Hallo Manjaro users,
On my Dell 5480 with Manjaro Cinnamon installed, specific programs refuse to show up
gparted, rpi-imager, ufw,the users&groups tool
I do try to initiate from the menu. No one shows up
The Software Update tool can be launched from the menu bar. To process updates.
It keeps “busy with preparing” (In dutch : Bezig met voorbereiden). The tool cannot be stopped by clicking the x.
Programs which do show up are gnome terminal, double commander, nemo, geany, gimp.
root:...root>>ps -ef | grep gparted
hans 9686 2013 0 16:29 ? 00:00:00 /bin/sh /usr/bin/gparted
root 9700 9686 0 16:29 ? 00:00:00 pkexec --disable-internal-agent /usr/bin/gparted
root 103032 7712 0 17:06 pts/3 00:00:00 grep --colour=auto gparted
root:...root>>ps -ef | grep rpi-imager
root 6704 2013 0 16:28 ? 00:00:00 /usr/bin/pkexec --disable-internal-agent /usr/bin/rpi-imager
root 103190 7712 0 17:06 pts/3 00:00:00 grep --colour=auto rpi-imager
root:...root>>ps -ef | grep ufw
hans 11044 2013 0 16:30 ? 00:00:00 /bin/bash /usr/bin/gufw
root 11047 11044 0 16:30 ? 00:00:00 pkexec /usr/bin/gufw-pkexec hans
root 103295 7712 0 17:06 pts/3 00:00:00 grep --colour=auto ufw
Full system updates with
# pacman -Syu (launched in a root shell) does not make any difference
root:...root>>pacman -Syu
:: Pakket-databases synchroniseren...
core is bijgewerkt
extra is bijgewerkt
multilib is bijgewerkt
:: Volledige systeemsupgrade starten...
afhankelijkheden oplossen...
zoeken naar conflicterende pakketten...
Pakketten (1) signal-desktop-7.86.0-1
Totale downloadgrootte: 109,91 MiB
Totale geïnstalleerde grootte: 432,62 MiB
Netto upgrade-grootte: -1,66 MiB
:: Doorgaan met de installatie? [J/n]
:: Pakketten ophalen...
signal-desktop-7.86.0-1-x86_64 109,9 MiB 12,4 MiB/s 00:09 [###################################################] 100%
(1/1) sleutels in sleutelbos controleren [###################################################] 100%
(1/1) pakketintegriteit controleren [###################################################] 100%
(1/1) pakketbestanden laden [###################################################] 100%
(1/1) controleren van conflicterende bestanden [###################################################] 100%
(1/1) beschikbare schijfruimte controleren [###################################################] 100%
:: Pakketveranderingen verwerken...
(1/1) upgraden signal-desktop [###################################################] 100%
:: Post-transactie-hooks uitvoeren...
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
root:...root>>
My system with inxi -zv8
Kernel: 6.1.159-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
root=UUID=dd1fc170-674c-475a-8b21-0a32661d2224 rw quiet apparmor=1 security=apparmor
udev.log_priority=3
Console: pty pts/2 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Latitude 5480 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 015DR5 v: A00 serial: <superuser required> part-nu: 07A7
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.39.0 date: 11/06/2024
ID-1: BAT0 charge: 49.7 Wh (92.8%) condition: 53.5/68 Wh (78.7%) volts: 8.38 min: 7.6
model: Samsung SDI DELL MT31P86 type: Li-ion serial: <filter> charging: status: charging
cycles: N/A
System RAM: total: 8 GiB available: 7.64 GiB used: 2.71 GiB (35.5%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None max-module-size: 16 GiB note: est.
Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered) size: 8 GiB speed:
spec: 2400 MT/s actual: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: 80AD000080AD part-no: HMA81GS6AFR8N-UH serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake gen: core 6 level: v3
note: check built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1200 min/max: 400/3000 scaling: driver: intel_pstate governor: powersave
cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 20004
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibpb_exit_to_user ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
Type: gather_data_sampling status: Vulnerable: No microcode
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional; RSB filling;
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0bda:5650 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 tty: 104x24
Monitor-1: HDMI-A-1 model: Dell P2219H serial: <filter> built: 2020 res: 1920x1080 dpi: 102
gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.325 y: 0.612 blue: x: 0.153 y: 0.063
white: x: 0.314 y: 0.329 size: 476x267mm (18.74x10.51") diag: 546mm (21.5") ratio: 16:9
modes: 1920x1080, 1920x1080i, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600,
720x576, 720x576i, 720x480, 720x480i, 640x480, 720x400
Monitor-2: eDP-1 model: AU Optronics 0x113d built: 2016 res: 1920x1080 dpi: 158 gamma: 1.2
chroma: red: x: 0.573 y: 0.341 green: x: 0.353 y: 0.580 blue: x: 0.165 y: 0.133 white: x: 0.314
y: 0.329 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Info: Tools: x11: xdpyinfo, xprop, xrandr
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
API: ALSA v: k6.1.159-1-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-2: PipeWire v: 1.4.9 status: active (process) tools: pw-cli
Server-3: PulseAudio v: 17.0-98-gb096 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IP v6: <filter> type: dynamic mngtmpaddr proto kernel_ra scope: global
IP v6: <filter> virtual: proto kernel_ll scope: link
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:6 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 119.24 GiB used: 31.34 GiB (26.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: X600 M.2 2280 SATA 128GB size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 3012 scheme: GPT
ID-1: / raw-size: 34.17 GiB size: 33.33 GiB (97.56%) used: 18.03 GiB (54.1%) fs: ext4
dev: /dev/sda5 maj-min: 8:5 label: manjaroroot uuid: dd1fc170-674c-475a-8b21-0a32661d2224
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 51.5 MiB (53.7%) fs: vfat
dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 08D0-2BB4
ID-3: /mnt/datalinux raw-size: 28.32 GiB size: 27.78 GiB (98.09%) used: 13.26 GiB (47.7%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: datalinux uuid: eea84e6c-10cf-4972-a3aa-28a5eff6a796
ID-4: /mnt/tuxnas/linux raw-size: N/A size: 2.68 TiB used: 819.58 GiB (29.8%) fs: nfs4
remote: tuxnas:/volume1/linux
ID-5: /mnt/tuxnas/navigatie raw-size: N/A size: 2.68 TiB used: 819.58 GiB (29.8%) fs: nfs4
remote: tuxnas:/volume1/navigatie
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 56.64 GiB fs: ntfs label: windows11_root
uuid: A654DB0154DAD363
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 1-3:3 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 214b:7250 class-ID: 0900
Device-1: 1-3.1:5 info: Trust Deskset type: keyboard,mouse driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 145f:02cc class-ID: 0301
Device-2: 1-3.4:7 info: Genesys Logic microSD Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 98mA chip-ID: 05e3:0751 class-ID: 0806
Device-3: 1-5:4 info: Realtek Integrated Webcam_HD type: video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5650
Device-4: 1-7:6 info: Intel Bluetooth wireless interface type: bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-5: 1-8:8 info: Raydium Touch System type: HID driver: hid-multitouch,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
chip-ID: 2386:350e class-ID: 0300
Device-6: 1-10:9 info: Broadcom BCM5880 Secure Applications Processor Smartcard reader
type: smart card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0a5c:5832 class-ID: 0b00 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 33.0 C pch: 31.5 C mobo: 30.0 C
Fan Speeds (rpm): cpu: 0
Packages: pm: pacman pkgs: 1454 libs: 430 tools: pamac,yay pm: flatpak pkgs: 0
1: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
3: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
4: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
5: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 231
1: cpu: 100% command: ps pid: 5557 mem: 3.89 MiB (0.0%)
2: cpu: 33.6% command: surfshark pid: 2918 mem: 179.3 MiB (2.2%)
3: cpu: 11.4% command: firefox pid: 3063 mem: 494.2 MiB (6.3%)
4: cpu: 8.3% command: cinnamon pid: 2013 mem: 193.2 MiB (2.4%)
5: cpu: 7.2% command: doublecmd pid: 3704 mem: 197.4 MiB (2.5%)
Memory top: 5 of 231
1: mem: 494.2 MiB (6.3%) command: firefox pid: 3063 cpu: 11.4%
2: mem: 275.6 MiB (3.5%) command: firefox pid: 3437 cpu: 5.4%
3: mem: 216.2 MiB (2.7%) command: surfshark pid: 2095 cpu: 1.0%
4: mem: 197.4 MiB (2.5%) command: doublecmd pid: 3704 cpu: 7.2%
5: mem: 193.2 MiB (2.4%) command: cinnamon pid: 2013 cpu: 8.3%
Processes: 231 Power: uptime: 10m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 3.04 GiB
services: csd-power,upowerd Init: systemd v: 258 default: graphical tool: systemctl
Compilers: gcc: 15.2.1 Shell: Bash (su) v: 5.3.9 running-in: pty pts/2 inxi: 3.3.40
My impression is, also based on my other topics launched recently, that Manjaro becomes instable. I hope it is only going on my two laptop computers, running Manjaro Cinnamon.
My hope is that our forum heros can help me out.
Thanks in advance from Hans
