
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) event7  - ERGO K860 Keyboard: device removed
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: ERGO K860 Keyboard: needs a virtual subdevice
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0005:046D:B359.000A/input/input41/event7"
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "ERGO K860 Keyboard" (type: MOUSE, id 22)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: (accel) selected scheme none/0
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: (accel) acceleration factor: 2.000
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) ERGO K860 Keyboard: (accel) acceleration threshold: 4
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) libinput: ERGO K860 Keyboard: is a virtual subdevice
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (II) XINPUT: Adding extended input device "ERGO K860 Keyboard" (type: KEYBOARD, id 23)
abr 26 17:19:06 neri-g55590 /usr/lib/gdm-x-session[1798]: (**) Option "xkb_layout" "us"
abr 26 17:19:06 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profile Enabled Default' for device 'ERGO K860 Mouse' returned 3 items, expected 2
abr 26 17:19:06 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profiles Available' for device 'ERGO K860 Mouse' returned 3 items, expected 2
abr 26 17:19:06 neri-g55590 gnome-shell[1917]: Property 'libinput Accel Profile Enabled' for device 'ERGO K860 Mouse' returned 3 items, expected 2
abr 26 17:19:10 neri-g55590 gnome-shell[1917]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x555b7e1ee7c0] is on because it needs an allocation.
abr 26 17:19:10 neri-g55590 gnome-shell[1917]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x555b7afb6090] is on because it needs an allocation.
$ swapon
NAME      TYPE       SIZE USED PRIO
/dev/dm-1 partition 34,3G 9,5M   -2
$ lsblk
NAME                                          MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
sda                                             8:0    0   1,8T  0 disk
├─sda1                                          8:1    0   200M  0 part
└─sda2                                          8:2    0   1,8T  0 part
nvme0n1                                       259:0    0 931,5G  0 disk
├─nvme0n1p1                                   259:1    0   300M  0 part  /boot/efi
├─nvme0n1p2                                   259:2    0 896,9G  0 part
│ └─luks-15c08fff-1a1b-4a13-be27-60c56a4d0700 254:0    0 896,9G  0 crypt /
└─nvme0n1p3                                   259:3    0  34,3G  0 part
  └─luks-d9c05080-3ac8-401d-8036-a3c1cb92ff7a 254:1    0  34,3G  0 crypt [SWAP]
post output from:
inxi -R
do you have to hard reboot when it freezes?
and try with different kernels
Yes, all the time I need to do a hard reboot bc using ALT+F2,F3,… doesn´t work.
could be related to xfs file system, could be because of nvme, and could also be because of nvidia…
so try with different kernel, for example the 5.15, and if it happens again and you have to hard reboot, post logs from the freeze:
journalctl -b-1 -p4 --no-pager
and also boot into manjaro live usb with proprietary drivers, and try sleep there…
