Hello professors, how can I delete a package or software completely ??
My Linux distribution is Manjaro and I did not install the software from their manager package. I downloaded the file directly from the software site itself and installed it manually. Now I delete and reinstall any data. All the data already exists.
There is vscode software that can not be removed completely. If you know a way, please let me know. Thank you very much
In this case these data may be anywhere. What app you installed and how β provide exact steps?
Then you should look for information how to remove it first on the software site.
visual studio code
.tar.gz file
and I installed from snap but There is still old data
The site did not write anything about it or I did not find it
So you installed it in Portable Mode in Visual Studio Code ? Then it should be straight forward what to remove β¦
Hi @A.TBTB,
Check in your $HOME/.config/ directory for any remnant of VS Code.
I, myself, use Code - OSS which, AFAIK, is just an VS Code fork with all M$ Telemetery removed, and there are files/directories under ~/.config:
$ cd ~/.config/Code\ -\ OSS
$ ls
drwx------ mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:31:30 2021 ο .
drwxr-xrwx mirdarthos mirdarthos 12 KB Mon Nov 29 10:45:27 2021 ο ..
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:31:30 2021 ο Backups
drwx------ mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:25:39 2021 ο blob_storage
drwx------ mirdarthos mirdarthos 20 KB Sat Sep 18 14:51:06 2021 ο Cache
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:00:22 2021 ο CachedData
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Fri Sep 24 09:00:23 2021 ο CachedExtensions
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Fri Sep 24 09:00:23 2021 ο CachedExtensionVSIXs
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:24 2021 ο Code Cache
.rw------- mirdarthos mirdarthos 20 KB Mon Jul 19 10:18:43 2021 ο Cookies
.rw------- mirdarthos mirdarthos 0 B Mon Jul 19 10:18:43 2021 ο Cookies-journal
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:24 2021 ο Crash Reports
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:25 2021 ο Dictionaries
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:26 2021 ο exthost Crash Reports
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:24 2021 ο GPUCache
.rw-r--r-- mirdarthos mirdarthos 2 B Wed Nov 24 12:25:41 2021 ξ languagepacks.json
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:24 2021 ο Local Storage
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:25:51 2021 ο logs
.rw-r--r-- mirdarthos mirdarthos 36 B Mon Jul 19 10:18:24 2021 ο machineid
.rw------- mirdarthos mirdarthos 4.2 KB Wed Nov 24 12:31:30 2021 ο Network Persistent State
.rw------- mirdarthos mirdarthos 57 B Mon Jul 19 10:18:34 2021 ο Preferences
.rw------- mirdarthos mirdarthos 52 KB Tue Nov 9 16:04:46 2021 ο QuotaManager
.rw------- mirdarthos mirdarthos 0 B Tue Nov 9 16:04:46 2021 ο QuotaManager-journal
drwx------ mirdarthos mirdarthos 4.0 KB Mon Jul 19 10:18:59 2021 ο Service Worker
drwx------ mirdarthos mirdarthos 4.0 KB Wed Nov 24 12:31:30 2021 ο Session Storage
.rw-r--r-- mirdarthos mirdarthos 74 KB Wed Nov 24 12:31:14 2021 ξ storage.json
.rw------- mirdarthos mirdarthos 1.7 KB Wed Nov 24 12:25:52 2021 ο TransportSecurity
drwxr-xr-x mirdarthos mirdarthos 4.0 KB Sat Sep 11 12:12:17 2021 ο User
Iβm unsure is thisβll help, but I suspect it will.
Thank you very much
Thank you very much
Complete removed
